Confused about Factory Specs on 2001 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by benkenobi2, Jun 3, 2020.
  1. Jun 3, 2020 at 7:51 PM
    benkenobi2
    benkenobi2 [OP] Member
    2001 White Tacoma Double Cab
    None.
    Hello everyone. I have a 1st gen Tacoma - 2001 Double Cab. I just purchased it and I like it a lot. My brother in law has a 96' that is lower to the ground. I am new to Tacomas so I did not know Toyota had a 16" wheel/tire and lifted version. I am also no mechanic and for the past two days, I have been trying to figure out what trim I have. I'll prob get flamed for my ignorance lol.
    With the help of someone on the introduction section of TW, I was referred to Toyota Owners and they gave me the factory specs on my Tacoma. I have attached pictures of the specs below.
    I am confused because the grade of my Tacoma is "standard". If you look below at standard installation equipment you will see that it has a 2.7 engine.. etc but it states that it comes w/ 15" wheels/tires.
    Above the box, in port/factory installed equipment, I see that my Tacoma had a
    • AA WHEEL AND TIRE UPGRADE #2.
    I am not sure what AA Wheel and Tire Upgrade means and cannot find any detail on it.
    Does this mean that Toyota upgraded the 15 inch wheels to 16 or is it possible that one of the two original owners of this vehicle did some modification to this Tacoma.
    I am really hoping the lift and wheels are all FACTORY stock.
    The one on it right now are toyota wheels and 16 inch tires on it. I also notice on the side of the door there is a decal that states that it can run both 15 and 16.
    This car has both sr5 and prerunner decals on it. :XScreenshot 2020-06-03 at 10.49.43 PM.jpg
  2. Jun 3, 2020 at 8:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Easy
    You have an SR5
    You also have the added TRD Package (it's an option)
    You have factory wheels and judging from the stance, factory height
    A Prerunner is everything a 4x4 is, but without the 4x4 meaning no front differential, no transfer case, no axles, and different wheel hubs. Everything else is the same though.
  3. Jun 3, 2020 at 8:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @benkenobi2
    Confirm that there is a button to the left of your steering column
    That'd be for the rear locker if indeed you have the TRD package; some people just slap the decal on their trucks
    benkenobi2[OP] likes this.
  4. Jun 3, 2020 at 8:14 PM
    benkenobi2
    None.
    Negative, no RR Diff Lock. I figure it wasn't a true TRD. There seems to be a lot of variations so I am just more concerned whether or not I have a factory lifted and 16" inch stock wheel version or if this was converted by a previous owner.
    GQ7227 likes this.
  5. Jun 3, 2020 at 8:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There is no such thing as "factory lifted"
    It's either factory, or it's lifted
    The only difference in height with 1st gen Tacomas will stem from the fact that it's either a 6 lug (which is a 4x4 or Prerunner) or a 5 lug (which has different suspension altogether including spring under rear axle)
    You could just easily look at the suspension of your own truck; we don't have your truck in front of us
    Factory Bilstein 4600's were yellow with a blue boot; if the previous owner replaced them (which they should have, these trucks are so old), hopefully he/she used the same type. If they are not what I described, I'm sure they're "factory replacement" specials from autozone/napa/etc.
    If your truck was lifted, whether it was a quality suspension lift or a cheap block kit, you'd be able to see it right away if you walked up to your truck.
  6. Jun 3, 2020 at 8:19 PM
    benkenobi2
    None.
    Ah thank you for the information. So the configuration that my Tacoma is in now with the 16 inch wheels and tires and the higher clearance is factory? It does have the 6 lug wheels but doesn't state on the specs if it was a prerunner.
  7. Jun 3, 2020 at 8:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The higher clearance is due to the fact that both a Prerunner, and a 4x4 model, share the same suspension
    The designation "Prerunner" is as I described earlier; a 4x4 model but without the 4x4 powertrain components
    GQ7227 likes this.
  8. Jun 3, 2020 at 8:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @benkenobi2
    Just realized in looking at your tiny screenshot that you have a 4 cylinder; you very well have the TRD package
    You just don't have the locking differential as it was included with the 6 cylinder model
    benkenobi2[OP] and cruiserguy like this.
  9. Jun 3, 2020 at 8:29 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I think that's how I understood the differences too. Not many of those, that's for sure.
  10. Jun 3, 2020 at 8:35 PM
    benkenobi2
    None.
    I thought I read somewhere that the TRD package only came on manual transmission Tacomas? Mine is automatic so I just figure someone put a decal on it.
  11. Jun 3, 2020 at 8:39 PM
    cruiserguy
    Elijah
    SEKS
    Yeah, could be that as well, now that I think about it. Someone else here had a plain 4 cyl auto 4x2 double cab, wasn't technically a prerunner but had that suspension. I think he was on 15s too. So it might have been 15s stock.
    Does your odometer seem off? Can you verify it?
  12. Jun 3, 2020 at 8:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    A 4 cylinder automatic TRD truck with locking differential was not available to the public, but that's not to say it doesn't exist.
    Being in the car business, being the right person, and talking to the other right person, you can make shit happen as a one or two off special order.
    We had 1 of 4 or so Viper GTS with a factory 7 stage paint job.
    The paint job was a $15k add-on on the factory window sticker.
    GQ7227 likes this.
  13. Jun 3, 2020 at 8:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No, TRD was available on manual and automatic so don't let misinformation confuse you.
    The picture of the locker I posted is of my own truck, and it's an automatic.
    Also, all double cabs were automatic.
  14. Jun 3, 2020 at 8:43 PM
    cruiserguy
    Elijah
    SEKS
    Look what color the shock body is on the fronts and on the rear, that will help us tell you a little more as well
  15. Jun 3, 2020 at 8:45 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    Not many last of the line SR5 taco either
    In a year and half on tw I can only account for maybe 4 or 5 at best!
    And it may be as few as 3
  16. Jun 3, 2020 at 8:51 PM
    benkenobi2
    None.
    Your knowledge on Tacomas is quite impressive. :D
    They are blue shocks.
    I tried a simple google image search to see if any Tacomas matched my description and I couldn't find one that was identical to it in specs. That is why I figure someone threw on the TRD decals.
    GQ7227[QUOTED] likes this.
  17. Jun 3, 2020 at 8:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Far from it, but thanks :rofl:
    If you shined a flash light I bet they're Tokico
    Too many Tacoma's out in the real world, and since a lot of them that don't make it are parted out for good money, a lot of trucks won't be "true factory spec"
    Plenty of people convert their Prerunners into 4x4, plenty have swapped out their automatic from their double cab and went stick shift, and some have even gone from ADD to manual locking hubs.
  18. Jun 3, 2020 at 9:08 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Although these weren't the droids you were looking for, I hope the answers were :anonymous:
    GQ7227 and benkenobi2[OP] like this.
  19. Jun 3, 2020 at 9:09 PM
    benkenobi2
    None.
    I honestly got this truck for my mother. She was actually the one who spotted it and figure we could use a light utility vehicle. My plans are to check out the compression of the engine and things of that nature and leave a reliable truck for her before I ship off.
    I'll check again tomorrow if they say Tokico but I think you are right!
    So from the horse's mouth I can tell my family and friends I have a TRD Prerunner? :D
  20. Jun 3, 2020 at 9:11 PM
    benkenobi2
    None.
    Just noticed the Eagle, globe, and anchor on your signature. That is awesome! I am actually a poolee. :D
    The information I have received is very helpful. I feel a bit more confident in my purchase so thank you for the ease of mind :D
    Kwikvette[QUOTED] likes this.
