Clutch problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95Babyota, Sep 22, 2021.
  1. Sep 22, 2021 at 10:24 AM
    95Babyota
    95Babyota [OP] Well-Known Member
    Kenneth
    95 Tacoma reg cab
    I have a 95 Tacoma 4wd 3rz and yesterday while I was driving I pressed in the clutch petal, stopped, and it started engaging while it was completely compressed and almost stalled the truck, I forced it out of gear and re-compressed the petal and it worked fine then after driving for a while it did it again, the fluid is topped off and I flushed the old fluid out about 6 months ago so I don’t think it needs to be bled. I had this issue with my old Tacoma and it ended up being a broken clutch fork, I’m praying that’s not the case. Has anyone had this issue before?
  2. Sep 22, 2021 at 10:31 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Just spit balling but maybe bad clutch master or slave cylinders. Or a bit of a stretch but could be a failing rubber hose that is expanding when the clutch pedal is being pushed in. An extra set of eyes can help determine this if it is the culprit
  3. Sep 22, 2021 at 10:48 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    New fluid helps but if you're loosing hydraulic pressure and there's no leaks the Clutch master cylinder, slave and hose aren't expensive or hard to change. I would rule out the clutch fork and check for cracked firewall mounts before replacing hydraulics though.
    JudoJohn and maxtherat like this.
  4. Sep 22, 2021 at 1:24 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Check and see if your clutch mechanical throw is actuating long enough and bleed the hydraulic clutch system if it needs it.
  5. Sep 22, 2021 at 1:36 PM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    Are the mounts on the inside or outside of the firewall?
  6. Sep 22, 2021 at 1:38 PM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    A rubber hose that goes from the master to the slave?
  7. Sep 22, 2021 at 1:38 PM
    Truckntran
    Truckntran Well-Known Member
    1996 and 1998 Tacoma 2wd
    High mileage work trucks
    If you flushed out old ugly black fluid it’s probably from degrading rubber parts. Chances are you need hydraulic rebuilds or new master and slave. Especially if it was a cold day this morning when it acted up.
    Best guess I can do from my phone.
  8. Sep 22, 2021 at 1:42 PM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    I don’t think it was that bad when I flushed it I just heard on here that another type of fluid would work better than DOT so I flushed it out and I think I replaced it with redline. That was 6 months ago or more though. It was probably around 65 degrees out.
  9. Sep 22, 2021 at 1:49 PM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    Also, I didn’t feel any difference in pressure when pushing in the pedal
  10. Sep 22, 2021 at 2:19 PM
    maxtherat
    Inland Northwest
    Yes sir
  11. Sep 22, 2021 at 4:05 PM
    Black DOG Lila
    Virginia
    Inside
  12. Sep 23, 2021 at 4:04 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Not only can the clutch bracket break the fire wall as well!
    Check the clutch Fork as well.
    While it can`t hurt to change clutch hydraulics with Aisin products
  13. Sep 23, 2021 at 5:54 AM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    I checked and there was only a metal line.
  14. Sep 23, 2021 at 5:55 AM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    I replaced the master and slave cyl and so far no more issues. Thanks guys.
  15. Sep 23, 2021 at 5:56 AM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    Also fixed that super annoying squeak from the petal woo!
  16. Sep 23, 2021 at 6:06 AM
    Bivouac
    No it is there between the steel line off the slave cylinder and the steel line off the Master cylinder .
    If not that line would be breaking all the time
    Unless some one had put the 5 speed in and never installed it
    maxtherat likes this.
  17. Sep 23, 2021 at 6:33 AM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    Oh ok. I’ll take another look. Ty.
  18. Sep 23, 2021 at 6:35 AM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    Is the push rod adjustable? It seams like the engagement point is really small. Maybe I’m just used to my crappy master cylinder lol.
    Black DOG Lila likes this.
  19. Sep 23, 2021 at 6:45 AM
    Black DOG Lila
    Virginia
  20. Sep 23, 2021 at 7:06 AM
    95Babyota
    Kenneth
    95 Tacoma reg cab
    Oh good! That makes way more sense. Thank you.
