Cold Air Intake Poll
Discussion in 'Performance and Tuning' started by Arrowshot, Dec 25, 2013.
Which Cold Air Intake
Poll closed Jan 24, 2014.
  1. AFE Stage-2 Si Air Intake System with Pro Dry S Media
    15 vote(s)
    55.6%
  2. URD True Cold Air Intake with MAF Sensor Calibrator
    12 vote(s)
    44.4%
  1. Dec 25, 2013 at 6:26 AM
    Arrowshot
    Arrowshot [OP] Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
  2. Dec 25, 2013 at 2:27 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Ran them both......
    Sound..... Urd..... Its loud and sounds badass outside, but civil inside.
    Ease of use, protection against elements.......afe
    while n/a, the afe intake seemed loud inside the truck but I guess Thats subjective.
    If it was raining with the urd, I would get water droplets sucked past the air filter and hit the maf sensor causing the truck to stumble.
    Afe no issues.
    Besides, at approx 40mph the stock, afe, and urd are drawing the same temps...... Ambient
  3. Dec 26, 2013 at 6:24 AM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Justus,
    Thanks very much for the comments and you hit on my main concern with the URD, exposure to the elements. I was wondering what would happen if you plowed through large puddles of water or really massive rainstorms. Is the MAF sensor specific to the URD intake?
  4. Dec 26, 2013 at 10:00 AM
    motoaction22
    motoaction22 Member
    Cody
    Washington
    2014 DCLB TRD SPORT
    I just installed the aFe CAI on my 2014 DCLB. Instant power increase. You can't even tell its there until you put your foot in it then it rages. This is the only mod so far that I have done and its definitely worth it. Easy install, sounds great, looks clean, easy to maintain as well. Go aFe. they have been doing this stuff for awhile.
  5. Dec 26, 2013 at 6:45 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    The urd intake uses the stock maf sensor.
    Edit..... Now I see what ur asking.
    The maf calibrator will allow further tuning and generally is set to lean out the stock mixture some, because the stock setup is rich (safe), and may cost up to 15hp so the claim is.
    U do not NEED the maf calibrator to run any intake I know of.... It will just help get the most out of ur upgrades as possible.
    I ran this also.... I didn't like the fact that I couldn't switch it off if I was running up a long grade in 100 degree weather..... I got pinging while running 91 octane.
    I have since duplicated that run without the calibrator in the same heat with zero issues.
    Will it make a difference u can feel?
    I thought so, but I wasn't comfortable with the inability to a just on the fly or to turn on/off.
    If u rlly want the best bang for ur buck, try to find someone with a supercharged tacoma, and go for a ride.
  6. Dec 26, 2013 at 8:28 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    I run an Airaid on my Tundra and love it.
  7. Dec 26, 2013 at 8:37 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    I installed the URD in my truck, with the concerns of weather, I also bought the filter "sock" from URD just to be on the safe side. I have used the sock ZERO times and had absolutely no issues. I love it and would not trade it for a thing (im told it works with the TRD S/C as well which is good news). The front grill, depending on which one you have, does a great job at keeping weather out. After living through the rainy season in southern AL and now KY/TN, I would not trade the URD intake. (Ive also had 2 friends get one after they saw and rode in my truck).
  8. Dec 27, 2013 at 4:21 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    If it wasn't for the stumbling in the rain I'd def run the urd..... Sounded great, but it was a pita in rain when passing trucks or getting up to speed.
    Maybe it was the poor sealing of the maf sensor where it seats into the bracket.... Most people have to install it like this.....
    Connect maf sensor to harness.....seat maf sensor to the bracket on the intake tube......secure maf sensor safely/snugly while ignoring the crooked angle from the harness connector preventing proper seating causing stress and tell urself the plastic will not get brittle from heat cycles.
    With my afe and stock intake I can safely snug down the maf sensor to the bracket on site intake tube and it sits flush. I can connect the maf sensor harness before or after tightening down the maf sensor to the intake.
    OP just remember, u can't pull an colder air than ambient unless your running an ice box setup..... And again, stock pulls ambient at 40ish, but has some restrictions that can cost performance.
    URD..... Benefit sound and low speed/idle intake temps (good if u like to brag about ur trucks idLe).
    ...cons...Carwashes, rain (grille type may be a factor), cutting sheet metal off the truck, much easier to hydrolock if u like to cross water just over ur bumper (remember the wake can come back after it hits the other bank and create a small wave which will now be higher than the actual depth of the crossing and possibly lock it up).
    Afe benefit... No cutting, unaffected by carwashes, and rain, no hydrophobic sock or splash guard needed, same water crossing capabilities you had from stock, flush mounting for the maf sensor, run any grille u want, no fabrication or hunting down a smaller filter to use it with the supercharger if u choose to later.
    Cons... I think it was louder inside the cabin than the urd but I'm not 100%.
    I've gone back and forth..... 1st was the afe
    Then the urd.....
