Code P0401
Discussion in '1st Gen. Tacomas (1995-2004)' started by sramirez1516, Jan 23, 2017.
  1. Jan 23, 2017 at 8:47 PM
    sramirez1516
    sramirez1516 [OP] Saul R.
    Saul
    2002 Toyota tacoma xtracab prerunner 2.7
    None
    Hi there
    I been working on a 2002 toyota tacoma xtracab prerunner 2.7L. The check engine light went off and it shows code P0401 Insufficient Exhaust Gas Recirculation (EGR) Flow.
    I took the intake manifold out and cleaned all the openings coming from the EGR valve, there was barely any carbon buld up. I also noticed the EGR Temperature sensor had some carbon so I cleaned it real good. I didn't replace the EGR valve hoping that cleaning the openings and EGR temperature sensor would fix the problem.
    I put everything back together and drove a few miles. The check engine light went off once again.
    I replaced the EGR Valve 1 hour ago and the check engine light went off. What am i missing? what else would you do? what am I missing?
    Thanks in advance.
  2. Jan 23, 2017 at 9:11 PM
    LifeOverTheEdge
    LifeOverTheEdge Well-Known Member
    Hackettstown, NJ
    2004 Tacoma Xtra Cab 2.4l 5 Lug Auto
    A whole lot
    Double check all vacuum lines, especially the ones on top of the throttle body.
    Try that before throwing parts at it.
    There's a ton of posts on this code, check em out and save some time, $, and headaches :)
  3. Jan 24, 2017 at 3:40 AM
    sramirez1516
    Saul
    None
    I been reading about a VSV (vacuum switching valve) failing on some cases. I been looking for one online but I'm guessing this tacoma has a different name for it. Anyone lnow them by a different name?
  4. Jan 24, 2017 at 6:28 AM
    indetrucks
    indetrucks Well-Known Member
    Christian
    Southern CA
    Supercharged 03 TRD Tacoma 4x4 Xtra Cab 5spd
    I thought the P0401 was the old loose gas cap code. No?
  5. Jan 24, 2017 at 6:34 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    The Factory Service Manual (FSM) has a troubleshooting section on all codes. P0401 is on page DI-101. You can download it from the Sticky section at the top of the screen.
    It shows the testing procedure for the VSV for EGR.
  6. Jan 24, 2017 at 7:02 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
  7. Jan 24, 2017 at 7:03 AM
    cruiserguy
    Elijah
    SEKS
    Unfortunately, as you found out, it's usually not the EGR valve itself that fails. It's usually the modulator or the vsv.
    DrZ likes this.
  8. Jan 24, 2017 at 7:04 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
  9. Jan 24, 2017 at 7:06 AM
    cruiserguy
    Elijah
    SEKS
    Your first name reminded me I need to binge watch second season of Better call Saul one of these days. Lol
    mechanicjon likes this.
  10. Jan 24, 2017 at 7:07 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    try purge solenoid.
  11. Jan 24, 2017 at 7:26 AM
    cruiserguy
    Elijah
    SEKS
    Just remembered, you can also try cleaning off the EGR temp sensor. You may have already done that though.
  12. Jan 24, 2017 at 8:27 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    OP claims he 'cleaned it real good'.
    The temp sensor was my 0401 problem. At first, I cleaned it with a spray-on TB cleaner. The CEL went away for a week. Then I cleaned it with a knife (scraped off that black crud) about 3 years ago. No CEL since.
    If the CEL ever comes back, I'll finally break down and get a new one.
  13. Jan 24, 2017 at 8:59 AM
    sramirez1516
    Saul
    None
    I will do a through inspection, today after work. I hope it's just a hose. Been spending quite a bit of $$. I'm about to throw the towel.
  14. Jan 24, 2017 at 10:24 AM
    sramirez1516
    Saul
    None
    Big fan. It's been kinda boring. I guess I'm used to the old Saul from Braking Bad, the funny Goodman.
  15. Jan 24, 2017 at 10:26 AM
    sramirez1516
    Saul
    None
    My dad showed up when I was working on it and he used a emery cloth to clean it while I was putting the intake back in. I tried to clean it with throttle cleaner but the carbon was really in there. He did a decent job.
  16. Jan 24, 2017 at 2:08 PM
    cruiserguy
    Elijah
    SEKS
    Cool man, you can test each of the components in the EGR system. The EGR valve itself can be tested for function while still on the engine. I believe the modulator should be removed to test, as well as the VSV. The steps to test these are in the FSM, I believe. Do you have access to a copy of the FSM or the digital version of the FSM?
  17. Jan 24, 2017 at 3:00 PM
    sramirez1516
    Saul
    None
    Sadly I do not have the FSM. You got any idea where to find it?
  18. Jan 24, 2017 at 3:13 PM
    cruiserguy
    Elijah
    SEKS
    I think there is a link to download the FSM in one of the threads in the sticky section. Or someone else might chime in with a link or copy.
  19. Jan 24, 2017 at 5:35 PM
    ghs57
    Chops
    Catskill Mts. NY
    Post #5. It's in the sticky section.
    cruiserguy likes this.
  20. Jan 24, 2017 at 5:41 PM
    sramirez1516
    Saul
    None
    I checked it but the website it sends me to doesn't have them anymore.
