"Clunk" when starting/stopping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Apr 7, 2021.
  1. Apr 7, 2021 at 11:13 AM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    So this has been happening for some time now, but it seems like it's getting worse. When I start to first accelerate or when the truck levels out at a stop, it has a distinct clunk type feel to it. I say feel because I can't hear anything when it happens, but it almost seems like something is loose and slipping. I'm going to check the torque on the U-bolt nuts, but has this happened to anyone else before? Could this be axle wrap getting worse? It appears to be coming from the rear of the truck best I can tell. Thanks.
  2. Apr 7, 2021 at 11:22 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Torque your Ubolts to 73 ft. Lbs. This was a problem from factory. Do a search.
    Chukwithak and Tacoma13_NC[OP] like this.
  3. Apr 7, 2021 at 12:54 PM
    Tacoma13_NC
    I just checked the U-bolts and they were all torqued at 73 ft/lb except one.
  4. Apr 7, 2021 at 1:00 PM
    spitdog
    Damn, I figured that was the culprit. Spare tire snug?
  5. Apr 7, 2021 at 1:04 PM
    Tacoma13_NC
    Yep. I checked it while I was under there. I'm just hoping it is nothing to do with the transmission.
  6. Apr 7, 2021 at 1:38 PM
    spitdog
    Realoldfatguy likes this.
  7. Apr 7, 2021 at 6:12 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Check the U-joints and the Carrier Bearing
  8. Apr 7, 2021 at 6:16 PM
    Realoldfatguy
    Realoldfatguy Well-Known Member
    Bob
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    RokBlokz Rally Flaps Toyota running boards
    This was the issue with mine. Changed the transmission fluid at it went away.
  9. Apr 7, 2021 at 6:17 PM
    Tacoma13_NC
    I just did a drain/fill two weeks ago. If it was that, it should be fixed by now. I appreciate the info though.
  10. Apr 7, 2021 at 6:18 PM
    Tacoma13_NC
    I'm 99% certain my needle bearing is going bad or has already done so. I'm starting to get a growl when coming to a stop.
  11. Apr 7, 2021 at 6:30 PM
    TwistedTLM4
    TwistedTLM4 Unknown Member
    Philadelphia, PA
    '05 DCSB TRD Sport
    WeatherTech Floor Mats, WeatherTech Bug Shield and Vent Visors, Audio Upgrade, RaamAudio RaamMat & Ensolite, Mr. Marv's Custom 10" Sub Enclosure, Pop N Lock Electronic Tailgate Lock, mattgecko's Bedlights, Demello Offroad Single Hoop Bumper, Marathon Seat Covers, Leer Topper, OME885s on 5100s, @Blackout14 HD Leaf Pack
    Check the lower control arm bolts. Mine did the same thing after getting an alignment - tech forgot to tighten bolts...
    tacoman45 and Tacoma13_NC[OP] like this.
  12. Apr 7, 2021 at 6:32 PM
    Tacoma13_NC
    I didn't think to do that. I'll definitely check them next chance I get.
  13. Apr 8, 2021 at 8:24 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    check the LCA bushings. If they are bad and the LCA is moving around like it shouldn't, it would be on a start/stop or acceleration/deceleration.
    And also it could be something as simple or dumb and something loose rolling around in the bed, bed cubbies, under seat storage. Check all those things too.
    Gunshot-6A and Tacoma13_NC[OP] like this.
  14. Apr 8, 2021 at 11:31 AM
    GP_spence
    GP_spence Well-Known Member
    AL
    2013 DCSB TRD Off-Road 4x4
    Slip joint. Don't know why Toyota didn't put a grease zerk on it. You can remove DS & grease it and it will go away for a while.
    https://www.youtube.com/watch?v=AvKwgjpsbdg
    Worn leaf springs wrap and make it worse.
    cwk84 and Tacoma13_NC[OP] like this.
  15. Aug 3, 2023 at 4:06 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I’m going to reopen this old thread and tell you the solution I found. I’ve had this issue for years and have spend dumb money on a transmission mount, carrier bearing, slip yoke lubing, righting u bolts, check spare tire play, etc.
    About 2 months ago I developed a horrible squeak in the right rear end. I could push the bed down and it would squeak. It just so happened that I was having an CV joint replaced and asked them to tell me where it was coming from. They said rear shock. I put in new shocks about 8 years ago due to a wreck. Lately the ass end of the truck didn’t seem to stay down and so I bought some Bilstein 5100. I have zero lift. When pulling the old pro comp shocks I noticed that the upper bushings were hard and compressed. There was play in the top of the shock. After putting in the new shocks (the pro comps turned out the were just fine). The cluck is gone! It might be worth buying 4 upper shock bushings and installing them. Very cheap fix. Horse them down in between the washers until they expand the same diameter of the washers.
    So happy this was an easy fix.
