Clunking sound while braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dgrptr, Feb 5, 2018.
  1. Feb 5, 2018 at 6:13 PM
    Dgrptr
    Dgrptr [OP] Member
    Jared
    Northern California
    2000 Toyota Tacoma SR5, 3.4L V6, 4X4
    Off road tires, plasti-dip trim pieces, wrap around bars rear bumper.
    I was told by my mechanic that both front pads and rotors and drivers side front caliper needed to be replaced.
    I purchased duralast gold pads, duralast gold rotors and a Brake caliper made by Brakebest. I installed everything but accidentally got lube on the ceramic face of the drivers side pads. I wiped it down and put them back in. Put the wheel back on a went on a test drive.
    HERE IS THE PROBLEM:
    When I slow down I hear a rhythmic clunking noise as the truck comes to a stop. It does not pull either direction. I only hear this noise front the front left.
    I tried to fix this issue by putting the old pads back in and wiping down the rotor some but I'm still hearing this clunking sound. If anyone can help me out with some suggestions that would be awesome. I'm really close to taking everything off, cleaning and starting over. If not I guess I'm headed to a mechanic to shell out some more $$.
  2. Feb 5, 2018 at 7:30 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Is the clunk coming from the front or rear? These trucks are known for axle wrap. Makes a clunk and slight shudder.
    05yoter likes this.
  3. Feb 5, 2018 at 7:33 PM
    tcjacado
    tcjacado Well-Known Member
    Do the pads have a lifetime warranty. If so remove them, take them in for a new set. I did this on my frontier when I put the pads in backwards. Took them out three days later and got new ones for free.
  4. Feb 5, 2018 at 7:58 PM
    djohn24
    djohn24 Well-Known Member
    Dennis
    Pa
    03 Double cab SR5 Tacoma 4x4
    Did you grease/lube caliper pins? You may have a bad caliper. This is similar that happened to someone I know on their vehicle. They installed new calipers and had same issue. Your clunking didn't change when you switched back to old brakes so, you can rule out brakes.
    frizzman and tcjacado like this.
  5. Feb 5, 2018 at 8:11 PM
    05yoter
    05yoter Active Member
    Joshua
    Connecticut
    Tacoma 4x4
    3" Supreme Suspension Lift Kit, Bilstein 5100, K&N, Curtis Tatton driveshaft, Detroit Trutrac, some other doodads...
    clunking might be bad UCA or LCA bushings, its been driving me nuts. I ruled out brakes, bearings, etc.
  6. Feb 5, 2018 at 9:54 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Try scuffing the rotor surfaces and pads with 120 grit sandpaper.
  7. Feb 5, 2018 at 11:30 PM
    Dgrptr
    Dgrptr [OP] Member
    Jared
    Northern California
    Yeah I mean it
    Was a brand new caliper that I bought. Could it clunk if grease got on the rotor ? I mean it’s just weird because I did pads and rotors on both fronts. Only the caliper was on the front left where the sound is coming from. I torqued the caliper bolts to spec as per chilton. It almost feels like I’m getting a sticking sensation from the front left as well when I pull off from a stop sign just after I’ve done a hard test brake. Sticking pads? Sticking caliper pistons ?
  8. Feb 5, 2018 at 11:46 PM
    05yoter
    Joshua
    Connecticut
    Tacoma 4x4
    its not the brakes
    1997tacomav6 likes this.
  9. Feb 6, 2018 at 12:38 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    It didn't make this noise before you changed the brakes correct?
  10. Feb 6, 2018 at 6:38 AM
    Dgrptr
    Dgrptr [OP] Member
    Jared
    Northern California
    Correct. But I had just had tie rods and left front wheel bearing done by a mechanic a week before with no sound after that
  11. Feb 6, 2018 at 6:43 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Did you bed the brakes in? I found that the truck would shudder when they are brand new and not worn in with the bed-in procedure yet.
  12. Feb 6, 2018 at 7:04 AM
    Dgrptr
    Dgrptr [OP] Member
    Jared
    Northern California
    Umm not a shuddering but more of a clunk in a cyclic pattern. As if it happens at one point in the rotation. Which makes me wonder if it’s a caliper problem... rotor... or pads. Sucks man I just want one thing to run smoothly
  13. Feb 6, 2018 at 7:36 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Why did your mechanic suggest to replace it all in the first place? What were the symptoms?
    If you still have your original OEM calipers, try putting those back on.
    OEM is always better that aftermarket chinese stuff.
  14. Feb 6, 2018 at 7:40 AM
    Krazyoakes
    Krazyoakes Well-Known Member
    Isaac
    Eugene, OR
    01 Tacoma 4x4
    Try this!
    I had a clunk in my brakes when I first did them and it was just because I didn’t bed them in properly. I’m pretty sure @Prayn4surf had the same issue.
    Don’t worry too much about the little grease you got on it, I think you just need to wear them in a little.
  15. Feb 6, 2018 at 7:44 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did you bleed the brakes?
  16. Feb 6, 2018 at 7:44 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    I felt like such an idiot when someone asked me the same question, like my mind jumped out of my head and had to be slapped back in place. New rotors n brakes require a break in procedure to properly “bed” the brakes. Listen to the senior in highschool @BartMaster1234 he knows better than most haha
    Read the instructions for break in. It should be on the box that the pads came in
    lucky13don and BartMaster1234 like this.
  17. Feb 6, 2018 at 7:48 AM
    Prayn4surf
    Socal
    Did it sound like the rotor was slipping, and hitting your lugs? Thats literally what mine sounded like, quite unlikely, and definitely NOT the problem...scared the shit out of me. Do the break in procedure, it will go away.
    Krazyoakes likes this.
  18. Feb 6, 2018 at 8:20 AM
    tony2018
    tony2018 Well-Known Member
    Could be the wheel bearins
    could be your control arm bushings
    I don't think it would be the rotor loose because the wheel lugs have to be tight on already or else the wheel would've fell off by now but I will still suggest checking this too.
  19. Feb 6, 2018 at 9:22 AM
    Dgrptr
    Dgrptr [OP] Member
    Jared
    Northern California
    No I didn’t try bedding them in yet and only bled the caliper that I disconnected. I guess I’ll bleed in order. The reason the mechanic said to replace them was because my rotors were too thin for regulations and the caliper had a frozen piston.
  20. Feb 6, 2018 at 9:53 AM
    Prayn4surf
    Socal
    I wouldnt drive too much on them without bedding them, it will cause improper seating of the pads and will possibly warp your new rotors. Takes 15-20 minutes...
