Constant Power Cable Vehicle's OBD-II Port
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrWortWort, Feb 24, 2023.
  1. Feb 24, 2023 at 12:37 PM
    MrWortWort
    MrWortWort [OP] Well-Known Member
    2021 SR Access Cab Tacoma
    I saw theses on forums I was wondering if anyone use one on their Tacoma
    They have mix reviews either it good, it drain the battery or worst it mess up the car's computer setting off all the warning lights
    Not sure it base on specific make and model or it just pure bad luck
    https://www.amazon.com/Garmin-Const...&pd_rd_r=59d78bdd-fa00-470b-9951-f355aaf7621c
    https://www.amazon.com/dp/B0B3B6WSPR/?coliid=I1GOFJPVIIHCCX&colid=M4ORGOHFDFWD
  2. Feb 24, 2023 at 12:45 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I'd be impressed if it managed to cause warning lights, but I don't know how it's wired. If you're concerned, I'd suggest just using an Add-A-Fuse on a circuit that's still energized while on battery. But, it sounds like you're not too comfortable with wiring electronics if you're looking to purchase something like this. If that's the case, and I apologize if it isn't, maybe someone local to you can help out, otherwise, a shop will gladly help you out.
  3. Feb 24, 2023 at 1:48 PM
    MrWortWort
    I was hoping to a find a easy way to hardwire a dashcam without messing the fuse box.
    I mostly concern since new cars are very sensitive due to their computer parts possibly getting ruin
    I would go to a shop but they charge too high for the installation
    I understand its business
    Unless they're price include their own dashcam and wire kit, I cant agree with the price
  4. Feb 24, 2023 at 2:54 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Well, there is a wire going to the rearview mirror that is on battery and always has power.
    Chew likes this.
  5. Feb 27, 2023 at 11:07 AM
    Fuspo
    Fuspo Active Member
    AZ
    22 Tacoma TRDOR
  6. Feb 27, 2023 at 1:02 PM
    MrWortWort
  7. Feb 27, 2023 at 1:07 PM
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    You'll be fine. I've hard-wired a dashcam into two vehicles (Highlander & Tacoma) and its quick and simple.
  8. Feb 27, 2023 at 1:08 PM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    Add a fuse. Works well
  9. Feb 27, 2023 at 2:44 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    I'm not sure if it has been confirmed or not, but maybe the connector is tucked inside of the headliner?
