Code: P0758 - Shift Solenoid 'B' Electrical Malfunction
Discussion in '1st Gen. Tacomas (1995-2004)' started by v5ensx, Dec 15, 2019.
  1. Dec 15, 2019 at 2:13 PM
    v5ensx
    v5ensx [OP] CARB legal is not CALI legal
    Helping a buddy out with his 1996 Tacoma v6. Anyone familiar with this P0758 code? 3 solenoid in transmission.
    O/D light in cluster flashes with check engine light on. Truck picking up speed very slow. Gas pedal down to the floor, rpm/speed raises slowly. Truck do not shake when picking up speed but shift harsh.
    What's been done:
    -fluid look good/red when drained
    -2 of 3 solenoid click in the faulty transmission, test a working transmission, same result
    -3 wire harness have continuity to pigtail
    -new filter and dex3 fluid
    Any solution?
  2. Dec 15, 2019 at 2:16 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    It's stuck in 3rd gear because the shift solenoid isn't functioning. Check wiring first but you'll probably have to replace the solenoid. They're freaking easy to do, just have to take off the trans pan
  3. Dec 15, 2019 at 6:08 PM
    v5ensx
    Even when the solenoid is jumped with 12v and click, can it still be defective?
