Clunk when turning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MemphisTaco, Mar 2, 2021.
  1. Mar 2, 2021 at 9:59 AM
    MemphisTaco
    MemphisTaco [OP] Well-Known Member
    Cody
    Nashville TN
    2018 TRD offroad Tacoma
    Kings 2.5 front/rear, ICON RXT, RR2-s, 285/75/17 KO2
    Hey everyone,
    Curious if anyone has had experience with this before. I have a 2018 TRD off-road, which has bilstein 6112s, fox 2.0 rears, and Dakar’s. When turning my wheel while moving there is a faint clunking noise that I can feel with my feet. I thought it was my ball joints at first, but after greasing them heavily I no longer think they are the culprits. Possibly the steering rack? I have gone underneath the truck and everything seems to be very secure. Any help/insight is greatly appreciated!
  2. Mar 2, 2021 at 10:25 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    I would go and check/retorque all the bolts that were related to those suspension upgrades and see where that puts you. Something is likely loose.
    MemphisTaco[OP] and na8rboy like this.
  3. Mar 2, 2021 at 12:23 PM
    Bigmamoo
    Bigmamoo Big mamoo
    Hawaii
    2021 Tacoma TRD off-road MGM
    Check the bolts on the skid pan. When I had my suspension installed they over torqued the four bolts to the front skid pan.
    once I torqued to spec the clunk went away.
  4. Mar 2, 2021 at 12:26 PM
    MemphisTaco
    Cody
    Nashville TN
    everything is torqued to spec. I have had this suspension on my truck for maybe 20k miles now and this noise just developed. Taking to the dealership tomorrow to hopefully diagnose it
  5. Mar 2, 2021 at 12:36 PM
    desert_gypsy
    desert_gypsy Well-Known Member
    2020 MGM TRD Off-Road
    I would jack up the front end and see if you have any play in the wheels. If not, pull them off and check IFS for play.
    Burqueboy505 likes this.
  6. Mar 2, 2021 at 1:04 PM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Check the frame bolts that connect the body to the frame. There is one under your left foot. The nut is in the kick panel. Mine was loose years ago and made a clunking noise and tightening it solved the problem.
  7. Mar 2, 2021 at 1:50 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Skid plate
  8. Mar 2, 2021 at 3:43 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Lug nuts?
  9. Mar 2, 2021 at 3:50 PM
    MemphisTaco
    Cody
    Nashville TN
    all torqued. its confusing
  10. Mar 3, 2021 at 6:07 PM
    MemphisTaco
    Cody
    Nashville TN
    Well, dealership gave me the classic could not replicate, when I offered to take a tech out to show them they refused due to policy.
  11. Mar 3, 2021 at 6:10 PM
    Bishop84
    Bishop84 Well-Known Member
    I wont drive with customers anymore, I hated it anyway haha.
    If you can try to get someone to record it. But if its difficult to replicate its probably not a huge deal.
  12. Mar 3, 2021 at 8:19 PM
    CT Yankee
    CT
    Because of company policy or because of insane customer driving?
    How about if YOU were the driver?
  13. Mar 4, 2021 at 6:47 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    the wheel turn stops?, happened on another toyota of mine and just added some grease on them and it stopped
  14. Mar 4, 2021 at 7:01 AM
    MemphisTaco
    Cody
    Nashville TN
    i originally thought that may be the case, but its not happening at full lock. Very strange
  15. Mar 4, 2021 at 7:04 AM
    TheTacoMarine
    TheTacoMarine Well-Known Member
    2016 Tacoma TRD Sport
    I’m experiencing the same. I’ve noticed my sway bar has some scratches on it. Appears to be rubbing against something but I can’t identify it. I’m running 265/75/17 Toyos with 6/5 bilstein.
    auskip07 likes this.
  16. Mar 4, 2021 at 7:13 AM
    MemphisTaco
    Cody
    Nashville TN
    your swaybar may be coming in contact with your shock body. I have a spacer for my swaybar that gets it out of the way, Id check that if i were you
  17. Mar 4, 2021 at 7:45 AM
    TheTacoMarine
    got a link to the kit?
  18. Mar 4, 2021 at 7:50 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Check that the Sway bar may be contacting the skid plate ? Sometimes the skids get pushed up and start rubbing on stuff.
  19. Mar 4, 2021 at 8:17 AM
    MemphisTaco
    Cody
    Nashville TN
  20. Mar 4, 2021 at 8:34 AM
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    Mine does it when I turn. I just had it in for suspension rebuild and my lower control arm caster bolt needs to be replaced. They said that is a possibility since it isn't holding full torque at the moment. The shop also said sometimes the lower arms shift a tiny bit making that sound as the bushings wear a bit. They didn't seem overly concerned about the sound.
    MemphisTaco[OP] likes this.
