Contractor Shell Compatibility Question
Discussion in 'Tonneau Covers, Caps and Shells' started by bkress37, Jan 9, 2024.
  1. Jan 9, 2024 at 8:50 AM
    bkress37
    bkress37 [OP] Well-Known Member
    Brady
    Hey all,
    I know the 2nd gen / 3rd gen camper shell compatibility questions have been asked on this forum to no end.. but here I am with another.
    Looking at a "contractor" shell from a 2nd gen tacoma. Aluminum, A.R.E shell that requires you to remove the tailgate. Thinking this would fit me 3rd gen just fine, correct?
    Seems like the biggest issue with fitment comes with the 2nd gen tailgate being shaped differently then the 3rd gen tailgate. But If the tailgate is being removed, then it should fit fine?
    Shell like the photo below:
    Tacman19 likes this.
  2. Jan 10, 2024 at 7:00 AM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Almost all trucks taper from cab to gate.
    You'll need a tape measure and be really good with it. LOL
    Zim
  3. Jan 10, 2024 at 7:40 AM
    545 Well-Known Member
    2015 Access Cab
    Nope, 3rd gen bedsides are about 1 inch higher
    You’d have a gap under the rear door
    could you make it work? Probably, but it’s not gonna fit right without doing something
    SH10151 likes this.
  4. Jan 16, 2024 at 8:05 AM
    bkress37
    Brady
    Got it, thanks for the responses everyone.
  5. Feb 5, 2024 at 4:45 PM
    Max8
    Max8 Thinking Outside The Box until they close the lid
    23 SR5 DCLB stock
    2012 ARE DCU contractor cap pending- Transmission aftercooler kit (Iconic Fabrication & Hayden 698) pending - Bed Stiffeners (Kwikfab LLC) Firestone airbag leaf springs, wye connector and pressure gauge Tailgate security mod (mfgr. by Christian06 on TW) OEM mud flaps OEM tailgate electronic lock Tow-Pro Elite Electric Brake Controller Anytime Backup Camera hardwired 42 ft to camper RCI Alum. Skid plates & cat covers 2WD LO mod (BB Tuning) Fumoto oil drain ECT Always-On Mod (hardness by Funman1steve) 6awg DC DC tow charger wiring, inline 60 amp breakers & battery terminals Kill switch KJTO driver side grab handle Hood hold open gas struts Scangauge III Seat Covers (Seat Covers Unlimited... wearing poorly) locking gas cap
    I've had three used ARE DCU contractor work caps over the years, none a perfect fit. The side doors are a lifesaver for grabbing tools and reaching tiedowns.
    If you are handy it's not hard to stainless pop rivet square aluminum tubing to close in tailgate or door gap. Have done both and finished with EPDM tape. Have replaced entire dual door panel with swing up tailgate panel as well. Two bolts and it hinges up and slides laterally out.
    I don't like the scant four thin machine screws mounted to the tacoma siderails.
    Shear a screw with a load of lumber on top and the cap could come loose.
    Twice now I've supplemented the dcu aluminum flatstock mounts with one more ea side and one more centered in front. Welded flatstock to dcu frame.
    Prior to the newer tacoma siderail mount system, I ran 1/4x4 aluminum flatstock** all around top of bed, glued and stainless screwed to top of bedsides. This gave me a level surface to clamp cap to with removable clamps.
    Cretins have tried to force the locking door handles at least twice. They are cast and thankfully broke. Older replacements unavailable so drilled out center rod they mount on to accept a brass sacrificial throughbolt securing noname handles.... and now carry a spare.
    The 1 inch square tube lumber rack stock is thin crap and I've rewelded broken welds all over and welded in gussets plates. Same at rear panel upper corners above door.
    Hope there's some useful info here if you consider adapting a good deal.
    **important to isolate against bimetallic reactions!
  6. May 3, 2024 at 7:11 PM
    demo243
    demo243 Well-Known Member
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    @bkress37 any chance you made any more progress on this?
    actually looking at doing the opposite right now- putting a 3rd gen cap with dual doors on a 2nd gen. Just having a hard time finding fitment or an overall length for the 2nd gen cap.
