Common Issues in New Tacomas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shotgunshooter3, Jul 27, 2013.
  1. Jul 27, 2013 at 9:36 AM
    shotgunshooter3
    shotgunshooter3 [OP] Well-Known Member
    Somewhere in the Southwest
    14 DCSB 4x4 SR5 Blue Ribbon Metallic
    Icon Stage 4 @ +1, RCI Skid Plates, All Pro Offroad Rock Sliders, Leer 100R, Skewped hood
    Howdy folks. As a few of my recent posts probably indicate, I'm considering a new Tacoma for my next vehicle and am trying to learn as much as possible.
    I am wondering what problems seem to be common in newer Tacomas. Ideally I want a truck that gives me a good chance of zero issues beyond normal maintenance, because I plan to spend the extra money to get exactly what I want and drive it until the wheels fall off.
    So what issues beyond normal maintenance seem to be trending in new V6 4x4 Tacomas? Are they serious enough to sway me to the Nissan Frontier (locking tailgate, Utili-track system, and the fact that the 2013 is comparable to the Tacoma for creature comforts has my attention)?
    Thanks in advance!
  2. Jul 27, 2013 at 9:37 AM
    Jux
    Jux :D
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
    There will probably be a whistling noise caused by the windshield or grill.
  3. Jul 27, 2013 at 9:46 AM
    joeyha
    joeyha Well-Known Member
    Joey
    Canmore
    12 DCLB TRD
    This^
    And also my leaf springs squeek when going over small bumps. I have a 12 DCLB Sport.
  4. Jul 27, 2013 at 9:52 AM
    Greenpants
    Greenpants Well-Known Member
    Massachusetts
    2009 4x4 Tacoma 4 banger
    The tailgate mod
    I have had 2 Tacomas over the last 18 years. Bought them both new .NO issues at all . Go with the Toyota Tacoma ! You will be very happy.
    greenpants....mike
  5. Jul 27, 2013 at 9:57 AM
    rickrock
    rickrock Beer.
    Quebec, Canada
    13 TRD Sport DCLB
    Tail gate lock, Tri-fold, Hood deflector
    I checked at the Nissan Frontier myself before buying my Tacoma. And I heard bad stuff around Nissan's, and bad reviews...
    For the locking tailgate, I had my dealer install a Pop & Lock as part of the deal. With the rear camera it looks like its right from Toyota, except the locking barrel doesn't seem top quality.
    You could search the forum for TSB's. You won't find a lot for 2013, but you'll fin plenty of info for the 2012 :typing:.
    Good searching, you are the right place!
  6. Jul 27, 2013 at 10:03 AM
    slaphappy
    slaphappy Mama didn't raise no fool
    Travis
    River Valley
    Silver Fresco 2010 FJ Cruiser 4WD
    Frontier's aren't even on the same planet as Tacoma's... my 2 cents
  7. Jul 27, 2013 at 10:06 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Had mine for 2 years. Only been in the dealership once. Line going to the a/c condenser was barely leaking. Only issue I have with mine is the blower motor "chirp" every once in a while when the fan is set to medium. I'm just too lazy to fix it and it doesn't do it all the time. I've been pretty lucky and haven't had some of the other problems that others have had (wind noise, squeaking springs). "Most" of the problems come from aftermarket stuff that we add to our trucks. The stock truck is pretty sound as is. If it were me, I would pick the Tacoma over the Nissan but I am biased. Resale value and reliability are the main reasons... though I will admit that the current body style is getting pretty long in the tooth even though I still like it.
    Good luck with whatever you decide.
  8. Jul 27, 2013 at 10:14 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    This is still happening? My '05 does it too, has ever since they put in the new leaf pack under the TSB I had done back when it first came out.
    Outrageous that it still hasn't been addressed and fixed on newer models.
  9. Jul 27, 2013 at 10:23 AM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Money is my biggest issue with my 2012 so far. I'm constantly catching myself mid way through the "checkout" process on websites to order shit for my truck. End up not ordering stuff though, since I'm a poor bastard, and all. Don't get the nissan. Frontiers want to be Tacomas when they grow up
  10. Jul 27, 2013 at 10:52 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Issues reported with stock trucks:
    - Rain water getting into heater air intake in the cowl, causing leak on passenger floor.
    Issues reported with modded trucks:
    - Whistling around the windshield seal at highway speeds -> sometimes seen when you install a lift and lose the factory rake, solved by applying more sealant
    - Front differential bearing rumble -> sometimes seen when you install a lift, solved by replacing bearing with ECGS bushing
    - Shortened wheel bearing life -> when you get wheels with less backspacing for a wider stance
    Statistically the Frontier has more issues, some of which are major (radiator leak causing coolant to contaminate and kill transmission, weak rear diff due to small ring gear, etc.) Under Renault mgmt, Nissan reliability nowadays is about mid-pack with American brands. The Frontier, being 300 lb heavier, has worse acceleration and braking performance than the Taco.
  11. Jul 27, 2013 at 10:54 AM
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    Truck payments...
  12. Jul 27, 2013 at 10:56 AM
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    My 13 does NOT do this. I have over 9k on the odometer...
  13. Jul 27, 2013 at 10:57 AM
    cstallings
    Arkansas
    Yes...this is the worst part. :)
  14. Jul 27, 2013 at 10:59 AM
    KenLyns
    Belly of the Beast
    It's fixed with larger rubber pads between leafs:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/98055-diy-squeaky-leaf-fix-12.html
    My leafs don't squeak anymore when I installed the kit ($48 for two packs from Toyota of Dallas), but my Icon shocks still do. (Solvable by transferring a shim from the stock Bilsteins, but I'm too lazy to bother with it. :D)
  15. Jul 27, 2013 at 12:09 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    2013 DCSB TRD Sport - that stupid smog pump noise when you shut off the engine.
  16. Jul 27, 2013 at 12:22 PM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I bought a new 05 4 cylinder extended cab right off the lot with 11 miles on it. It never made an appearance at the dealer for any warranty work. At around 75k miles it needed front wheel bearings. And the A/C compressor died shortly afterwards. I sold it and bought a double cab (another 05) that needed wheel bearings right when I bought it at 112k miles. So badly one of the wheels couldn't be turned by hand with the tire off the ground. Probably needed them for a while. Sold that one last fall and just bought another 05 double cab which had the front wheel bearings replaced at 72k miles. And it just broke a rear leaf spring. I would say front wheel bearings are a common problem.... They have their issues but honestly I still think they are a way better truck than the competition. But I am a bit biased as this is now my 15th Toyota truck.
  17. Jul 27, 2013 at 2:45 PM
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
    Surprised nobody has mentioned the shaky shake. Toyota cant or wont fix the low speed vibrations on the DCSB.
  18. Jul 27, 2013 at 2:50 PM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    ^This
  19. Jul 27, 2013 at 3:17 PM
    Jux
    Jux :D
    Northern Colorado
    Nice. Mine does but only around 45-55 mph and it seems to only be in the morning or night when the air is cooler.
    Hasn't bugged me enough yet for a trip to the dealership.
  20. Jul 27, 2013 at 3:27 PM
    luvium
    luvium Well-Known Member
    San Diego
    13 DCSB 4x4 TRD Offroad M.G
    Trimmed front flaps Extra D rings
    Interior trim rattles, which can be fixed, other than that I have had no issues. Smog pump spooling sound at engine shut off and squishing sound when braking, only if the radio is off can you hear it, both are normal for the tacoma.
    5500 miles
