Cooper AT3s 265/75R16 height difference vrs TRD OR stock 265/70R16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by marshall765, May 15, 2015.
  1. May 15, 2015 at 3:27 PM
    marshall765
    marshall765 [OP] Well-Known Member
    Shreveport Louisiana
    13 DCSB TRD Offroad 4x4
    IMG_1731.jpg IMG_1733.jpg IMG_1732.jpg IMG_1736.jpg IMG_1735.jpg IMG_1734.jpg
    First time poster here! I have been lurking since 2013 when I bought my 3rd Toyota but first Tacoma. I also own a 2003 Tundra and traded a 2006 4-runner for the pictured TRD OR 4x4. I do not have much 4x4 experience, but have been in Toyota's for 10 years now. Enough with introductions.
    I replaced my stock 265/70R16s today with Cooper AT3's in 265/75R16s and gained 1/2 inch in height. I have read many times on here that the 265/75R16 is the largest tire size I can run on the stock rims without complications. For some reason I thought I was going to gain closer to an inch with this tire, but that's not the case. Don't get me wrong, i'm not looking to go to big with my truck, but an inch more was what I was going for.
    With that in mind here is my contribution. Pictures of a stock 265/70R16 with less that 20 miles on it (its the spare on a 16inch steel rim), up against a brand new set of Cooper AT3s in 265/75R16. As you can see, there isn't much of an altitude gain at all.
    The truck has 3 inch Pro-Comp Coil overs in the front with UCAs, and blocks plus AAL in the back. I know many of you hate everything except OME, Toytech, and Blisteen, but this setup is working well so far. After the upcoming hunting season is over, I will have a real idea of how well Pro-Comp works on the truck.
    PineBurger likes this.
  2. May 15, 2015 at 10:41 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Different makes of tires will vary in height...not all 265/75/16's are the exact same. Also, if your rims are wider than the stock steel wheel it will make your tires shorter. On my FJ40 the 35/12.5/15's are about a half inch shorter in height on a 10" wheel than the same tire on an 8" wheel.
  3. May 15, 2015 at 11:56 PM
    bueller
    bueller Well-Known Member
    AZ
    That picture isn't really a fair comparison since the AT3 is on the truck with weight on it. The only way to truly see the difference in height would be to have both tires off the truck side by side.
    PineBurger, Teksen and flafos like this.
  4. May 16, 2015 at 5:42 AM
    marshall765
    Good point. I will do that and post a pic.
  5. May 16, 2015 at 7:09 AM
    marshall765
    IMG_1742.jpg IMG_1739.jpg Ok, as Bueller pointed out. My comparison wasn't consistent. Here are the new pics, both tires off of the truck. The cooper A/T is 3/4 of an inch taller than the stock tire, not to shabby.
    flafos likes this.
  6. May 16, 2015 at 8:50 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    one thing you can do is look at the mfg specs. they will list OD which is a good indicator of size. but being loaded you will achieve less than that and over time wear down the tread making it even less and less :)
  7. May 17, 2015 at 5:05 PM
    Jtaoj0
    Jtaoj0 Well-Known Member
    The tires are 1" diff with the 265 75 being the larger. But half is above center of the wheel and half below. Thus the 1/2" increase in height of the truck and not a full inch.
  8. May 17, 2015 at 5:42 PM
    marshall765
    What do you mean, the proof is in the pudding, as the pics above show, its 3/4 of an inch gain.
  9. May 18, 2015 at 11:25 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    new tires vs worn tires. tread decreases :D
    also construction of the tire determines what actual size it is
  10. May 18, 2015 at 11:40 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Truck height is only increased by the increase in the radius of the dire, not diameter (2x radius). So a 1inch bigger diameter tire, will lift your vehicle 1/2in
  11. May 18, 2015 at 2:32 PM
    marshall765
    The tire is the spare with less than 20 miles on it. both tires have full tread.
  12. May 18, 2015 at 2:33 PM
    marshall765
    I put a measuring tape on it! There are pics! 3/4 inch gain.
  13. May 18, 2015 at 2:38 PM
    nd4spdbh
    SoCal
    again like stated, sizes are close but approximate.
  14. May 18, 2015 at 2:42 PM
    marshall765
    Again like stated? Sorry, I missed were you said approximate above.
  15. May 18, 2015 at 3:03 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The lowest points on our Off Road Tacomas being the bottom of the rear differential and the transfer case area. With stock 265/70-16 (31") tires, the truck had 9.25" of ground clearance.
    When I switched to 265/75-16 (32") tires, the truck now has 9.75" of ground clearance. 1" taller tire adds 1/2" of ground clearance. New, unworn tires.
    Measuring from the center of the wheel to the outer edge of the tire, that 1" taller diameter is 1/2" in each direction (radius) increase.
    Keep in mind, the intentionally fast set speedometer will now read correctly, but the accurate odometer will read slower. Making you have less miles that you really traveled, and making you think your gas mileage is more worse than it really is. Add 5 miles for every 200 traveled to find your true mileage.
  16. May 18, 2015 at 3:08 PM
    nd4spdbh
    SoCal
    :rolleyes: as OTHERS have stated.
  17. May 18, 2015 at 10:34 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    nd4 and David has it right. your truck isn't sitting "on top' of the tires, it is sitting in the middle so you have to split the difference in overall "tire height" and that's the "increased truck height"
    and sorry, I though it was the worn tire in the pic, I'll look more closely next time :)
  18. May 19, 2015 at 2:13 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    how do you like the cooper's. im looking at the same tire. my truck rides rough with the bfg's KO's 8 plys.. im looking at the 6 ply option,, where did u buy them and what cost,, im looking at them on Amazon 144.00 each free shipping ..thanks
  19. Aug 15, 2015 at 5:46 AM
    Zoot
    Zoot Well-Known Member
    2011 DC/SB TRD O/R 4X4
    Toyota bed mat, Wet Okole's F&R, Window Tint, custom trail-stripes, Cooper A/T3 265/75R16, MedlinAround interior LEDs, Leer 100r, aFe air filter, K&n cabin filter
    The stock BFG were supposed to be 30.7, and cooper's 31.5 from what i can remember. I did the comparison while mine were getting put on and I got about the same 3/4" difference.
  20. Aug 15, 2015 at 6:17 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    That is how I always looked at it . Very well put. Now what you said about the milage is very interesting. Good to know ! Thanks for that .
    David K[QUOTED] likes this.
