Compatible tire sizes with 17 TRD PRO 4Runner Wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTurboMan, Feb 21, 2020.
  1. Feb 21, 2020 at 11:25 AM
    TacoTurboMan
    TacoTurboMan [OP] Well-Known Member
    San Jose, CA
    19 Super White TRD PRO
    I need some clarification on whether BFG KO2 at 285/70/17 will fit the 4runner trd pro wheels safely.
    Reason I ask is because the wheels are 7" wide while the 285's require a 7.5"-9" wide wheel. But I've seen some people running these sizes anyway. Some say it's not recommended..but no one can really explain to me why lol
  2. Feb 21, 2020 at 11:42 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    A guy I work with has been running that set up on his FJ. And he hasn't had any issues, outside the normal rub mods needed for that size tire.
  3. Feb 21, 2020 at 1:19 PM
    SitrucR
    SitrucR Well-Known Member
    Denver
    2019 OR DCSB 6MT
    OME/Dakar
    I’ve run 285’s on every 7” wide Tacoma wheel I’ve had. Having a set of 285/75r17’s installed on 4R Pro wheels right now.
    Llcoolben likes this.
  4. Mar 19, 2020 at 11:02 AM
    Llcoolben
    Llcoolben Member
    Ben
    2019 Tacoma DCOR
    How is that working for you? What lift and mods to accommodate that size? I plan on using the same wheels as you. I keep searching for this size and would prefer this size if possible instead of the 285/70/17.
  5. Mar 19, 2020 at 2:42 PM
    awynne56
    awynne56 Well-Known Member
    Andy
    2019 Taco trd sport
    front grill pro
    Yes I have them now. No issues
  6. Mar 19, 2020 at 2:46 PM
    awynne56
    Andy
    2019 Taco trd sport
    front grill pro
    No rub even on mud flaps
  7. Mar 19, 2020 at 2:56 PM
    Llcoolben
    Llcoolben Member
    Ben
    2019 Tacoma DCOR
    those look like LT285/70R17s and I see you have an aftermarket control arm. I was trying to go LT285/75r17s without needing an aftermarket control arm for now.
  8. Mar 19, 2020 at 3:23 PM
    awynne56
    Andy
    2019 Taco trd sport
    front grill pro
    Depending on your lift you might need ucas to get it aligned right
    yes your right. 285/70/17 sorry
  9. Mar 19, 2020 at 5:18 PM
    SitrucR
    Denver
    2019 OR DCSB 6MT
    OME/Dakar
    minor plastic trimming, alignment with caster as far forward as spec allows for stock UCA’s, and a body mount chop.
    lifted on OME 887’s, nitrochargers front and rear, Dakar Medium leaf pack. Spidertrax.
    didn’t need plastic trimming or body mount chop with 285/75R16’s on the original wheels.
