Coolant Temp Gauge Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zersko, Feb 1, 2020.
  1. Feb 1, 2020 at 6:46 AM
    Zersko
    Zersko [OP] Well-Known Member
    Northeast
    2016 Tacoma SR5
    08 Tacoma 205,000miles
    Recently started having a “problem” with my coolant temp gauge. I start my truck and let it warm to about quarter way up the gauge then start driving. When I give it gas the needle will start falling to “cold” and when I let off the gas it will start to raise again. Seems like the needle is a little higher than normal when driving too until I let off the gas again. Heat and A/C both work great. Any help would be appreciated. Thanks.
  2. Feb 1, 2020 at 6:50 AM
    DG92071
    DG92071 Well-Known Member
    I don't know what the problem is but I would take a look at the alternators output (volts while running) at various engine RPM's. Good luck.
  3. Feb 10, 2020 at 9:42 AM
    Zersko
    Northeast
    2016 Tacoma SR5
    Anyone?
  4. Feb 10, 2020 at 9:48 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I'd start looking to see if it's the gauge (unlikely, IMO) or something else in the cooling system. Perhaps a stuck or failed t-stat?
    Ya gotta confirm the gauge data is right or wrong before drawing any conclusions.
  5. Feb 11, 2020 at 2:22 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Have you done any work to the coolant system recently? The issue could be an air pocket in the engine.Park uphill and warm up the engine with the radiator cap off and see if you can burp the air out.
    The sensor in the engine is not designed to read air temperature so when the air pocket is on the sensor the reading drops.
    PzTank likes this.
  6. Feb 11, 2020 at 5:45 AM
    Scalleywag
    Scalleywag Well-Known Member
    North Carolina
    2005 SR5 Double Cab V6 6 Speed
    I’d use an OBD2 scanner with live data to compare the actual engine coolant temps to what the gauge is displaying, best to have a passenger to monitor this if you’re going to be the one driving.
    I’m dealing with a fuel gauge issue that I’ve diagnosed extensively and I believe I have a bad instrument cluster, 206,000 on my truck.
    A brand new cluster from Toyota is about $360 for my 2005, but there are also instrument cluster repair shops that will fix your cluster if you send it to them. A google search will give you a whole list of options if your temps prove to be stable and you determine that the cluster is at fault.
  7. Feb 11, 2020 at 8:54 AM
    Zersko
    Northeast
    2016 Tacoma SR5
    Nothing has been done to coolant system since I bought the truck 24k miles ago.
  8. Feb 11, 2020 at 9:02 AM
    Zersko
    Northeast
    2016 Tacoma SR5
    My fuel gauge is all over the place too. Never actually know when the tank is empty so I just fill up every 200 miles. That has been the only gauge problem I've had. I think im onto it being the T stat though because yesterday I found if I dont run the heat or air when warming my truck up it gets to operating temp much faster.
  9. Feb 11, 2020 at 11:51 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @Scalleywag was the fuel gauge itself the issue or was it the sending unit?
  10. Feb 11, 2020 at 12:13 PM
    Scalleywag
    North Carolina
    I’ve gone through two replacement sending units and traced all the wiring from the pump connector to the dash. My current sending unit is a brand new OEM Denso that was bought direct from Toyota. No change to the indication error.
    I cleaned every ground I could find thinking maybe I had a corrosion issue.
    The only two items that are left are the cluster and the Body ECU. I really think it’s the cluster as everything else works perfectly, including every other gauge on the truck.
    I can afford a new cluster but I’d be sick to spend $360 and that not fix it. The Body-ECU is over $700; so like most on the forums, for now I’m using the odometer and scangauge II.
    I’d love to find someone nearby (Triad area NC)with a 4x4 V6 6spd and a working fuel gauge that would let me swap the clusters and see if the problem follows the truck or the cluster.
    I think there are a lot of folks on here with janky fuel gauges, as many people as report running out of fuel at 1/8-1/4 of a tank I think the root issue is relatively common.
    Larzzzz[QUOTED] likes this.
  11. Feb 11, 2020 at 12:15 PM
    Scalleywag
    North Carolina
    can you elaborate a little more on what exactly your fuel gauge is doing?
  12. Feb 11, 2020 at 12:26 PM
    Zersko
    Northeast
    2016 Tacoma SR5
    When I bought the truck the fuel gauge was slammed at the bottom with the gas light on. Guy said it always sits there. Well first fill up and it showed it was full. Then after 100 miles it went to quarter tank and so on. Every time I started the truck within the first few weeks of ownership the needle was in a new spot. Nowadays 50 miles after refuel it starts to drop but I can still never get an accurate reading.
  13. Feb 11, 2020 at 12:32 PM
    Larzzzz
    Larry
    MA
    I'ma thinking.... Is it possible to use a battery and potentiometer to test the input to the gauge itself sitting on a table or a bench.
    @Jimmyh might you have drawings for the cluster and the gauge (s) inputs?
  14. Feb 11, 2020 at 1:00 PM
    Scalleywag
    North Carolina
    Not certain about the temp gauge but Toyota lists a test procedure for the fuel gauge that is a simple key on with and without a jumper to test the gauge function. Naturally my truck passed that needle swing text but the gauge still isn’t right.
  15. Feb 11, 2020 at 1:00 PM
    Scalleywag
    North Carolina
    To your knowledge has any wiring been modified on your truck?
  16. Feb 11, 2020 at 2:22 PM
    Zersko
    Northeast
    2016 Tacoma SR5
    As far as I know everything is original and wiring hasnt been messed with. Still surprises me that this is my first truck with over 200k miles and also my first truck that doesnt have a constant glowing CEL
    Larzzzz likes this.
  17. Feb 11, 2020 at 3:03 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It should do this anyway. That is normal.
  18. Feb 11, 2020 at 3:06 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Did you check the coolant system for air?
  19. Feb 11, 2020 at 3:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  20. Feb 21, 2020 at 11:15 AM
    Zersko
    Northeast
    2016 Tacoma SR5
    Okay changed the thermostat, theres no air in the system. Still have the same problem. Still takes a while to warm up and temp gauge still drops when accelerating and when parked (sometimes).
