Clutch Fork Snapped
Discussion in '1st Gen. Tacomas (1995-2004)' started by BuelltonTacoma, Aug 14, 2019.
  1. Aug 14, 2019 at 4:09 PM
    BuelltonTacoma
    BuelltonTacoma [OP] Well-Known Member
    2000 Tacoma 4x4 V6 3.4L MT
    Pulled up to a 4-way stop last night, felt a little pop and my clutch pedal hit the floor w/ zero pressure. Got a tow home and swapped out the slave this morning. Bled the slave and still zero pressure, then noticed the slave piston was hitting the clutch fork as a weird angle (not straight), so I took the slave back off and took a closer look at the fork. After removing the rubber boot, realized the clutch fork was completely snapped off and had about 2 inches of play (up/down, not forward/back). This probably means I need a new throw out bearing too (I'm really just talking out of my ass b/c that's just something I just read somewhere online).
    Dropping the transmission to remove bell housing is beyond my front-yard DIY capabilities, so the truck is being towed to the auto shop as I write this. Got a quote of 6 hrs labor + who-knows-what-other-damage once they get the transmission open to inspect the break. Hoping to get out the door under a grand but not betting on it. As for me, it's Modelo time now. Figured I'd share this experience in case anyone else with a high-milage first gen runs into this problem.
    Too long; didn't read -- clutch fork broke off inside transmission. No clutch pressure. Drank a six pack and hired a real mechanic.
  2. Aug 14, 2019 at 4:40 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Haha. It happens often enough. Toyota reengineered the clutch fork around 2001, so you rarely if ever hear it happening on 2001+ trucks. You're going to want to do the clutch & pilot bearing, also resurface the flywheel if the tranny gets dropped.
  3. Aug 14, 2019 at 4:46 PM
    BuelltonTacoma
    The mechanic is going to check out the rest of the clutch for issues related to the fork break, but I'm hoping I can avoid that as I had my clutch replaced about two years ago and drive it like an old man.
  4. Aug 15, 2019 at 1:43 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    In my youth I replaced quite a few clutches in the Yard .
    The down side was losing hardware in the grass .
  5. Aug 15, 2019 at 9:40 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Man - Same here. I used to have a big magnet to go over the gravel and grass to try and find certain things that I lost. I don't miss rolling around on some gravel and having it stick to you. Those were the learning years for sure!
    OP - You'll find that separating the trans on the 1st gen is somewhat of a nightmare. If you have a friend or know anybody with a lift that's your best bet. I had to use a come-a-long to pull mine apart. Not advised but it was necessary.
    I would think $1000 to $1200 should cover you for a clutch replacement. Once you pull the trans out it's easy to access the shift fork. Good luck!
    BuelltonTacoma[OP] likes this.