    Then stock......
    Then afe again and I'm happy.
    I'd run the urd right now if it wasn't for the maf sensor seating issue, and pulling water onto the maf sensor element. Nothing says holy crap like trying to merge and having the truck stumble. I cannot afford that now, Its nice to know I can call on 300+HP and not worry about stumbling.... I can handle throttle modulation just fine, I dont need to fight a computer at the same time.
    AFE for me
  9. Dec 27, 2013 at 6:15 PM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Justin, great write up and no doubt that comes from experience. Sounds like I want AFE but I was not aware that the AFE could be used with the URD MAF Sensor (even though they sell both). I wonder if Gadget has ever looked at modifying so it could be turned off when not needed/wanted. Would that be easy mod from your perspective or not?
  10. Dec 27, 2013 at 6:22 PM
    Brodie
    Brodie Gear Jammer
    Colorado
    2013 TRD Magnetic Gray Double Cab
    Ran the AFE pro dry on my 02 Cummins, never saw a dirtier turbo in my life, took it off and tossed it, after one oil change.
    AFE pro Dry doesn't stop enough dirt.
  11. Dec 27, 2013 at 6:35 PM
    Mydixiewrecked
    Mydixiewrecked Well-Known Member
    Wa
    06 AC sport
    Just installed the 50 series flow master dual exhaust and AFE cold air intake last night.
    Truck rumbles when started, rumbles when I get on it, but is quiet when cruising.
    I'm definitely satisfied with the combo
  12. Dec 28, 2013 at 12:31 PM
    Yotski
    Yotski Well-Known Member
    Alex
    Hilo, Hawaii
    13 SSM Access Cab V6 6 Speed 4x4 TRD Off-Road
    Wet Okoles, Toytec BOSS 3in Kit, Allpro Standard Leaf pack, Ext Bilstein 5100, OEM Skid Plate(destroyed), Thule Racks, Method NV, KM2s, Rigid Grille & Light Bar
    I was debating between these two too... but I have the rigid grill so Im not sure if the urd would be safe.
  13. Dec 29, 2013 at 4:59 PM
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    AFE still seems to be leading. Anyone else notice issues with the AFE Dry Pro filters allowing too much dirt/dust?
  14. Dec 29, 2013 at 7:22 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I'd pick the URD if I didn't have to cut a section off my truck. So I got a AFE stage 2 SI with a modded Volant air scoop attached to it. Love it :thumbsup: The MAF calibrator is worth buying either with the URD or AFE :thumbsup: The air scoop setup is for my TRD blower setup BTW :D
  15. Dec 30, 2013 at 12:05 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    whats ur AFR at WOT with that force fed setup?
  16. Dec 30, 2013 at 12:43 AM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    I would just run an aftermarket high flow filter, the stock airbox is short, direct, and close to a CAI.
  17. Dec 30, 2013 at 4:20 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    actually, the 1grfe airbox has been run with zero filter media and gained zero HP on a dyno.
    the problem is the intake itself
  18. Dec 30, 2013 at 5:51 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I have run them both too, along with an aFe dropin and a custom set up with a Volant scoop tied into the stock air box. Short story, I am running the URD and Cali, and will stay with it.
    Performance wise, you will probably not notice much of anything. All gains are at the high end of the rpm scale, so unless you spend alot of time with your foot on the floor, only thing you will notice is noise. But note that I ran the urd and the afe cai against my Gtech perf meter and showed about a tenth in the quarter. My results though.... For day to day driving, never noticed any perf gains.
    Noise wise the afe was noisiest. Now depending on what you want, this may be good or bad. For me the afe was bad as it had a kind of gurgling noise at around 1500 rpm. It was annoying to me as this is the rpm when driving around town. Ended up going back to stock due to that.
    I then tried the urd. At first by itself without the cali and results were the same perf wise as the urd, not noticable unless on a perf meter. Noise was much better though, no annoying off idle gurgle.
    After about 6 months, installed the cali too. To me this gave a noticable kick right around 3000-3500, when it goes into open loop, depending on throttle position. But I did notice it.
    The urd cai and cali have been in for about 1.5 year and I plan to keep them on. I do not cross significant water and I did buy the shield, not the sock, sock will drop airflow. I have not had any stumbles and cutouts during rain storms, I am just off the Gulf Coast, so we do get good rainstorms. I also have a mesh grill.
    Afe is easier to install, as the urd requires cutting the metal by the radiator, and also extending the maf sensor wiring (you need good soldering skills for this, sensor is sensitive). But for me, the afe off idle noise was a no go, happy with the urd setup.
  19. Dec 30, 2013 at 11:38 AM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    If you run either, be sure to pick one of those filter socks to keep a much debris out as possible.
  20. Dec 30, 2013 at 6:03 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    I'll let you know when I get the blower in Feb with my tax return :D
    Don't forget the stock "cai" everyone claims on TW, the airbox sits on a hot engine block :thumbsup:
