Concrete core bit info needed
Discussion in 'Garage / Workshop' started by surfsupl, Jan 27, 2014.
  1. Jan 27, 2014 at 11:05 PM
    surfsupl
    surfsupl [OP] Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I need to punch a 3" hole in a concrete pad. No re-bar. I have been looking @ Bosch core bits. Anyone use this brand bit and had success? Or another brand you may have used?
    Thanks
  2. Jan 28, 2014 at 3:57 AM
    gearcruncher
    Canadain bumper technician
    Rent the machine for the day . They have a base fee for the drill and a wear cost for the diamond drill bit . I beleive they measure the wear surface beforte you rent it and measure again when you bring it back . If you only have 1 hole to drill and use the lubricator properly , shouldnt cost more than $30 bucks . If you had to purchase the bit , I beleive they run about $200 bucks
  3. Jan 28, 2014 at 7:31 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Definitely price rent vs buy
  4. Jan 28, 2014 at 7:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, rent one of the upright machines, it will make your life a lot easier. They have a connection for a hose so you can keep water running inside the bit while you run it (you can run the dry also but it chews up the bits a lot more, takes longer and creates a lot of dust, best to use the water if you can). If water is a concern, just have a shop vac handy.
    We also have places like Pro Cut around us that will come in and knock that out. Including setup and tear down time, a hole that sized through a standard 4 or 6" slab with no rebar would only take about an hour tops.
    The bits can be expensive, but if you shop around you can find them as cheap as $50. For one time use and no rebar, you'll be fine with a cheaper bit. You want the more expensive bits when you know you'll be cutting rebar. In general, I've had decent luck with Bosch products although I've never used their core bits for concrete.
  5. Jan 29, 2014 at 6:22 PM
    surfsupl
    Gregg
    WestCoast
    I need to add an additional drain on a back patio.
  6. Jan 29, 2014 at 6:22 PM
    surfsupl
    Gregg
    WestCoast
    Thanks for your reply's
