Clutch noise for 1999 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by GreenTaco99, Jul 10, 2017.
  1. Jul 10, 2017 at 4:41 PM
    GreenTaco99
    GreenTaco99 [OP] New Member
    1999 Toyota Tacoma ext cab v6 sr5
    Hey everyone,
    I have a 1999 Tacoma v6 5 speed standard and whenever I push in the clutch, my car makes a whining, groaning, vibrating sound. Additionally, when I try to shift into either 1st or reverse, when I release the clutch, it feels like I'm only 10% connected to the transmission. This means that the car will barely move, and if I give it any throttle, the whining groaning sound turns into what sounds like a grinding and screeching of gears. I have no clue what the deal is or where to start looking for problems, so if anyone has any ideas, they would be much appreciated!
    Thanks,
  2. Jul 10, 2017 at 4:41 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    How many miles are on this clutch?
  3. Jul 10, 2017 at 4:46 PM
    GreenTaco99
    I'm not sure.. the car has 215,xxx miles and I bought it with 198,xxx about 1.5 years ago and I've never replaced. the guy I bought it from mentioned something about having it replaced maybe 60,000 miles before he sold it?
  4. Jul 10, 2017 at 4:59 PM
    eon_blue
    Azusa, CA
    I'm betting it needs a new clutch then, since there's about 150k on the current one. That's about the average lifespan of a clutch. See what some others on here might think though.
  5. Jul 10, 2017 at 5:05 PM
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    Is the noise in this video the noise your talking about? If that's the noise your talking about, then I sparyed some dry film lube on the areas that he did several days ago and my annoying squeak has been gone so far. I can't help with the reverse issue.
    https://www.youtube.com/watch?v=mKLCTeyvU5I
  6. Jul 29, 2017 at 4:32 PM
    rybern
    N Alabama
    My noise has come back about 2 weeks after I sprayed dry film lube on the area inside the boot.
  7. Jul 29, 2017 at 7:25 PM
    cazinpa
    cazinpa Well-Known Member
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    This is the throw out bearing - presses against the pressure plate when the pedal is pressed.
    It means you need a new clutch sometime soon. Depending on how bad, it could still last a while.
  8. Jul 29, 2017 at 7:51 PM
    rybern
    N Alabama
    Thanks for the response Andy. So this noise is coming from the throw out bearing? Dealer records show that my clutch was replaced 60k ago(original clutch lasted 233K). Maybe they just replaced the clutch disk and not the throw out bearing. This may also mean that the throwout bearing may be original?
  9. Jul 30, 2017 at 3:37 AM
    cazinpa
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    I'd guess they did replace it - although the original lasted forever, I don't think 60k is unreasonable for a clutch - especially if it wasn't OEM.
    I had one that I drove with the bearing noise for over a year. Not a death sentence, but I'd start thinking about it.
  10. Jul 30, 2017 at 5:45 AM
    rybern
    N Alabama
    I'm surprised that I was only able to get 60K from these OEM parts before getting this noise.
    According to dealer records, I was able to find that the following parts were replaced at 233K at dealership:
    BEARING,BAL,12,32,F 903631200277
    REMAN DISC CLUTCH 312503540084
    REMAN CLUTCH COVER 312103520084
    BEARING ASSY, CLUTCH 3123035091
    SEAT SUB-ASSY, SHIFT 3350535020
    BUSH, SHIFT LEVER 3354831010
  11. Jul 30, 2017 at 10:00 AM
    cazinpa
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    Apparently I didn't really read your post the first time. The whining is the least of your problems. You need a new clutch.
    Clutch life greatly varies by driver and the use of the vehicle. I would not consider 60k miles unreasonable...
  12. Jul 30, 2017 at 10:54 AM
    rybern
    N Alabama
    Opps, I'm not the OP. Apparently I accidentally high jacked this thread. I chimed in about the squeeking of the pedal which is the only problem I'm having.
  13. Jul 30, 2017 at 11:03 AM
    cazinpa
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    Squeak is an easy fix. Just grease up the pivot on the clutch fork. You will have to pull the rubber boot where it goes through the bellhousing.
  14. Jul 30, 2017 at 1:30 PM
    rybern
    N Alabama
    I tried dry lube file. I'll try spray grease next. Thanks.
  15. Jul 30, 2017 at 1:34 PM
    cazinpa
    Andy
    Lancaster, PA
    '96 Tacoma
    A few tweaks
    Good ole' sloppy regular grease is what I've always used.
  16. Jul 30, 2017 at 2:33 PM
    rybern
    N Alabama
    Spray grease fixed it deader than a hammer. Thanks. :)
  17. Jul 31, 2017 at 6:00 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Fluid film works great for this.
  18. Aug 1, 2017 at 5:53 AM
    rybern
    N Alabama
    The spray grease I used lasted two days. I sprayed Fluid film on yesterday. Thanks for the tip. :)
    Dalandser[QUOTED] likes this.
  19. Dec 1, 2017 at 10:04 AM
    pequeño-taco
    pequeño-taco Member
    Chase
    Super White 04 Taco
    Stock
    How has that Fluid Film been holding up? My 04 just got the Creeky pop to it.
  20. Dec 1, 2017 at 10:07 AM
    eon_blue
    Azusa, CA
    My 04's clutch pedal/assembly goes through phases....I swear it's like a teenager. Some days/weeks it's creaky/popping and then it goes for days/weeks where it's smooth and quiet like it was brand new.
    I hit it with Tri-Flo lube every so often and I think it helps.
