Coilovers vs struts
Discussion in 'Suspension' started by teddygrahams, Jun 3, 2010.
  1. Jun 3, 2010 at 6:22 PM
    teddygrahams
    teddygrahams [OP] Well-Known Member
    what are they two big differences in these two besides the obvious. what are the disadvantages and advantages to both? im trying to decide what to get... thanks
  2. Jun 3, 2010 at 11:48 PM
    teddygrahams
  3. Jun 4, 2010 at 1:32 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I don't think you can put a strut on a Taco without totally modifying all of the suspension: a strut basically supports the top of the wheel in place and acts as a shock absorber; a coilover style system uses an upper control arm (UCA) to support the top of the wheel and the coilover then holds the vehicle height and is the shock absorber. Strut systems have no UCA, just a lower control arm (LCA).
    Maybe you are pondering the difference between an adjustable coilover (c/o) vs a non adjustable c/o..?
    Personally I like the adjustable because I can change the front end lift up or down as I please, I can crank one side up a little more to level the truck side-to-side etc, and I recently incresed my rear lift from 1" to 1.5" and just adjusted the front accordingly to level it back out.
  4. Jun 4, 2010 at 10:31 AM
    teddygrahams
    taco come stock with a strut coilover system. which are pretty much the same and im curious to as what makes them different if you were to buy them both aftermarket.
  5. Jun 4, 2010 at 10:40 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Adjustable, rebuildable, valving, price, looks, performance.
