Compressing caliper pistons, changing piston boots.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mooty311, Nov 6, 2024.
  1. Nov 6, 2024 at 8:13 AM
    mooty311
    mooty311 [OP] Member
    I was trying to change my front brake pads and had difficulty compressing the pistons so I could fit the pads in. I ended up tearing a piston boot in the process.
    I have a couple of questions.
    1st, does anyone know of an easy way to compress the pistons? When I pushed one piston in, the other one would pop out. I ended up pushing one piston in and inserting half of the brake pad while I pushed the other piston in. Just seems like there should be an easier way.
    2nd, I ordered a caliper seal kit from Toyota. Can I change the piston boots without taking the whole thing apart?
  2. Nov 6, 2024 at 8:29 AM
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    Take the worn out brake pad to use to push both the pistons back in at the same time. You can not press one at a time. This will push the other piston out as you have found out..To push the pistons back in, use a big pair of caliper vise grips. this works great.. To put the piston seal kit back in you will need to pop the piston that was pushed to far out completely out. To put the new seal kit back in, 1 seal & 1 dust dust boot.. Then fill system with fluid & purge all the air. To pop the one piston out block off the good piston with a piece of wood and then use some compressed air on the open bleeder screw or supply hose this will push the piston out .. Do not use a lot of air pressure,,,just enough to push it out.
    Note: If ever you can not push the piston back in with normal pressure, the caliper should be replaced or rebuilt.
    Koolbreeze7 likes this.
  3. Nov 6, 2024 at 8:37 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    My favorite way is to push them back with the bleeder open. Since the worst fluid is usually in the caliper, it really helps with the bleed process. Beyond that, you can do it with just hand pressure for most calipers.
    Barsoom likes this.
  4. Nov 6, 2024 at 9:02 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    And Harbor freight has a nice brake caliper set, if pistons do not go back easily: I also open bleeder screws when pushing the pistons in, to get old, more likely to be overheated, fluid out. Also, in my experience, pushing pistons in, by hand, without bleeder screws open is very, very hard, since piston is pushing back against the un-compressible brake fluid.
    PS I have this kit, since it covers all possible makes, models and caliper sizes. I've used it on 6 different brands (Japanese, Korean, US), and it had matching pads for all.
    tonered[QUOTED] likes this.
  5. Nov 6, 2024 at 9:12 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good stuff.
    The one that really messed me up was a combo caliper with parking brake. Screwing it in while pressing was . . . fun.
    Barsoom[QUOTED] likes this.
  6. Nov 6, 2024 at 9:19 AM
    Barsoom
    NW GA OTP
    My Kia had one of those. That's then I bought the kit. Front of the piston was smooth, except for for 2 notches at 3 and 9 o'clock. I could not push that piston in to save my life, and trying to turn the piston, while pushing it, was worse than catching a greased pig. I put old brake pads on, after fighting with one caliper fr 2 hours and ordered the kit via mail (no Harbor Freight in Alaska). A week later I did both wheels in less than an hour, with the kit.
    Kit had a plate that matched Kia's piston perfectly.
    Second kit has two pushers, left and right hand threaded (labeled LH and RH), so it will work on all screw in and push in pistons.
  7. Nov 6, 2024 at 9:33 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. It was on a Mazda 3. I got them with some old needle nose pliers. Haha!
    Never even expected an issue before jumping in. I sure do like these combo calipers, but that little issue did trip me up.
  8. Nov 8, 2024 at 4:47 AM
    stoney1911
    stoney1911 Professional Idiot
    Phoenix, AZ
    2019 TRD OR DCSB
  9. Nov 8, 2024 at 8:09 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
  10. Nov 8, 2024 at 4:51 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
  11. Dec 3, 2024 at 12:55 AM
    Smithmystery
    Smithmystery Active Member
    Texas
    2020 Army Green TRD Pro
    I use the Quad pad. It makes life a lot easier.
