coolant system flush while replacing radiator
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stout890, Dec 29, 2011.
  1. Dec 29, 2011 at 1:03 PM
    Stout890
    Stout890 [OP] Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    ok iv searched all over and cant find anyone addressing this concern, im replacing my radiator and want to do a coolant system flush, block, heater core and all. but im curious do i do the flush with the old radiator on or with the new one on. or is there a way to do a flush with no radiator on?
  2. Dec 29, 2011 at 1:06 PM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    :popcorn: I have to flush mine soon..
  3. Dec 29, 2011 at 1:10 PM
    jsutter
    jsutter Well-Known Member
    Jim
    Southeast Ohio
    08 Reg. Cab 4cyl 2wd
    cruise and intermittent wipers
    You need to drain the coolant out to replace the radiator anyways, so why do you think you need to flush it too? The little bit of coolant left in the engine won't hurt anything.
  4. Dec 29, 2011 at 1:30 PM
    Sunner
    Sunner Well-Known Member
    I would flush it just to get the passage ways in the block and hoses clean too since you are there already. OP, I dont think there is a specific order you need to do this. Personally Ide do it with the old radiator in there. And Im sure you cant flush it with the radiator off.
  5. Dec 29, 2011 at 1:43 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Anyone should flush a system if replacing a radiator if they like to do good jobs not half ass. Unless the truck has low low miles and even than I'd still do it.
    I absolutely have to do it because I was topping off with green coolant and didn't realize the effects of that. So I am going back to silicate free Toyota red coolant and I want it to be free of all the nasty old coolant.
  6. Dec 29, 2011 at 1:45 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    I worry about flushing out nasty rust or deposites from the old rad into the engine block. But than again I don't want to flush nasty engine block build up into my new rad.
  7. Dec 29, 2011 at 1:56 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I would do steps 1-7 first with old radiator then replace it and do it again after new radiator is installed.
    Coolant flush steps
    1. drain radiator
    2. disconnect upper radiator hose
    3. put garden hose into radiator fill
    4. turn on water & start engine
    5. run till water is clear then shut off water
    6. when engine stops pumping water out hose shut off engine
    7. reconnect radiator hose
    8. add coolant till radiator is full
    9. start engine & add coolant till it wont take any more
    10. let engine get warm then let it cool off & check coolant level
  8. Dec 29, 2011 at 2:00 PM
    Sunner
    I was considering the 2nd being more of a problem, having crap from the block going into the new rad. I think you'de be fine giving it a good flush with the old rad on, do it twice if it makes you feel better. Or as many times as it takes until you are draining clear fluid out of it. Are you going to be using a chemical or just distilled water?
  9. Dec 29, 2011 at 4:35 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    I'm going to use the garden hose then 1 gallon of distilled water.
  10. Dec 30, 2011 at 9:23 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
  11. Dec 30, 2011 at 9:36 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Flush the system with old radiator on, till you get clean water, will take several times, then for good measure flush the system once or twice with the new radiator on, to clean out any materials that were left from manufacturing. Then add your 50/50 mixture. I used regular tap water to flush coolant system.
  12. Dec 30, 2011 at 9:57 AM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Which radiator hose is the output to the engine? Upper or lower? Should I flush with both the drain plugs open? Iv read to run the engine while flowing water from a hose in through the radiator cap until its warmed up so that the thermostat is open. If I have the upper rad hose is disconnected is it ok to have that water dumping all over the radiator? I'm sure it will be ok but is there a better way like just having the lower drains open?
  13. Dec 30, 2011 at 10:01 AM
    MGMAddict
    MGMAddict Well-Known Member
    Doylestown,PA
    TRD Sport
    Bilstein ULC
    Whatever you do, refill your cooling system with toyota long life coolant don't use the new super long life coolant. Im a mechanic at Lexus and that stuff causes nothing but problems. When I get my 2012 thats one of the first things I'm draining out of it. We never had issues with cooling systems like we do now. Just my 2 cents.
  14. Dec 30, 2011 at 10:07 AM
    Sunner
    I havnt done a flush on my truck but I have flushed my bikes many times, I drain the old coolant, fill the system up with cleansing chemical,(CLR works great from what Ive heard, never tried it, might want to check it out) seal up the entire system and just run the engine until the water starts flowing, let the system circulate for a few minutes, flush then repeat. Its easier on bikes because they heat up quick but that is how I plan to flush my system on the truck as well.
  15. Dec 30, 2011 at 10:09 AM
    Sunner
    Whats the problems you guys are having? I am assuming this coolant is ordered through the dealer? When I do go to get this coolant, I just ask for "long life coolant"? Does the other one actually say "super long life coolant" vs "long life coolant"?
  16. Dec 30, 2011 at 10:37 AM
    4Wheelin4Banger
    Randy
    Bottom hose is output of radiator, top hose is output from engine. I rinse everything real good when done and haven't had any problems.
    I never open the drain plugs (crap can get in them and cause them to leak).
    Yes and turn the heater to full hot (so it gets rinsed also).
  17. Dec 30, 2011 at 10:46 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Doesn't coolant flow through the heater core regardless of the heater control positions in the cab? I thought the levers simply controlled whether air is routed across the core? :confused:
  18. Dec 30, 2011 at 11:21 AM
    4Wheelin4Banger
    Randy
    I don't know it's just the way my father taught me a long, long time ago in a galaxy far, far away.
  19. Dec 30, 2011 at 3:32 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    I would think the temp selector lets the heater core open up and the fan selector allows air to flow over
  20. Dec 30, 2011 at 4:09 PM
    Norton
    Based on the attached extract from the FSM, I don't think so. I believe the temp selector controls the "percentage" of air flow routed across the heater core (note the AIR MIX terminology), while the fan selector controls the total flow of air through the system.
