Cloning 2 sets of TPMS sensors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fishingeek603, Mar 24, 2022.
  1. Mar 24, 2022 at 9:45 AM
    Fishingeek603
    Fishingeek603 [OP] Well-Known Member
    New Hamphire
    2023 TRD Sport, Super White Access Cab 4x4
    Fox 2.0 front with res adjustable rears jba ucas icon rxt leaf pack.
    Hello all, I didn't some digging on the forums and there really isn't much on cloning tpms sensors. With that being said. Can anyone give me a definitive answer as to if it's possible to clone a set of OEM steel sensors with alloy tpms sensors? If so can you provide links? TIA.
  2. Mar 24, 2022 at 10:48 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I have three sets of wheels for my 2017 Tacoma. One set is the OEM sensors in TRD OR alloys. For the second and third set of wheels I have installed 8 Autel MX 315 cloneable sensors and I have uploaded the OEM sensor ID numbers using my Autel TS601 to each sensor (I got the 601 since I did not have a OBDII tool). Since the truck only sees the same four ID numbers, there is no programming the PCM/ECU. Swap wheels in a few minutes put the others away and follow the OM for the TPMS button by my knee and done.
    BarRedAmateur, NoOne, grogie and 6 others like this.
  3. Mar 24, 2022 at 7:05 PM
    SuperAir
    SuperAir Well-Known Member
    Maine
    19 TRD ORAC Cement
    Eibach Stage 1, 17x8.5 Ray 10s, 265/70-17
    I just got 4 Autel MX cloneable sensors today and the scanner should be here tomorrow. I'll be doing the same as eurowner and cloning my factory sensors to run different tires/wheels . Looks to be pretty straight forward after a little research
    NoOne likes this.
  4. Mar 24, 2022 at 7:14 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I must say this is very smart, definatly something to remember for the future.
  5. Mar 25, 2022 at 5:59 AM
    Stigman
    Stigman Well-Known Member
    2020 Cement TRD OffRoad
    A couple of related questions you guys might be able to help with.
    • Is it possible to install 5 of these sensors in 5 wheels if one wanted to cycle the spare in with tire rotations?
    • If I sold my OEM wheels with the OEM sensors in them, is it possible to use that Autel tool to retrieve the codes from the ECU for programming new sensors?
  6. Mar 25, 2022 at 6:13 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I can answer your first question, someone will have to answer your 2nd.
    No, you cannot add a 5th sensor. Some Toyota vehicles allow it, the Tacoma isn't one, unfortunately.
  7. Mar 25, 2022 at 6:34 AM
    WyoRoadDog
    WyoRoadDog Well-Known Member
    2018 TRD OR
    +1, I just did this same setup on a set of dedicated snow tires for my truck. I did the Ts508 tool to program.
  8. Mar 25, 2022 at 6:45 AM
    Stigman
    Dang that’s a bummer. I’ll probably just leave them all out if that’s the case. Thanks for confirming!
  9. Mar 25, 2022 at 8:28 PM
    eurowner
    eurowner Duke Sky
    Scoty
    The 3rd Gen PCM/ECU can only see 4 sensors. There have been reports here when there is a 5th wheel with sensor which causes the TPMS to “crash”.
    Yes, Techstreams shows a window which only works for vehicles that have a PCM/ECU that is designed to see 5 sensors, a’la the Landcruiser and specific years for the 2nd Gen Tacoma.
    Yes, but you are not looking at the PCM/ECU with the hand held Autel tool! You wave the Autel tool on the wheel at the valve to scan the old sensors, write the IDs down/take a picture of the screen, and then you can manual input those IDs into your new cloneable sensors.
    Koolbreeze7 likes this.
  10. Mar 25, 2022 at 8:35 PM
    o0_henry
    o0_henry Well-Known Member
    South Texas
    2018 Tacoma TRD-offroad
    How do I map the sensors if I don’t have the originals? The light drives me up a wall
  11. Mar 25, 2022 at 8:40 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Map the sensors?
    Do you know what specific sensors are in your wheels?
  12. Mar 25, 2022 at 9:54 PM
    o0_henry
    South Texas
    Meant program. There are none at the moment. Need to pick up a set. But I’ve held off until I can figure out what Are the easiest to program without having the original to clone
  13. Mar 26, 2022 at 4:34 AM
    Fishingeek603
    New Hamphire
    gotcha i was curious if i was able to clone the steel sensor with alloy but was unaware they were different frequencies and they sit at a different angle? looks like ill be in on the FSC buy for another alloy set.
  14. Mar 26, 2022 at 4:56 AM
    SuperAir
    Maine
    19 TRD ORAC Cement
    Pretty sure the Autel sensors will work as they are basically universal as long as they are cloneable ones. They also cover 315/433 frequencies in one sensor.
    I’m sure you can get the codes out of the ecu somehow as even tho the sensors are gone the info should still be there.
    As long as your TPMS tool has OBD capability I don’t see why you couldn’t read the ECM
    You can clone the sensors by inputting the info manually from a scanner, so if you have the old IDs you don’t need the old sensors.
  15. Mar 26, 2022 at 5:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    Tacomas used to have sensors in the spares, ended around mid production of the '09 model IIRC.
    So, someone who has an earlier vehicle should have this option.
    ktbell444[QUOTED] likes this.
  16. Mar 26, 2022 at 5:30 AM
    Fishingeek603
    New Hamphire
    so forgive my ignorance once again but im seeing 2 different Autel tools on Amazon one is 160 and the other is a whopping 280 dollars... what is the difference with these models?
  17. Mar 26, 2022 at 5:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    $120.
    Sorry. Just could not resist........... :D
  18. Mar 26, 2022 at 5:33 AM
    Fishingeek603
    New Hamphire
    dang.... you got me there lol
  19. Mar 26, 2022 at 5:47 AM
    Fishingeek603
    New Hamphire
  20. Mar 26, 2022 at 6:26 AM
    SuperAir
    Maine
    19 TRD ORAC Cement
    The 508 has OBD capability for the TPM system and comes with a cable. You should be able to program new ifs into the ecu with this one. The 408 has no cable it’s a wireless unit for basically just learning and programming sensors themselves. Not sure where you are in NH but I’m in S.Maine right across the river and I have the TS408.
