Code P0011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Miguel_prerunner7, Nov 7, 2020.
  1. Nov 7, 2020 at 8:36 PM
    Miguel_prerunner7
    Miguel_prerunner7 [OP] Well-Known Member
    Miguel
    Downey Ca
    Sold 2001 tacoma prerunner 4x4 conversation 09 taco
    Snorkel
    Hello fellas,
    For some reason this code keeps popping up P0011 randomly.
    Comes on and goes away on it’s own..
    Anyone have this problem?
    2.7 2009
    Thanks !
  2. Nov 7, 2020 at 8:45 PM
    Bishop84
    Bishop84 Well-Known Member
    Could be a few things, oil control valve, cam gear, or timing chain is stretched. They are hard to diagnose.
    I personally would consider doing a hot oil flush next oil change.
    Drive it on the highway, add a cleaner, and dump the oil red hot. Replace with a quality oil.
    Miguel_prerunner7[OP] likes this.
  3. Nov 7, 2020 at 8:52 PM
    Miguel_prerunner7
    Miguel
    Downey Ca
    Snorkel
    thank you I will give it a try
  4. Nov 7, 2020 at 9:02 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you, in your experience as a Tech, ever seen a clogged OCV Filter cause this issue?
    Would it even be worth checking it?
    Bishop84[QUOTED] likes this.
  5. Nov 7, 2020 at 9:08 PM
    Bishop84
    Yes, but it was a symptom of something else. Metal fillings haha.
    Regardless the filter on the high pressure oil line leading to the ocv is worth inspecting and cleaning. It's a banjo fitting.
    TnShooter[QUOTED] and b_r_o like this.
