Code P0451
Discussion in '1st Gen. Tacomas (1995-2004)' started by npbow, Oct 14, 2018.
  1. Oct 14, 2018 at 4:00 PM
    npbow
    npbow [OP] Active Member
    Need help I have a 2004 xcab v-6 and its throwing code P0451 EVAP pressure.Has anyone has this and what could be causing it .I read it could be a pressure switch.
    Also I recently replaced the vacume lines that go from canister to hard line under the bed .I used fuel line hose due to no available vacume hose that has a slightly smaller inside diameter do you think that could cause the problem.
  2. Oct 15, 2018 at 9:34 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Been fighting mine for a while. EVAP system leak - small , is what the actual code says. Checked the purge valves on the drs. side inner fender - they are functioning. Can't find any leak. There is a schrader valve to connect a smoke machine but I don't have one of those. Been toying with the idea of using a bicycle tire pump to pressurize the system then squirt soapy water on the connections, but I need a helper. I just reset (shut off with code reader) and it stays off till I get a new inspection sticker.
  3. Oct 15, 2018 at 11:30 AM
    Buckowens
    Buckowens Member
    Texas
    2001 Prerunner
  4. Oct 15, 2018 at 2:11 PM
    djohn24
    djohn24 Well-Known Member
    Dennis
    Pa
    03 Double cab SR5 Tacoma 4x4
    I got a po442 code the other day which mentioned a evap (small leak). I seen on here the top of the gas tank where the sending unit mounts can rot away. Meaning, you need a new tank. I haven't looked at mine yet but, if you see wetness around there, good sign that is the issue.
  5. Oct 19, 2018 at 7:31 AM
    npbow
    From everything I can find on the web the p0451 for a 2004 tacoma means ( Evaporative Emission Control System Pressure Sensor Range/Performance) and the reason for the code is a bad sensor. Whats confusing is I cant find anything that tells you, or shows you where this sensor is.I read allot of posts and web pages they are conflicting some seem to say its on the gas tank others say its on the charcoal canister.Does anyone know exactly where this sensor is ,and a fix for this code or part number for this sensor.Thank this is driving me crazy.
  6. Oct 19, 2018 at 10:27 AM
    Buckowens
    Buckowens Member
    Texas
    2001 Prerunner
    It is located under the hood, drivers side above the brake booster attached to a black bracket that is bolted to the firewall.
  7. Oct 19, 2018 at 12:21 PM
    npbow
    I think they moved it starting in 2002 not there on my 04
  8. Aug 4, 2019 at 7:16 PM
    Reareahar
    Reareahar Member
    Md
    Tacoma 03 prerunner
    V6 3.4
    Has anybody ever figured out this PO451 code. It's driving me insane. I've changed evap canister and all new vacuum lines..appreciate any insight if anybody figured this out!
  9. Aug 4, 2019 at 10:45 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Since you replaced vac lines and canister, I'd double check everything just to rule out any connection issue. Also included Vapor Pressure Sensor location/info. Think you were looking for that as well.
    Welcome to Tacoma World! Good luck.
  10. Aug 5, 2019 at 6:10 AM
    Reareahar
    Reareahar Member
    Md
    Tacoma 03 prerunner
    V6 3.4
    Thanks alot but why is everybody else saying it's under the hood (vapor pressure sensor) is 2003 the only one that's on the gas tank? I'm not looking forward to that again. My eva0 canister I removed the can to install... On this thread also it's mentioned the sensor can't be located it's not carried by dealership anymore. Insight please.
  11. Aug 5, 2019 at 1:25 PM
    npbow
    I just changed my sensor this weekend (p0450) to start you can get the sensor from rock auto https://www.rockauto.com/en/catalog...084,fuel+&+air,fuel+tank+pressure+sensor,6385
    To install I took out all the bed bolts put a piece of 2x4 on top a 4x4 between the frame and bed on drivers side right were the middle bed bolt would mount.Next if you carefully feel the side or the sensor you can feel the clip that hold the sensor lock in. If you get a flat head or a pick and pry between the sensor and clip it will pop out allowing you to pull up on the sensor to remove (also must unplug wiring harness) I added a diagram hope it helps
    Area51Runner likes this.
