Clutch Engagement Point?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Terrier, Nov 29, 2008.
  1. Nov 29, 2008 at 6:07 PM
    Terrier
    Terrier [OP] Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    I notice that the point at which my clutch appears to engage on my 5 speed Tacoma is much higher than that of my other vehicle's clutch. I would estimate that the engagement point is approximately in the upper 1/4 (in other words, near the top of the pedal travel or fully released position).
    Where is the approximate engagment point on your Tacoma clutches?
  2. Nov 29, 2008 at 6:13 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Take a look at the clutch pedal TSB. At the end, pgs 9-10, it describes how to adjust the clutch pedal height, freeplay, and release point.
    http://www.divshare.com/download/4099480-549
    Might need to bleed the clutch or adjust the pushrod.
  3. Nov 29, 2008 at 6:41 PM
    Terrier
    Idaho
    Thanks for your prompt response. Are you saying that it should not engage so high? I only have about 7,000 miles on the truck and if I recall correctly, it has been engaging about same point since new.
  4. Nov 29, 2008 at 7:51 PM
    afd23a
    The Dynamo of Dixie
    Personally, I would think that it should not engage until closer to the floor. The rule of thumb I have been told in the past is that the further out it engages, the more the clutch is worn. That is assuming the release point was closer to the floor in the beginning. Since it has been doing it since new, that may not be the case. It may just be that an adjustment should be made to make it engage closer to the floor.
    The TSB that I linked before is for the 05-06 models. I'm not sure if the 08's are the same. Just for clarification, I linked it so you could use the information about the clutch pedal height, freeplay, and release point as a reference since the TSB doesn't apply to your truck. I'd check the release point procedure on pg 10 and see what it measures. Then you can use that info as ammo if you take it in to get it adjusted. ;)
    I do know that mine doesn't engage as far out as you are describing though. And for that reason, I have not tried the procedure on pg 10. But if I was concerned about it, I would.
  5. Nov 29, 2008 at 8:32 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I think its the opposite my tacoma has a newer clutch and engages when pushing it down less and my 87 pickup that needs a new clutch engages closer to the floor. I could be wrong.
  6. Nov 30, 2008 at 9:15 AM
    Terrier
    Idaho
    Looks like kmok's is somewhat consistent with the engagement point on mine. Afd23a has me a little concerned. Maybe I need to clarify. When I say "upper 1/4", I am not referring to upper 1/4 inch; I am referring to approximately the upper 25% (1/4) of the pedal travel.
    Also, afd23a, thanks for your input; however, the TSB does not appear to apply (release point vs. engagement point). Also, the procedure on page 10 should be left for the dealer mechanic to perform safely and properly (TSBs are directed to the dealer mechanic).
    Please tell me about the engagment point on your 2nd generation Tacoma's.
  7. Dec 2, 2008 at 1:34 PM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Yes, clutch engagement is later in the travel with our trucks. The piston rod would need to be adjusted to change that. I havent touched mine.
    One thing some us have done to help at least reduce the long travel is remove the last 3/4" of wasted freeplay (at least on my 05'). There was an instructional posted years ago on TN, but its gone. Basically getting to the adjustment for the freeplay (as seen in the TSB afd23a posted) is a pain, so make your own 7mm spacer to replace the Clutch pedal No.1 Cushion (its about 3mm) thus removing all that wasted travel, but not engaging the clutch.
  8. Dec 5, 2008 at 8:00 AM
    afd23a
    The Dynamo of Dixie
    FYI, I had my clutch master cylinder replaced a couple days ago b/c it was leaking. The clutch engage point changed with the new cylinder. It moved farther away from the floor to the same area of travel you are asking about. Approximately the last 1/4 of the pedal travel. Went back this morning and they adjusted it to be closer to the floor. Apparently, this is a PIA to adjust. Now it's around the halfway point of the pedal travel and I'm ok with that. I would've liked it better in the first 1/4 of the pedal travel, but oh well. Bottom line, the dealer can do it, but the tech probably won't enjoy it.
  9. Dec 27, 2008 at 9:19 AM
    Terrier
    Idaho
    Update: Recently, a mechanic from the Toyota Dealer test drove my Tacoma and said the higher clutch engagment point is normal.
  10. Dec 27, 2008 at 9:36 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Have the same setup as yourself, but the pre-runner. I found this to be very odd when i bought the truck but have become used to it as time went on. Shifts fine, and there doesn't seem to be a problem what-so-ever with th e release point other than it being different then most vehicles.
  11. Nov 17, 2020 at 7:49 PM
    K Williams
    K Williams Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    Just got a new clutch installed(my URD Stage 2 went on me last week). My clutch engages, I'm guessing the last two inches in the pedal's distance? What distance should it start engaging, and how high should the pedal be of the floor? Thanks.
