Cold air intake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shingtime, May 8, 2022.
  1. May 8, 2022 at 7:12 AM
    Shingtime
    Shingtime [OP] New Member
    2016 TRD Sport
    ReadyLift SST 69-5112
  2. May 8, 2022 at 7:15 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    In case you don’t know, the truck comes with a cold air intake from the factory.
    Barrydd, shakerhood, Junkhead and 3 others like this.
  3. May 8, 2022 at 7:19 AM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    TRD intake is an oiled filter which is more work/maintenance. I've run both the HPS intake tube and AFE Momentum GT intake, the HPSgave more low end power/torqueand the AFE gave more top end. I also get about 1mpg better with AFE. Neither will do much on their own aside from a little better throttle response, but compliment exhaust and tune nicely.
  4. May 8, 2022 at 7:20 AM
    eurowner
    eurowner Duke Sky
    Scoty
    If you want an aftermarket CAI; S&B, TRD, Injen are all great enclosed air filter setups.
    Stay away from all open air filter CAIs.
    Or build your own, I use a Green Filter, TRD Intake Accellerator, and the HPS intake tube.
    The best bang for your cash is a tune, do that first!
    Junkhead likes this.
  5. May 8, 2022 at 7:28 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    I found an AFE intake w/ the front scoop off Facebook for $100. For that price it’s totally worth the noise it makes. No change in power/mpg.
    I would do an intake over an exhaust just for the noise.
  6. May 8, 2022 at 7:32 AM
    Shingtime
    2016 TRD Sport
    Noted thanks for the tips. I’ll go with the enclosed option as well as and exhaust upgrade. Tune up is a great idea, finding the truck is lagging a bit off the take off
  7. May 8, 2022 at 7:46 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    CAI and/or exhaust will not give noticeable performance improvements over the factory installed system no matter what brand you select. What ever benefit might be realized is offset by the ECU controlling gas mixture and all those sort of things. That said, I've got both the TRD CAI and exhaust. I like the sounds and the extra longevity of the air filter. Looks cool too.
  8. May 8, 2022 at 7:59 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    You can add one of those airaid helix throttle body spacers to for more noise...makes your engine should like its got a small super charger.....again no power gain, but to some the noise is priceless.
    shakerhood and Chew like this.
