Clock spring / spiral cable replacement - symptoms, part number, & guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kogary, Mar 3, 2012.
  1. Mar 3, 2012 at 1:58 PM
    kogary
    kogary [OP] Well-Known Member
    Denver
    2005 Indigo Ink AC, V6, auto, 4x4
    Heated drivers seat, JVC HU, Sound Ordinance compact 8" sub under passenger seat, Morimoto projectors/D25 HIDs, LED lit cupholder mod
    Hi All,
    I recently replaced my clock spring / spiral cable (Toyota uses the term "spiral cable"). I did a lot of research before replacing the part and found that most of the info I needed was scattered over multiple threads. So I wanted to create a consolidated info thread to help future TacomaWorld searchers :)
    Vehicle information:
    2005 Tacoma SR5
    4.0 V6
    4x4
    ~53,800 miles on odometer
    NO steering wheel audio controls
    My symptoms:
    - Horn stopped working
    - Cruise Control stopped working
    - Airbag light on
    I ordered my new clock spring / spiral cable from https://www.discounttoyotaparts.net/ (I priced every OEM supplier site I could find, and they had the lowest price including shipping).
    I navigated to the following part of their website to find the correct clock spring:
    - Click on "OEM Toyota Parts" link at the top of the page
    - <enter year, make, model>, click search
    - Click on the link for your Tacoma's Trim (e.g., mine was "Tacoma V6 1GRFE - 4.0 Liter)
    - Electrical
    - Restraint systems
    - Air bag Components
    - Clockspring
    - Select either the one "w /o steering switch" if you DO NOT have steering wheel audio controls, or "w/ steering switch" if you DO have steering wheel audio controls. You'll notice a $20 difference between the two parts.
    Since I DO NOT have the steering wheel audio controls, I ordered the following:
    Description:
    Collision Catalog - 2005 - Toyota - TACOMA
    electrical, restraint systems, air bag components, clockspring w/o steering switch $199.57
    Sub Total: $199.57
    Tax $0.00
    FedEx Ground - Shipping $17.46
    Total: $217.03
    There are two versions of this clock spring / spiral cable. If you DO NOT have steering wheel audio controls, order the one I listed above. The official part number is: 84306‑04080 (which for some reason they don't list next to the part itself, however when the package arrived, the OEM toyota box it was shipped in had a sticker with the part number above printed on it).
    If you DO have the steering wheel audio controls, the official part number is: 84306‑0E010.
    I followed the following guide to remove and replace the clockspring:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/106114-2nd-gen-clockspring-replacement-how.html
    Kudos to MYSUV for such a great guide!
    The only part of the guide that I did not need to follow was the part dealing with the steering wheel puller. My steering wheel slid off nice and easy. Apart from that, everything else was the same.
    Overall, this was a very easy DIY project. On a scale of 1 - 10, 10 being the most difficult, I would rate this as a 2. This took about 30 minutes, start to finish. By doing it yourself can save you around $200, compared to having the dealership do it for you.
    Also, www.discounttoyotaparts.net was a pleasure to do business with. I ordered the part on a Sunday evening and they had it shipped out Monday afternoon. I received the part 2 days later (on a Wednesday) in a very well packaged box. I wouldn't hesitate to do business with them again!
    Hope this helps future members searching for clock spring / spiral cable replacement information!
  2. Mar 7, 2012 at 3:51 PM
    CSCHOL
    CSCHOL Well-Known Member
    Chad
    W. Michigan
    ‘23 TRD OR
    Stocker
    DETROIT — Toyota Motor Corp said on Wednesday it is recalling more than 681,000 cars and trucks in the U.S. market to address potential problems.
    The Japanese automaker said it will recall about 495,000 Tacoma pickup trucks from model years 2005 to 2009 to replace a part in the steering wheel. It is also recalling about 70,500 Camry mid-sized cars and 116,000 Venza crossover vehicles from model years 2009 to 2011 to replace a stop lamp switch.
    Toyota said it is not aware of any accidents or injuries in either case.
    For the Tacoma, Toyota will replace the steering wheel spiral cable assembly because friction may occur over time involving that part, which may result in the driver's side airbag being deactivated and not deploying in an accident.
    For the Camry and Venza, silicon grease during assembly may lead to increased electrical resistance that can cause the vehicle not to start or the shift lever not to move from the "park" position, Toyota said.
    Both fixes will take about 30 minutes, the company said. Owners of the affected Tacomas will be notified in early April, while the others will be alerted as soon as Toyota has the necessary replacement parts.
