Compatibility of 4Runner TRD Pro Wheels PTR-20-35510-BK on 2024 Tacoma?
Discussion in '4th Gen. Tacomas (2024+)' started by Clayton4x4, Dec 19, 2024.
  1. Dec 19, 2024 at 5:01 PM
    Clayton4x4
    Clayton4x4 [OP] Well-Known Member
    2024 DCLB TRD Off Road
    I thought I saw a thread of people putting these wheels on their 2024, but can't find it. So if you have the link for it, please point me to that.
    I took these off my 2015 Tacoma, and the service center couldn't tell me if they're compatible with my 2024. They also quoted me a price of $295 to program the TPMS in them.
    Kolter45 likes this.
  2. Dec 19, 2024 at 5:08 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    The wheels will fit, but you need new lugs, and a center hub spacer.
    I read the 2024 is smart enough that you can get the truck to recognize two sets of sensors. Summer and winter. It should recognize the sensors from your 2015. Takes 30+ miles to get them set.
    Instructions in the owners guide around page 540.
    More info at Do you have a Discount Tire nearby?
  3. Dec 20, 2024 at 9:26 PM
    Clayton4x4
    Thanks for the info!
  4. Feb 6, 2025 at 6:33 PM
    Clayton4x4
    They turned out great with the Rave Off Road lug nuts. Coincidentally they were put on the same day Toyota sent a recall on the 17” OEM Off Road wheels, which I put in storage and will deal with tomorrow. 265/70/17 Nitto Ridge Grapplers on them.
    JoeMongo, Kolter45 and Theeangelow like this.
  5. Feb 7, 2025 at 10:29 AM
    TheDanimal
    TheDanimal Well-Known Member
    Daniel
    DFW
    2024 Silver TRD OR 6MT 2019 MBM TRD OR 6MT (RIP)
    Are those OEM or Replicas? I thought the offset was too much for the 4th gen on the OEM wheels. How much poke did you get?
  6. Feb 7, 2025 at 7:28 PM
    Clayton4x4
    They’re OEM. They do stick out a bit
  7. Feb 14, 2025 at 4:05 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    What spacers and lugs did you need to get?
  8. Feb 14, 2025 at 3:00 PM
    Clayton4x4
    TrdSurgie[QUOTED] likes this.
  9. Feb 14, 2025 at 4:28 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Any issues swapping the 4th gen tpms into the sema wheels?
  10. Feb 14, 2025 at 7:07 PM
    Clayton4x4
    At first my shop just replaced the 2 sensors whose batteries had died, and he thought everything was programmed correctly, but the tire pressure warning light was on and the pressure values didn’t update on the guage cluster. I figured I’d drive it over the weekend to see if it would update, but it didn’t.
    So I brought it back, and that’s when he found out the other 3 weren’t compatible and he ordered replacements. So Thursday I’ll know for sure when he puts them in and programs them. He didn’t indicate any issues with installing the tpms, but I’ll update this thread on Thursday
    Interesting enough the “Setting wheel position while driving” is now displaying. Also I don’t remember there being a pressure value slot for the spare until now.
  11. Feb 14, 2025 at 11:12 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Thanks for sharing. Interesting about the other 3 not being compatible but 1 was?
  12. Feb 15, 2025 at 1:14 AM
    Clayton4x4
    5 because I have a matching spare
    The originals are from 2015 and the battery died on 2 of them, so they are new sensors
    He had to order more sensors to replace the other 3
  13. Feb 15, 2025 at 8:51 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    It was my understanding that the hub bore was different between the generations...how did the tire shop account for that?
  14. Feb 15, 2025 at 9:03 AM
    CrispyTacoLover
    Hub ring to take it from 106 to 95. Assuming of course they did that.
  15. Feb 15, 2025 at 9:14 AM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Doesn't sound like they did. OP stated they just used different lug nuts.
  16. Feb 15, 2025 at 9:46 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    That doesn't sound…safe.
  17. Feb 16, 2025 at 10:36 AM
    Clayton4x4
    Where are you getting this information?
  18. Feb 16, 2025 at 11:00 AM
    CrispyTacoLover
    Look up the specs on your wheels. The center bore is designed for gen 2 and gen 3 Tacomas at 106.1mm.
    The 2024+ Gen 4 Tacoma and 2025 4Runner has a wheel hub center bore of 95.1mm.
    Older wheels can go on the new Tacoma, but the 4gen wheels will not go on older gen Tacomas.
    In your case, a hub spacer should have been installed to take it from 106 down to 95.
    Do some searches and you’ll see all of the discussions on this.
  19. Feb 16, 2025 at 11:42 AM
    Clayton4x4
    Thanks I’ll research this and get them in time for Thursday
  20. Feb 19, 2025 at 11:29 AM
    Clayton4x4
    So I got these spacers, and they specifically mention a safe OEM ride. I’m pushing back the appointment to get the replacement TPMS installed until after these come in.
