Consensus on first oil change? Toyota says 10,000 miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dxironman, Sep 11, 2021.
  1. Sep 11, 2021 at 7:38 AM
    Dxironman
    Dxironman [OP] Well-Known Member
    Central Florida
    21 TRD Sport
    I’ve seen a lot of recommendations to change your oil at 1,500 miles or 5,000 miles but Toyota says 10,000. Is there any consensus on this? If I do it before the recommended Toyota mileage at a quick lube place will it affect the warranty?
  2. Sep 11, 2021 at 7:40 AM
    Bishop84
    Bishop84 Well-Known Member
    No need to do it early, if you have hard conditions do it every 5000 otherwise 10,000 is fine.
    I used to do the first change early but modern engines have good quality oil from factory and there's no need for concern.
    willie2, Skydvrr and Kev250R like this.
  3. Sep 11, 2021 at 7:42 AM
    Clearwater Bill
    Billy
    Largo Florida
    No
    No. (Plus how would they even know?)
    But it would be tough times before I darkened the door of a quick lube place.
    skeletron, usmc2msu, barf and 4 others like this.
  4. Sep 11, 2021 at 7:44 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Do what you want. I do my oil change and tire rotation every 5k miles.
    LDS 77, grogorat and shakerhood like this.
  5. Sep 11, 2021 at 7:48 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Seriously it's your truck so change it at 1,500, 5,000 or whatever would make you happy. Enjoy your Tacoma, these are great trucks!
  6. Sep 11, 2021 at 7:56 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Just don't exceed 10K miles between oil changes and you will be fine. Otherwise, it's kind of up to you if you feel you want to do it more often than what is recommended. When I was a young driver, the standard was every 3,000 miles. But tribology (science of lubrication) and engine designs have some a long way since then and 10K appears to be the norm these days with new cars using synthetic oil.
  7. Sep 11, 2021 at 7:57 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    if the warranty issue is serious, they will ask for proof you maintained per schedule. keeping your receipts should
    be good enough, though it does not prove you actually did the change, just that you were prepared to.
  8. Sep 11, 2021 at 7:58 AM
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
    No consensus. Lots of strong opinions. Some people do 500 miles, since 10,000 miles. I did 10,000.
  9. Sep 11, 2021 at 7:58 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I just do what the manual says, I figure Toyota knows best lol plus if it’s a new truck the first two years of service is free from Toyota.
    NorrinRadd and Knute like this.
  10. Sep 11, 2021 at 8:06 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I did my first one at 5K. Will probably do 10K or annual changes from now on.
    BTW Your ‘Maintenance Required’ message will come-on every 5K Miles regardless of how you use your truck.
  11. Sep 11, 2021 at 8:10 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Yeah when that light first came on it freaked me out haha, then I realized it’s just a mileage setting.
    It’s probably a well known fact but just because it’s not the same as older cars, it may be worth saying: when you take it in for the 5,000 service they do not change the oil. They told me people get all bent out of shape about that because they expect the oil to be changed at every service but our trucks only need it every 10K.
    That was news to me when I first got my Taco because it’s been almost 10 years since I bought a vehicle.
    Kev250R[QUOTED] likes this.
  12. Sep 11, 2021 at 8:13 AM
    Jurist
    Jurist Active Member
    Tom
    2021 TRD Offroad 3.5 M/T
    I have done a 1500 mile change on all my new vehicles. I have gotten 240,000 + miles on them.
    All the points others have made are valid for sure. But I am a what if'r.
    There are reasons that they tell you rev limits and speed limits and not driving constant speed and towing on new engines.
    The parts are meshing. That means that very fine bits of metal are being worn off, the rings are seating and other stuff. This is then washed by the oil away, and hopefully captured in the filter.
    It cost me $75 to do the change myself and took about 20 min. Used amsoil. I also change the rear diff and the M/T fluid. Since they are breaking in also and they don't have filters. I have notices when guys get re-geared that the manufactures recommend that you replace the diff fluid at 500 miles, why? because the metal parts are meshing and this is the time of greatest wear. Now those micro fragments of metal are in the oil to act like an abrasive.
    Call me paranoid, these trucks are great and to expensive not to do the simple stuff like change the fluids to keep the wear to a minimum.
    $.02
  13. Sep 11, 2021 at 8:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    While true, that wasn't his question. His question was re warranty because of a short/early OCI, as in
    So my answer and question
    Still stands.
    There is no warranty issue for short/early OCIs
    shakerhood likes this.
  14. Sep 11, 2021 at 8:16 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Dealer told me to get it in there at 4,000 then 10,000 then 10,000 thereafter.
    I'll try to get it in around 4-5,000 and I'll change it out every 5,000-7,000.
    It's hot-as-hell in Phoenix so regardless of mileage I'll do it early June every year.
  15. Sep 11, 2021 at 8:21 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    The only time it will affect your warranty is if you don't do the service at least at the intervals in the Toyota maintenance schedule. If you don't do it at the dealer then keep your receipts. You won't get hurt warranty-wise for doing it more often/earlier than Toyota wants. If you're looking for consensus on oil change intervals here, forget it. Everyone has their own opinion, one just as valid as the other. That said, the last place I would do an oil change is at one of those quick lube places.
  16. Sep 11, 2021 at 8:22 AM
    clock11
    clock11 Well-Known Member
    Aaron
    Southern California
    2020 White TRD Off Road
    Deaver Stage III, Icon Stage 3 (minus Icon leafs), BFG K02s, Prinsu roof rack, Diamondback HD, CaliRaised Ditch lights and Brackets, Clazzio Seat Covers, Rearseat 12v Power & USB, Bed cubby 12v Power & USB, Interior LED bulbs, Toyota OEM tailgate lock.
    I am doing mine every 5k, however my personal experience has been not good with quick lube type places. I have learned not to trust them. My advice is if you want to do short intervals and have the means and ability, do it yourself at home. If not, I would just go to the dealer every 10k as suggested by toyota. In other words, 5k change at home, 10k change at dealer, 15k at home, 20k dealer...
    MAD777 likes this.
  17. Sep 11, 2021 at 8:29 AM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Don’t say quick lube to me. Crawl under it and do it yourself :thumbsup:
    zoo truck, clock11 and Jurist like this.
  18. Sep 11, 2021 at 8:37 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    First oil change at 5k miles...10k miles after. If it makes you happier at every 5k, thats ok to.
    I used change my oil and filter every 20k miles or so in my tundra. It was still running perfect at 292k miles. Imo, changing synthetic oil at 5k miles is a total waste of money, and resources.
  19. Sep 11, 2021 at 8:40 AM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    Google "tacoma maintenance schedule" and its all on there, every 8000km (I think 5000 miles?) they recommend you take it in for an oil change/service.
  20. Sep 11, 2021 at 8:52 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Yes they do but they don't change the oil every 5,000 miles. It's on every other service. First 5,000 mile service is a tire rotation, 10,000 miles oil change and tire rotation, etc.
    zoo truck, barf and Road_Warrior like this.
