Code P014C, P014D
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mudsock, Jun 2, 2022.
  1. Jun 2, 2022 at 6:17 PM
    Mudsock
    Mudsock [OP] Well-Known Member
    Indiana
    2010 2.7 4x4
    C5FEDB7E-4632-440D-B163-866C1FAED706.jpg 5EC86F56-4132-4BD7-A4AE-D341DC79064B.jpg 428DCE46-130A-423D-B413-EDE8D262DAC1.jpg
    My questions is this code referring to the oxygen sensor? And is this the first O2 sensor or the one after the cat? Any help would be appreciated.
    also, I’m not sure what the C1201 code is about.
    And a gratuitous Yuengling shot.
    Sorry the picture of Yuengling was supposed to be last and correctly aligned. Oh well. You get the idea.
  2. Jun 2, 2022 at 7:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The slow response codes are typically a failing sensor providing there are no exhaust leaks upstream or near the sensor, they are referring to the upstream (before the converter) Air/Fuel Ratio sensor.
    The downstream sensor is a standard oxygen sensor, the upstream is referred to a an AFR (Air/Fuel Ratio) sensor.
    Toyota uses Denso sensors so make sure you get the correct one and beware of counterfeits on Amazon & Ebay.
    The C1201 in the ABS module just means the there's a trouble code in the PCM, it will self clear once the PCM codes are fixed.
    Mudsock[OP] likes this.
  3. Jun 3, 2022 at 2:19 AM
    Mudsock
    Indiana
    2010 2.7 4x4
    Thank you very much!
