Coolant bypass pipe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bws2, Jan 2, 2023.
  1. Jan 2, 2023 at 6:34 PM
    bws2
    bws2 [OP] Member
    William
    Washington state
    2007 Access Cab 2WD - 2.7L manual
    I have a 2007 Tacoma 2.7L manual transmission with 120,000 that I’ve owned it since it was new.
    Just found out about the plastic coolant bypass pipe. Trying to decide if I should replace it, or wait until I have a leak.
    Wondering if this job would be over my head, since I’ve only done fluid changes and spark plugs. It would be the biggest repair I’ve ever attempted.
    My questions are:
    Should I replace it now or wait?
    How difficult a job is this and what kind of tools would I need?
    Should I just have it done professionally?
    Black97v6MT, TRDSport10 and MarX like this.
  2. Jan 2, 2023 at 6:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It’s a lot more work than plugs.
    I’d probably do it myself, but I would not want to.
    I would say, you are probably capable.
    If you’ve never done more than plugs, it will definitely test your patience and be a learning experience.
    Or, of you feel more comfortable, and have the money, you could let someone else do it.
    Here is a video of the process
    https://youtu.be/etARn10c19Q
  3. Jan 2, 2023 at 8:22 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    OP, good luck with your repair. These 2.7 have great reputation for being so reliable. Interesting watching the vid the other member posted that Toyota was using plastic for their coolant bypass pipe back in 2005. On my 3rd gen 3.5 it has a plastic bypass y tube at the very back and difficult to get to that can be prone to leaking as well. Lol…. why Toyota, do you have to use plastic in these areas….
    Junkhead and MarX like this.
  4. Jan 2, 2023 at 9:06 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    In general if it ain’t broken, don’t fix it!!
    DesertRatliff, JmsWms, MarX and 2 others like this.
  5. Jan 3, 2023 at 7:14 PM
    bws2
    bws2 [OP] Member
    William
    Washington state
    Thank you for the response. Wow, after seeing the mechanic in this video work as hard as he did on this, I'm really questioning my ability to get this job done without messing something up.
    Part of me wants to challenge myself to do this, but being in my late 50s, it might be money well spent to have someone else do it.
    MarX likes this.
  6. Jan 3, 2023 at 7:23 PM
    TnShooter
    Deogee
    STOCK
    It not that you need any special skills to do it.
    It’s the work involved.
    That’s one of those jobs that require a lot more work than skill.
    Torspd, MarX and po35042 like this.
  7. Jan 3, 2023 at 7:51 PM
    lbaldwin22
    lbaldwin22 Active Member
    2006 Silver Access Cab
    Im at 220k miles and mine is just now starting to leak. Just a backyard mechanic myself and would attempt it but with limited time and space to work on my truck, I’ll most likely take it to my mechanic and let them handle it
    TreeFortRichard, TRDSport10 and MarX like this.
  8. Jan 4, 2023 at 1:32 PM
    TnShooter
    Deogee
    STOCK
    MarX, tacoman45 and Jimmyh like this.
  9. Jan 4, 2023 at 6:06 PM
    bws2
    bws2 [OP] Member
    William
    Washington state
    MarX likes this.
  10. Jan 4, 2023 at 6:25 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I would definitely replace it, if it’s leaking you can overheat and your temp gauge wouldn’t even notice it due to the location of the sensor. I paid a Toyota mechanic and he charged me a little over 300 in labor
  11. Jan 4, 2023 at 6:45 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Generally speaking, if there's an updated part available that addresses a known trouble area, I would absolutely replace it preemptively. It will only add value to the truck
    MarX likes this.
  12. Jan 10, 2023 at 5:50 PM
    bws2
    bws2 [OP] Member
    William
    Washington state
    Thanks everyone for the replies.
    One question, do I need to drain the radiator before starting this job?
    MarX likes this.
  13. Jan 10, 2023 at 6:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes, draining the rad straight into a bucket will make for less mess when the pipe comes off
    You could also look for a engine block drain too
    MarX likes this.
  14. Jan 10, 2023 at 6:46 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2012 SR5 4x4 ACab with Old Man Package, MT, 2.7L, Spruce Mica
    Camper Shell w/roof rack, Bed stiffeners, Step Bars
    I did mine, wasn't too bad if you take your time and watch some you tube videos on it beforehand.
    Replaced the water pump, fan clutch, coolant and thermostat while there, truck had almost 200k and figured it was time.
  15. Jun 12, 2023 at 4:46 PM
    bws2
    bws2 [OP] Member
    William
    Washington state
    Well I did it! Replaced the plastic coolant bypass pipe in my 2007 access cab.
    It was a bigger job than expected, but anything is a bigger job compared to the limited DIY I've done in the past.
    Took me about 12 hours (spread those hours over 3 days).
    Really had a fight getting the hose on the back of the intake manifold re-attached.
    Finally got the clamp to that hose in place with a small pair of channel lock pliers.
    I'm pretty sore today (from this 60 year old body contorting into the engine bay). And I have a real
    appreciation for mechanics that do this for a living.
    Thank you all for the encouragement a few months back. It's satisfying to do this job myself, and I got to know my truck a whole lot better.
    One question: I didn't replace the throttle body gasket because the one I bought didn't have the little metal screen in it like my old one.
    Do I need to go back in and replace it? If so is the gasket without the metal screen is okay to use or perhaps that part was superseded?
  16. Jun 12, 2023 at 7:20 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Bottom line: replace it, it will eventually crack at where it bolts at the front of the pipe.1
    It wasn't that hard...but if your unsure, by the stainless one and go to a mechanic. Should be about 1 hour to 1.5 hour labor.
  17. Jun 13, 2023 at 8:24 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I C U have a 2007 Access Cab 2WD - 2.7L manual - I have a 2008 Access Cab 2WD - 2.7L manual wi th 155K - how many miles on yours ? Was the leak bad ? Where did it leak from ? My brother in law's was leaking from the gasket by the firewall when he replaced it the actual pipe was fine - he has a 2.7 manual with 255K. Glad you got'er done. Thanks for any reply.
  18. Jun 13, 2023 at 12:04 PM
    bws2
    bws2 [OP] Member
    William
    Washington state
    Thank you George.
    I've got 120K on it. Luckily my pipe wasn't leaking yet and it looked to be in good shape.
    But I know it was just a matter of time and miles before it would have leaked.
    Very glad to have that beautiful stainless steel pipe installed!
    Black97v6MT and TRDSport10 like this.
  19. Jun 13, 2023 at 12:21 PM
    george3
    New Jersey
    So it was done as Preventative Maintenance - I was thinking of doing the same just need motivation for all the work - the pipe it self isn't that much but if you had to pay for labor it would be. Thanks for the reply
    kidthatsirish likes this.
  20. Jun 14, 2023 at 6:29 PM
    kidthatsirish
    I replaced mine at around 175-185k miles (I think... probably have to check my maintenance log. It had just started to crack at the end towards the front of the vehicle.
    While mine is a 4x4 it is otherwise similar. It took me a few hours to do mine....of course I have the advantage of being in my mid 30's. Reattaching the vacuum hose on the backside of the manifold between it and the firewall was definitely the hardest part.
    While some may elect to wait, it was a big enough issue that Toyota went back to a stainless steel line sometimes around 2009 I think. Food for thought.
    TRDSport10 likes this.
