Cold Air Intake MPG
Discussion in '1st Gen. Tacomas (1995-2004)' started by prayzhm, Apr 18, 2016.
  1. Apr 18, 2016 at 9:02 AM
    prayzhm
    prayzhm [OP] Active Member
    Bob
    2004 Tacoma Dbl Cab TRD
    Is there any evidence of any mpg increase with the addition of a cold air intake on an '04 Tacoma? I know there is an increase in hp but not sure it would be beneficial for gas savings.
    Thanks for any responses!
  2. Apr 18, 2016 at 9:04 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    no and no
  3. Apr 18, 2016 at 9:09 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    HP increase? No. MPG? No.
    If there really is, it's <.5%
  4. Apr 18, 2016 at 9:29 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Just do the deck plate mod. LOL!
  5. Apr 18, 2016 at 9:30 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    All you *might* get with a CAI is a slightly noticeable sound they make when accelerating, some people like it....not sure it's worth the money though.
    Think about it, they're located in virtually the same spot as your stock air intake, how is the air they're pulling in significantly colder than it was before? Definitely not enough to make any kind of difference.
    Save up for headers and exhaust if you want a (albeit slightly) noticeable increase in power and possibly MPG, and an awesome sounding truck ;)
    ItsaWhite2018 likes this.
  6. Apr 18, 2016 at 9:33 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    OP, I see that you are new here.
    Don't ever bring up cold air intakes here. If you keep it up; the polar ice caps will melt instantly and the world will flood in a matter of hours.
    If you must discuss cold air intakes, please blanket your interest with a "snorkel system" inquiry. They aren't for traveling through water BUT for keeping your intake above a dust level. But,shhhh, keep that between us okay. ;)
  7. Apr 18, 2016 at 11:12 AM
    prayzhm
    Bob
    No interest in sounding better (doesn't help the wallet any) but if there is no performance improvement I think an OME kit is in order!
    Thanks for all the response!!
  8. Apr 19, 2016 at 10:20 AM
    MattFL
    MattFL Well-Known Member
    S. Florida
    1999 Tacoma V6 4x4 TRD Extended cab
    Cold air requires more fuel, if anything your mileage would go down.
  9. Apr 19, 2016 at 10:42 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I'm telling ya, deck plate mod. Lol!!!
  10. Apr 19, 2016 at 1:36 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
  11. Apr 19, 2016 at 2:31 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
  12. Apr 21, 2016 at 9:15 AM
    ashleyroachclip
    ashleyroachclip Well-Known Member
    Obviously, I am new to this site as well, thanks for having me.
    That said , can someone tell me what is this deck plate mod?
    Or is this a practical joke
  13. Apr 21, 2016 at 9:21 AM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    Deck plates are off of boats. They are like a big screw in cap. You cut a hole in your air box and install one. Remove it when you want loud noise and dust in your engine. Keep it screwed in for the latter.
  14. Apr 21, 2016 at 9:23 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    It's a real mod, but it's as practical and benifical as a joke.
  15. Apr 21, 2016 at 9:23 AM
    ashleyroachclip
    Thanks Hondah
  16. Apr 21, 2016 at 9:23 AM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Hot air intake
  17. Apr 21, 2016 at 9:24 AM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    No problem mate. :hattip:
  18. Apr 21, 2016 at 9:25 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Lol!!!
  19. Apr 21, 2016 at 9:30 AM
    eon_blue
    Azusa, CA
    There are warm air intakes...
  20. Apr 21, 2016 at 9:36 AM
    ashleyroachclip
    When I bought this truck, it indeed has a K&N intake , and the California carb compliant MAF .
    I was looking at the shroud, which has a seal to hood , and see the size of the hole, where intake air comes from in the side fender apron.
    If you also look at some of the other after market air intakes , Voliant , probably not spelled right, but their filter is in a 3 sided box.
    My point, blocking engine bay temperatures , and a larger air supply, may be beneficial .
    The factory air box, is fairly restrictive.
    All said , the only way you could have a cold air intake ....
    ...a block of dry ice in front of the air supply
