Converting a ball hitch to a 2" receiver
Discussion in '1st Gen. Tacomas (1995-2004)' started by johnblackj, Aug 16, 2020.
  1. Aug 16, 2020 at 10:35 PM
    johnblackj
    johnblackj [OP] Member
    2000 Tacoma
    My 2000 Tacoma came with a bumper mounted ball hitch.
    I thinking of using a atv receiver like this one https://www.amazon.com/Adaptador-re...prefix=haul+master+rec,automotive,244&sr=1-20
    mounting it upside down so its under to bumper replacing the ball hitch.
    It would just be to use a bicycle rack that I have that carries two bikes.
    Do people think it would be secure? Is there anything to becarefull of with this? Or does anybody have better suggestions?
    Thanks
  2. Aug 16, 2020 at 11:11 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Check AutoZone or Uhaul and get an actual hitch.
  3. Aug 17, 2020 at 1:59 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It looks like from the picture which does not mean much the distance from the pin hole to the rear your bike rack might not fit depending on the distance to the rear of your male tube from the hole to the end.
    As long as the temptation never comes up to use it for anything else but your static bike load.
    Myself I would go with a real Hitch
    SR-71A and Rachelsdaddy like this.
  4. Aug 17, 2020 at 3:14 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    This would be better than the ATV adapter.
    https://www.amazon.com/Reese-Towpower-81378-Bumper-Receiver/dp/B0008F671S
  5. Aug 17, 2020 at 5:53 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Tullie D likes this.
  6. Aug 17, 2020 at 6:00 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  7. Aug 17, 2020 at 6:04 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    That seems like it might be prone to rotating. I don't like it. If you look around, you can get an actual hitch receiver for $100 or so and that would be far more durable.
    SR-71A likes this.
  8. Aug 17, 2020 at 9:04 AM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Just like everyone else on here stated go with an actual frame mounted hitch on your truck, thats what it was designed for OR heavy duty rear bumper with a 2" receiver.
  9. Aug 17, 2020 at 10:53 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    For the OP`s use to hold his Bicycle or 2 it will work.
    Downside don`t park the truck with the bikes any place you can`t leave the truck running for 30 minutes
    So very Easy to unbolt and walk away
    NikkoCharger likes this.
  10. Aug 17, 2020 at 12:06 PM
    johnblackj
    2000 Tacoma
    True, my rack is pretty secure but removing the whole thing wouldnt be impossible.
  11. Aug 17, 2020 at 12:09 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I mean, this isn't nearly as bad as that guy a while back that wanted to use an ATV winch on his Taco, but it's generally not a good idea to use atv accessories on your truck.
    Not only would this easily rotate unless you modify it, I'm betting this would bend your bumper. Ball hitches on bumpers don't do great at a torsional load, which is what you'd have with a bike rack or something. I also couldn't find any sort of rated weight limit on this thing. Even a bike rack with a couple bike on it would likely exceed the limits if mounted to an ATV.
    Just spend the $130 on a hidden hitch or similar.
    https://www.amazon.com/s?k=hidden+h...hitch,automotive,216&ref=nb_sb_ss_ac-o-p_2_12
  12. Aug 17, 2020 at 12:15 PM
    johnblackj
    2000 Tacoma
    Full hidden hitch it is then.
    Thanks for the advice
