Code P0450 help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Agir, Oct 19, 2021.
  1. Oct 19, 2021 at 10:06 AM
    Agir
    Agir [OP] Well-Known Member
    I keep having the check engine code P0450 come up, every time it comes up though is when I fill my gas take up, it stops coming on around when a quarter of tank of gas is used. From then on it stays off till I fill up again. Is this a wiring harness issue, or a sensor issue?
  2. Oct 19, 2021 at 10:22 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Could be either one then it might be a problem with pressure building in the tank when full .
    Maybe the vent is below the liquid level till the level drops below 1/4 tank.
    How long have you had the problem??
  3. Oct 19, 2021 at 3:04 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Never pump gas after the auto shutoff stops the pump.
    No topping up on all 4 cylinder trucks because the charcoal cannister is mounted above the fuel tank and can get flooded with fuel while pumping the tank AND filler neck full of fuel.
  4. Oct 19, 2021 at 3:30 PM
    Agir
    To answer both y'all it has happened fairly recently, I have had the engine code trip that once or twice. Two years ago, but recently it has been a constant issue.
    I do pump the gas after the auto shutoff but my engine is a 6 cylinder. I also have done this for years prior with no prior issue so I personally don't think that would've caused it.
    It is nice to be back on Tacoma World again, decided to come back after a while because this place is just too awesome.
  5. Oct 19, 2021 at 7:03 PM
    Glamisman
    Glamisman Well-Known Member
    this is a good explanation... https://www.obd-codes.com/p0450
    evap codes are notoriously difficult to find and fix. If you don't live in a state that requires emission testing I wouldn't worry about it too much, as you have seen, it is self "fixing".
