Coolant Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jscribn1, Mar 14, 2021.
  1. Mar 14, 2021 at 8:21 AM
    jscribn1
    jscribn1 [OP] Active Member
    Justin
    2009 4.0, I noticed a leak under the front skid plate. I thought it was trans fluid or power steering but after cleaning it up and driving again its definitely coolant. It's not bad but enough that warrants a fix. Looking at it I can't tell where it's coming from. Could it be the water pump? Could it be a leaking thermostat housing? None of the hoses appear to be the issue. There will be coolant on the belt when it sits after driving. It's got 160k on the motor, first Tacoma so I'm not sure how long they last. Any help or suggestions would be appreciated.
  2. Mar 14, 2021 at 8:24 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Flashlight and look from the hop, it really could be a number of things. Although I don't have enough knowledge of the Toyota V6 to tell ya more, chech radiator hoses first, super easy.
    You should expect many more miles with proper fluid changes.
  3. Mar 14, 2021 at 8:27 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Definitely check the water pump, also remove skid plate (only 4 bolts) so you can see better. Once you remove skid plate you’ll have an easier view of hoses, thermostat, water pump areas from below.
    idahodesert likes this.
  4. Mar 14, 2021 at 8:42 AM
    jscribn1
    Justin
    I removed the skids to look and left them off for now. Should I check it while it's running? If it is the water pump where do they usually leak from? I'm new to the Tacoma world, it's actually my 17 yo daughters truck.....
  5. Mar 14, 2021 at 8:48 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    on YouTube there is Toyoda Mechanic that goes over monitoring leaks
    F'ing time change I can not remember her name right now
  6. Mar 14, 2021 at 8:57 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Check behind fan, water pump may be leaking at the front shaft seal. Should be able to see leak with engine off. Thermostat is right there too. If you can bring engine up to temp then turn off and monitor for leak.
  7. Mar 14, 2021 at 8:58 AM
    jscribn1
    Justin
    I'll go search the you tube right now! thanks
  8. Mar 14, 2021 at 8:58 AM
    jscribn1
    Justin
    I guess I know what I'm doing today! Thanks
  9. Mar 14, 2021 at 10:41 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Virtually all water pumps work the same way, despite model type. They have a weep hole at the bottom for coolant to escape when an internal shaft seal starts to go bad. Always check when not running. If leaking for a long time, I'm thinking 3+ months, there will be crusty material collecting at the weep hole. The color will match the color of the coolant, although a little lighter.
    If the radiator OEM hose clamps have been replaced with worm gear style clamps, you may need a fix as simple tightening the clamps. Keep in mind that most coolant leaks will get pushed back as the car moves forward. So, look for source of a leak directly above and forward of the leak point.
    Coolant leak sources, in my perceived order of prevalence:
    coolant hoses, and hose clamps (don't overlook hoses into the heater core)
    Water pump gasket and/or weep hole
    Coolant reservoir
    Radiator, check the cap also
    Thermostat gasket/housing
    Rusted freeze plugs
    Head gasket
  10. Mar 14, 2021 at 11:30 AM
    jscribn1
    Justin
    Great info thanks for the detailed post!
  11. Mar 14, 2021 at 12:32 PM
    Waasheem
    Waasheem
    2007 xrunner
    Leaks in general can be tricky. It could be coming from up high, dribbling down and dripping from a hose below the actual leak to trick you. Airflow could also move the dribble & fool you. You just gotta look, flashlight & telescopic mirror helps. If you’re still having a hard time locating the exact source a pressure tester works good.
    I had one, 2 guys before me couldn’t find the leak, I pressure tested it and found it leaking from the radiator end tank seam up high, it was spitting air and coolant. I think pumping air in was creating an air pocket right where it was leaking from so it was difficult to see. I made sure everything was completely dry, and it was filled to the top first.
  12. Mar 14, 2021 at 1:51 PM
    jscribn1
    Justin
    Good idea, I think pressure testing will be the key
  13. Mar 14, 2021 at 2:10 PM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    just changed mine, it wasn't leaking but my lower idler pulley had the squeaks. 96K miles, I went ahead & also did thermostat, hoses, fresh coolant, idlers & tensioner.
    Amo-cat3 likes this.
  14. Mar 14, 2021 at 2:20 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    My pump started leaking out the weep hole at around 94k miles.
  15. Mar 14, 2021 at 3:16 PM
    Waasheem
    Waasheem
    2007 xrunner
    A coolant pressure tester isn't something everyone has in their toolbox. Mine could sit 2 years unused, then I'll use it 5 times in a month. Maybe you can rent one from an auto parts store. First I'd try a flashlight and mirror.
  16. Mar 14, 2021 at 3:20 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    I still have original water pump on the kids 08’ 4.0 with 405k on it :anonymous:
    Amo-cat3 and steelcity2 like this.
  17. Feb 16, 2023 at 5:55 PM
    wonderbread
    wonderbread Active Member
    Steven
    PNW
    08 Tacoma TRD 4.0 4x4 auto w Loc
    Bilstein 5100 adjustable w TRD Exhaust
    So did the leak end up being the water pump??
    Stemmy, the last pic you posted of the water pump removed looks just above where my leak is coming from and forming a slight puddle on the frame below the a/c condenser. Engine is dry from the valley down so thank goodness it doesn’t look like it’s the water pipe that runs through the valley above the knock sensors. The coolant seems to be running down the serpentine belt from the fan pulley area? I’m sure hoping it’s the water pump. Head gaskets look dry. Thanks for your help!
