coolant reservoir not going down?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ginseng27, Apr 19, 2022.
  1. Apr 19, 2022 at 11:42 PM
    ginseng27
    ginseng27 [OP] who knows?
    '17 DCSB OR
    not enough.
    Hello all,
    I've been trying to chase down a coolant issue. I think there's a blockage somewhere but I wanted to pick the brain trust and see if I'm missing anything.
    First things first:
    Had some engine hesitation and cylinder misfire. cleaned the maf sensor and put in better gas and it seemed to go away. While I was testing my fixes out (doing some driving around the local highway), saw my engine was overheating. immediately went home and turned it off. saw it spike up to 230F.
    So I looked through everything and noticed my reservoir was overflowing and was actually spewing coolant out of the overflow. I replaced my radiator cap. easy enough, that seemed to work for a little bit. then the engine starting overheating again. Heat would rise when engine RPM's were low and woudl kinda stabilize to acceptable numbers when the RPM's were higher. So the drive home was stressful. Also noticed no heat coming from the heater core an could hear water sloshing in the heater core behind my dash. air in the system!
    So I replaced the thermostat and had to add a ton more coolant using the special funnels. Everything seemed fine when I did this. I let the engine idle for a while and it kept the temperatures pretty good. Reservoir didn't fill up in my 1.5 hour test. highest temps I saw in a 45 min idle was 212f. Drove around, everything seemed fine. Temperatures were all acceptable after a little drive. No air in the system that I could detect.
    Then earlier today, I went for a drive and the temperatures all seemed fine but I noticed my coolant reservoir was a little high. Okay, maybe it's becuase it's hot. that's normal. But I checked it when the engine was as cold as can be and the reservoir has not lowered. not one bit. I looked in the radiator cap and it was bone dry in that area when previously it was definitely full to that point. I drove home because it was a short drive and the reservoir in fact, went up and started overflowing again. I could hear my serpentine squealing halfway home. Also noticed air in the heater core as there is sloshing behidn the dash.
    What does the brain trust think? The only other thing I can think is maybe the radiator has a blockage and the nuclear option is to replace it entirely but I want to see if there's anything I'm missing. Is there a blockage in the reservoir? is there a leak somewhere I'm not detecting?
    TL;DR:
    engine coolant reservoir is not going down. suspect blockage but not sure. engine temperatures SEEM fine for now but there's air in the system when previously there wasn't.
    here's a few photos. This is the coolant as of now:
    You can also see that it definitely spewed out, that little bit of wet spot on the hose is coolant. I suspect that this has been spewing out and caking the front of my engine for a bit as there's a ton of grime and dirt there.
    I should note: 122k on a 2017
  2. Apr 19, 2022 at 11:54 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    check the radiator for restrictions such as dirt/mud or any other debris that may be stuck in between the fins before you rule out the radiator as being bad. Did the misfire condition happen before the motor overheated, or during? And how long did the misfire occur?
    Gunshot-6A likes this.
  3. Apr 19, 2022 at 11:56 PM
    ginseng27
    '17 DCSB OR
    not enough.
    debris between the fins being more than the normal simple bug stuck in there? I didn't do a dedicated search but didn't see anything that would catch my eye. I can check later tomorrow when I get a chance.
    the misfire happened before the motor overheated. it happened once and then the engine went into limp mode. I pulled off the freeway, and turned off the engine, looked around and smelled around, nothing. then I started it up and it started up just fine. I had to take care of a few errands so I gingerly drove around and could feel some engine hesitation. After cleaning the maf sensor and putting different fuel in, the engine seems much happier. no hesitation.
  4. Apr 20, 2022 at 12:07 AM
    MonkeyProof
    SoCal- SGV
    how did you bleed the coolant system? did you use a funnel attached to the radiator and climate control with Heat on?
    Two questions, the misfire and possibly the hesitation should have have set the engine light on. Did you retrieve any trouble codes? Second question is, why did the motor overheat the first time?
    I guess one more question, do you have a scanner/code reader available?
    Hobbs likes this.
  5. Apr 20, 2022 at 12:13 AM
    ginseng27
    '17 DCSB OR
    not enough.
    Yes. Used the funnel attached and ran the heat on high. Watched the bubbles come out of the system.
    Yes. The engine light came on. P0302. Cylinder 2 misfire. I pulled the code immediately because I have a reader on me at all times. After i restarted the engine after the misfire and limp mode, the cel was not lit and the next day, when I went to get some parts (i suspected plug and boot at this point), i tried to read the code again and it was gone entirely.
    The first overheat event, I'm not sure exactly what happened. I noticed it as I was testing my maf cleaning. The reservoir was overflowing and the temps were climbing.
    SR-71A likes this.
