Cooper discover at3's load E for daily driver yes or no?
Discussion in 'Wheels & Tires' started by taco03Trd, Jul 1, 2017.
  1. Jul 1, 2017 at 10:20 AM
    taco03Trd
    taco03Trd [OP] 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    So i pull the trigger on the coopers at3 but didn't know i got the E load ones . Going on my daily driver . Is this a good idea or not? I dont pull anything but myself going to work LOL . Not much havy loading. i dont want to loose lots of mpgs .
    Any advice would be helpful.
    Trying to get this done today
  2. Jul 1, 2017 at 10:40 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    Being totally honest I haven't found a huge difference in MPG going between and E and a C load tire, 53 pounds vs 45 pounds.
    Do you go in the backcountry much? Or is it 100 percent pavement ?
    looking at your posts it looks like your pretty much on pavement, I would go with a lighter tire then, no need for more protection.
  3. Jul 1, 2017 at 10:43 AM
    taco03Trd
    Carlos
    Riverside ca
    All pavement out here 100 %freeway driver . So not much difference on mpg ?
  4. Jul 1, 2017 at 10:50 AM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    I have had E KOs and now run C's, still avg around 17 MPG. Dosen't really matter what I do. That being said if you want maximum MPG then the lighter tire is the way to go.
    The AT3 look way meatier in person in an E load, nice looking tire.
  5. Jul 1, 2017 at 10:55 AM
    taco03Trd
    Carlos
    Riverside ca
    Yea they are . I think i can survive with some mpgs lost . I do like the look of this tires for sure .. :burnrubber:
  6. Jul 1, 2017 at 10:58 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    E load is way overkill for a 100% street driven Tacoma (unless you tow or haul a lot of weight)...but on the plus side you most likely won't have to worry about punctures or flats at all.
    DavesTaco68 likes this.
  7. Jul 1, 2017 at 10:58 AM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    Lots of good reviews on them.
  8. Jul 1, 2017 at 11:00 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    no! P Metric Michelin AT2!
  9. Jul 1, 2017 at 11:09 AM
    taco03Trd
    Carlos
    Riverside ca
    Yea i just pull out of the tire shop the guy told me the same thing to much for a daily driver . So what should i get the ? The P at3 ?
  10. Jul 1, 2017 at 11:10 AM
    TheCookieMonster
    North East
    GET THE P METRICS!!!!!!!!!!!!!!!
  11. Jul 1, 2017 at 11:17 AM
    taco03Trd
    Carlos
    Riverside ca
    Any good deal out there for the AT3's ? I guess this are for sale now . How much can u sell this for ? WM as this for $146 ea
  12. Jul 1, 2017 at 4:38 PM
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    Good rebates on at3's on ebay through 7/5Screenshot_2017-07-01-17-46-42.jpg
  13. Jul 1, 2017 at 4:52 PM
    Rthompson02
    Rthompson02 Well-Known Member
    NW Florida
    2015 AC with a Hand Shaker
    3 inch leveling kit.
    The load range E tire is 10 ply rated, it does not have 10 ply construction. It is rated the same as a bias 10 ply tire. The load range rating is capable of supporting more load at maximum air inflation (80 psi) than the p metric tire. It won't be more puncture resilient than the p metric tire and it might not ride as good. It won't hurt anything to run them just set the air pressure to whatever the door placard says.
    You should see a lot of miles on the E range tires.
    I have the E range tires on my 2002 and they aren't too bad considering the typical road noise that my BRG KOS have.
  14. Jul 2, 2017 at 5:10 PM
    taco03Trd
    Carlos
    Riverside ca
    Yea i see that the E Rated are 7 lbs more them the P rated tires . So u get good mpgs on the E tires u have now ?
  15. Jul 2, 2017 at 6:19 PM
    Rthompson02
    NW Florida
    Better tire mileage. (Removal).
  16. Jul 2, 2017 at 7:54 PM
    taco03Trd
    Carlos
    Riverside ca
    Removal ??
  17. Jul 2, 2017 at 8:12 PM
    Rthompson02
    NW Florida
    They are likely to have a lot of miles on them before they wear out and need to be replaced
  18. Jul 2, 2017 at 8:45 PM
    taco03Trd
    Carlos
    Riverside ca
    Ok so u run this E Load tires on ur tacoma now ?
    You think i should run them on mine too?
  19. Jul 2, 2017 at 8:47 PM
    taco03Trd
    Carlos
    Riverside ca
  20. Jul 2, 2017 at 9:15 PM
    herbertgerg
    herbertgerg Well-Known Member
    Gary
    1999 SR5 4x4 5spd Access Cab
    Been running E rated tires a long time. 80 k on the last set and they still have tread left. Do they weigh more, sure; but there nothing like a little peace of mind knowing there is a tire down there with a little more beef.
    And the roads where I drive are much more likely to flatten a tire than any trails off road I've ever been. People pick up after themselves on the trail, but I've never seen someone pull over on the freeway and pick up all the construction debris full of nails and screws they just let blow out of their trailer. E load rated tires are truck tires. P rated tires are for cars. The MPG loss is negligible.
