Code P1604 and the air pump doesn't kick on or off anymore.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MidnightRebel07, Dec 21, 2017.
  1. Dec 21, 2017 at 7:06 AM
    MidnightRebel07
    MidnightRebel07 [OP] If you're gonna be a bear, Be a Grizzly !
    Jerry
    Northside of Pittsburgh, Pa.
    2013 Tacoma BAJA T/X dcsb
    Ironman Foam Cell Pro suspension, Anso black headlight housings, l.e.d. headlights, black taillights, Demello steel front bumper with highlight 7" l.e.d. round lights, Diode Dynamics Amber SS3 Pro lights, Hooke Road steel rear bumper with Nighlight reverse lights, Hooke Road roof rack, Ultima Aluminum toolbox, Weathertech floor mats, EGR in channel ventshades, Snorkel, K&N air filter and cabin air filter, 265/75/16 Cooper ST Maxx, Firestone ride rite airbags, Bentrodders bed reinforcements, too many other things to remember.
    For a couple days when starting my 2013 Tacoma BAJA 4.0 I've noticed the maintenance required light blinking 8 times and now it stays on. Thought it was reminding me to do the oil change until it stayed on (plus I just changed the oil 2k miles ago). I've noticed that the air pump doesn't make any noise anymore when turning the truck on and shutting it off. Took it to the par t's store and read the code with their scanner and it came up with this p1604 code. The truck doesn't have any issues starting at all. Any help would be great. The truck only has 40,568 miles on it.
  2. Dec 21, 2017 at 10:13 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    The probable causes for that code cover a wide range of systems/symptoms. BUT since your AIR injection pump seems to be inoperative, I would remedy that issue first.
    One of the probable causes for the code is the A/F ratio sensor (wide band O2). That year may use the A/F sensor to monitor and determine how long the AIR pump runs (a running pump will create a lean condition). This is all dependent on whether the engine is HOT or COLD and what the ambient temp is. There could also be another issue keeping the pump from running (other then failure)
    Might want to monitor your fuel trims as well to make sure nothing abnormal is going on.
    MidnightRebel07[OP] likes this.