  6. Apr 20, 2022 at 12:43 AM
    MonkeyProof
    SoCal- SGV
    A realy boogered up MAF sensor could effect both banks only, not just one cylinder on a bank.
    Bank 1 passenger side Cylinders 1-3-5
    Bank 2 driver side Cylinders 2-4-6
    Are there any abnormal noises or leaks from the water pump? Any leaks at the rear of the block? Gotta find the cause of the overheating concern.
    One thing maybe look for is a misfire at first startup after been sitting for a few hours. The misfire may only last for a few seconds and won't set a MIL.
    If you have a suitable scanner/code reader that has Mode 6 data, you can check for prior misfire(s) and present misfire(s) in the current drive cycle. Mode 6 data is actually pretty useful for diagnosing drivability concerns. Mode 6 will capture events that don't set a MIL/CEL
    Here's a screen shot of my Mode 6 Data from the Fusion App from a few weeks ago..
    You can see that I had some misfires at Cyl#4
    Another example of Mode 6 Data.. I also had a Pending Code P0430. looking at Mode 6 Data I got a pretty good idea of whats going on as to why I had that pending code..
  7. Apr 20, 2022 at 4:40 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Now if you looked at the obvious. What about the coolant line in the back of the engine? It should spray on the tranny. Also if you changed the thermostat maybe the water pump??? Interested in solution for the old memory bank
    ginseng27[OP] likes this.
  8. Apr 20, 2022 at 5:02 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I would perform a compression test (at a minimum on #2) and coolant system pressure test. If air is getting in the system and you have a random misfire, it is possible you may have pushed a head gasket. This is a free test you can do by renting the tools if you don't have them.
  9. Apr 20, 2022 at 5:05 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How is the fan? Is it cycling on and off? Is it running while you over heat?
  10. Apr 20, 2022 at 5:14 AM
    MonkeyProof
    SoCal- SGV
    This is why I suggested to watch for a misfire at first startup, most often in this situation the misfire lasts for just a few seconds as the coolant inside the cylinder burns off and is easily not noticed.
    edited:
  11. Apr 20, 2022 at 5:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    disconnect the hose between rad and overflow and verify no blockage with air
    Verify new radiator cap is the correct one and operates as it should
    Verify fan is properly working
    Verify the rear coolant fitting that some have reported cracking isn't an issue
    Pressure test the system to verfiy no leaks. Tools can be rented at parts house.
  12. Apr 20, 2022 at 5:24 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    pull the plug. if it looks really clean like steam cleaned you have a HG issue or worse a crack somewhere. no tool rental necessary
  13. Apr 20, 2022 at 5:46 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    First thing I would do is to replace the radiator cap. Cheap, easy, and an integral part of your cooling system. That is the key to your over flow functioning properly. I would start by watching one of the hundreds of videos on the YouTube about how your cap works. Then start looking further from there if that doesn't fix it. No need to get complicated thinking you have a serious issue until you eliminate the simple things.
  14. Apr 20, 2022 at 5:48 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    OP has already done that. Right in the first post.
    Skydvrr likes this.
  15. Apr 20, 2022 at 5:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    :D
    ginseng27[QUOTED][OP] and SR-71A like this.
  16. Apr 20, 2022 at 5:49 AM
    auskip07
    Skip
    Atlanta, Ga
    guys radiator caps dont cause misfires. dont waste money on nonsense parts.
  17. Apr 20, 2022 at 6:21 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Did you ever "burp" it?
    Is there coolant in the oil?
    Have you started it cold, with the radiator cap off, and are there bubbles coming up especially at high RPMs? If so... bad head gasket.
  18. Apr 20, 2022 at 6:25 AM
    TNFirefighter29
    TNFirefighter29 Well-Known Member
    Tennessee
    2020 Magnetic Grey Tacoma TRD
    If your reservoir is filling up, you are pulling fluid from your engine without replacing it from the radiator due to blockage. Dropping level in the radiator sounds like it is flashing off in the engine because of the blockage. I believe you are way beyond simple fixes, coolant issues seem to build up slowly into major issues. I agree with others pull your #2 spark plug. Have a compression test ran along with a coolant system pressure test. In my opinion your cylinder miss is being caused by blown head gasket, or head issue caused by blockage or a bad water pump.
  19. Apr 20, 2022 at 6:28 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    If you have unexplained air coming into the cooling system, you need to be looking at a head gasket issue.
    evolx likes this.
  20. Apr 20, 2022 at 6:32 AM
    MonkeyProof
    SoCal- SGV
    Also, a leaky HG on the exhaust side can potentially cause an overpreasure condition within the coolant system. Which can sometimes explain why the coolant bottle is overfilling and spilling over without a present overheating condition.