  3. Sep 24, 2013 at 6:40 AM
    jeremyk61
    jeremyk61 Well-Known Member
    I went to the site to order the part and it lists the clock spring as N/A with no button to add it to my cart....any idea why it's no longer available?
  4. Sep 24, 2013 at 7:08 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Have you tried to have the dealer do it for free? It's a recall and your dealer should cover it.
  5. Sep 24, 2013 at 7:24 AM
    81shark
    81shark Well-Known Member
    exactly...
    had mine done for free
  6. Sep 24, 2013 at 7:36 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2... good thread but this shouldn't cost you a penny. This is a safety recall, Toyota is obligated to make the repair for free.
  7. Sep 24, 2013 at 7:52 AM
    jeremyk61
    Yes. I have a 2005 and it has the steering wheel controls; Toyota told me it is not covered/included in the recall. I don't have the air bag light on, just the cruise control isn't working. So frustrating!
    offbrother1 likes this.
  8. Sep 24, 2013 at 12:22 PM
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    Same here. My cruise control stopped working, but no airbag light. I am also not apart of the recall.
  9. Sep 24, 2013 at 12:28 PM
    Brian007Taco
  10. Sep 26, 2013 at 7:32 AM
    jeremyk61
  11. Sep 26, 2013 at 11:25 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I had replaced this on my last truck, then 2 months later got a recall letter. So I brought it in, Toyota changed it again, and I mailed Toyota corporate a letter and my receipt from buying the part previously. They sent me a check about a month later.
    tacomakid96 likes this.
  12. Sep 28, 2013 at 9:40 PM
    Swamp Donkey
    Swamp Donkey Well-Known Member
    Fort St John B.C
    2011 4cyl SR5 auto 4x4
    I bought 2 of them. Just received them 2 days ago. I have audio controls, cruise and of course the airbag and horn not working. I noticed that even though it says it is for a vehicle with audio controls, there are 2 connectors, with 4 wires. So in short, I am not sure if everything will work. I am at least hoping for the horn and airbag. :rolleyes:
  13. Sep 28, 2013 at 9:58 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  14. Oct 8, 2013 at 5:47 PM
    jeremyk61
    Any luck with that part?
  15. Oct 8, 2013 at 9:12 PM
    Swamp Donkey
    Fort St John B.C
    Have not tried installing yet. Probably by the weekend. I might have two for sale! HAHAHA
  16. Feb 10, 2014 at 2:19 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    Any luck? I think I ran into the same problem.
  17. Feb 11, 2014 at 5:15 AM
    Swamp Donkey
    Fort St John B.C
    I did end up buying two of them. The 1st one I installed, the horn honked as soon as I hooked it up. Would not stop honking. The second one, has been working flawlessly. So I did have success with that part number. The worst part was the connections. I had to kinda bend the "male" pins to make the connections work on both of them. Took a long time! It's hard to line up like ten or twelve little pins when you can't see what's going on!
  18. Feb 11, 2014 at 5:49 AM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
  19. Feb 20, 2014 at 2:12 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    I spoke with two dealers in Denver and both said it was covered under the 3/36 warranty, so I'm out of luck. The part was about $345, and labor about $115. So I won't be doing that. Seeing as Toyota already had a recall on the same part on the '05-'09's, I think they will eventually extend the recall.
  20. Mar 4, 2014 at 7:59 AM
    goingcamping
    goingcamping Well-Known Member
    Brett
    Colorado
    2007 Tacoma
    Custom body work...boat trailer came of hitch, hit tailgate and Rammed stick thru lower valance while towing boat....hmmm, Maybe I should get a new boat?!?
    Brian007taco
    Any luck with the ebay/Chinese ones? I'm thinking of unloading my Tacoma for a 3/4 ton and I hate to buy a Toyota one, if the Chinese ones will at least remove clear the code?
    I called Toyota this morning and my truck isn't covered under the recall (16 pin vs 7 pin). I have the wheel controls...the cheapest I've found a factory replacement is $226.00, ebay $49.99.
    Thanks,
    ~Brett
    EDIT: I went ahead and ordered the ebay/Chinese clock (spiral) spring. I read quite a few of feedback comments posted and all (but one with a Prius) had positive comments about the clock spring they received! Granted most were impressed with the expedited shipping, but none-the-less, no real complaints about the part itself? I'll update once I get the part? $51.99 shipped from San Francisco (I'm sure off a long boat ride from China).
