Cooler/Surf Rod Racks?
Discussion in 'Boating & Fishing' started by K Williams, Apr 18, 2014.
  1. Jan 4, 2019 at 7:39 PM
    SeaPA
    SeaPA Well-Known Member
    NC
    2019 DCLB TRD OR 4x4
    Where did you get this rack? Looks like the perfect size!
  2. Jan 6, 2019 at 9:33 AM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
  3. Jan 6, 2019 at 12:51 PM
    SeaPA
    NC
    Thanks for sharing. I'm actively checking Craigslist, but I feel like winter is the wrong season.
    If anyone is looking to sell one, let me know!
  4. Feb 14, 2019 at 5:26 PM
    EdubTRD
    EdubTRD Well-Known Member
    Eastern NC
    2005 White SR5 2.7 Access Cab
    I wanted to put a front hitch on my Gen 2 but couldn’t stand how it looked without the fishing/cooler rack. I settled for a rear rack which I like and found pretty functional.
    I just got a 2019, time will tell how I set it up.
    Sudsman44 likes this.
  5. Feb 14, 2019 at 8:17 PM
    Sudsman44
    Abington PA
    Nice looking truck. I’ll keep an eye out for you down at ramp 44.
    EdubTRD[QUOTED] likes this.
  6. Feb 20, 2019 at 8:28 AM
    GSPdog7
    GSPdog7 Well-Known Member
    Allen
    Central VA
    2015 Silver Sky Metallic TRD Off-road
    I’m building one just like yours as we speak. Anything you’d add or do different? :thumbsup:
    Coming down in April, June and October.
    Anyone ever fish in April? First time fishing that early down there.
  7. Feb 20, 2019 at 3:37 PM
    EdubTRD
    Eastern NC
    Thanks man! It works for me, especially being that I only go for 1 week during the year.
    Things I would do differently:
    1. I would mount a cutting board on it with some aluminum angle.
    2. I would use all 2” PVC to make my rod holders.
    Things I did that I definitely like:
    1. I would definitely angle a rod holder on the end for tying on leaders, tackle and bait etc (it allows line to hang down from your rod tip for easy access).
    2. Leave one end open to allow for easy access when loading/unloading coolers.
    Things to consider:
    1. Pay careful attention when attaching your rod holders, be sure to space them far enough apart to accommodate your reels.
    2. Make sure your rod holders are tall enough so that when you mount the rack on your vehicle, the rods don’t hang down below the rack(they will get damaged if you don’t have enough clearance below).
    3. If you install a cutting board, use countersunk screws for a flat surface.
    4. Use all stainless hardware and fasteners.
    5. Cut a notch in the top of your rod holders for the base of the reels to slide into, it keeps your rods from spinning and more stable while riding. (I travel with my rods on top of my camper shell in snowboard racks until I get to the beach. Then they go in the fishing rack until I leave the beach).
    I hope this helps. Post your final product if you get around to making one.
    I always fish in the fall, so not much knowledge about spring fishing. I hear the bull reds run sometime in late winter/ early spring though.
    Attached is a couple photos of the rack I made for my parents which was my second attempt and I like it better than mine.
    168C552F-D0FD-4390-86AE-75A8E66C091C.jpg 5119C089-DB05-4DC6-8EC7-1D9FD375324B.jpg
  8. Feb 20, 2019 at 3:43 PM
    Sudsman44
    Abington PA
    glue 2” PVC couplers to the tops of the tubes. Gives you smooth finished ends that wont scratch your gear.
  9. Feb 20, 2019 at 3:50 PM
    EdubTRD
    Eastern NC
    I agree, that would make for a nice finish. However, I’ve found that without a notch cut in the holders the rods spin around and bang into each other when riding down the beach/road.
  10. Feb 20, 2019 at 6:16 PM
    GSPdog7
    Allen
    Central VA
    Good ideas and tips. I bought 1 1/2” and 2” pipe and was thinking the 2” pipe was a little to big. Was trying to keep the play down while the rod was sitting in them. I’m going to definitely slot the top end So they won’t spin. Was trying to find a rubber kind of coating like Plasti dip to put on them but haven’t found any yet. I bought a harbor freight rack for 40 bucks off a guy on Facebook. Got some rods coming Friday so I’ll have from 7ft to 12ft rods to make sure I have my heights correct. :thumbsup:
  11. Feb 20, 2019 at 6:24 PM
    EdubTRD
    Eastern NC
    Maybe Flex-seal or some kind of rubber bed liner? You could also try a rubber Fernco band, but once you clamp it, may not look as nice... you’ll figure it out.
    Post a picture once you get it done!
    Happy fishing!
  12. Feb 21, 2019 at 3:28 PM
    Sudsman44
    Abington PA
  13. Feb 21, 2019 at 5:10 PM
    EdubTRD
    Eastern NC
  14. Feb 21, 2019 at 7:05 PM
    GSPdog7
    Allen
    Central VA
    I was thinking the same thing. I may order some and use whatever pipe it fits. I’d think 2” schedule 40 should be the norm.
  15. Feb 22, 2019 at 12:23 PM
    #35
    GSPdog7
    Allen
    Central VA
    I just called and they told me they fit
    1 1/2” pipe FYI.
  16. Feb 22, 2019 at 7:27 PM
    #36
    DrummyTaco
    DrummyTaco Feeeesh
    Outer Banks
    2017 Tundra Platnium, 2017 SR5 DCLB 4x4 (rip), 1996 reg cab 4x4, 1997 xtra cab 4x4
    Are you a member on SOl or Pierandsurf by chance? I’ve seen the handle before. And since you said “44” instead of “the point” it kinda strung a bell since not many people name the location by number. Ain’t been on either forum in a while though.
    I fish the point quite often and 55 as well as 38. My fiancé is “frank n frans” granddaughter.
  17. Feb 23, 2019 at 9:59 AM
    #37
    Sudsman44
    Abington PA
    I am on P&S but not too much anymore. It’s not what it was years ago. I generally make 3 trips a yr to HI. Spring and Fall to fish, and once in the summer for the family. Scoping out retirement possibilities for sure.:fingerscrossed::fingerscrossed:
  18. Feb 23, 2019 at 3:26 PM
    #38
    DrummyTaco
    DrummyTaco Feeeesh
    Outer Banks
    Agreed, it’s been 5yrs or so since I been on there.
    Good luck with finding a place, here soon you won’t have to worry about the bridge collapsing and getting stuck on the island.
  19. May 29, 2019 at 10:25 AM
    #39
    RedTacoOR
    RedTacoOR Member
    2019 Red TRD OR
    Hey guys, I fish the OBX and Southern beaches down to Fort Fisher. I just bought a 2019 Taco OR to replace my Jeep JKU. Does anyone know if a front rod or rod/cooler rack will conflict with the safety sense system? I own both a rod only rack and one that can hold a cooler, it would suck if I bought a front hitch only to find out the truck keeps the brakes applied the whole time or throws warning lights. Thanks in advance.
  20. May 29, 2019 at 4:07 PM
    #40
    DrummyTaco
    DrummyTaco Feeeesh
    Outer Banks
    Are you opposed to having a rear hitch mounted cooler/rod rack?
