Clock resets.....everyday! HELP!
Discussion in 'Technical Chat' started by bkmcinty, Dec 24, 2012.
  1. Dec 24, 2012 at 4:20 AM
    bkmcinty
    bkmcinty [OP] Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Ok so two days ago I get into my truck and my map and dome lights will not turn on.....weird I will also say they are all LEDs from CS jumper which I don't think has anything to do with it but anyways....also the clock says 1:00 every time I turn the truck on now....regardless if I set it to another time every time I turn it on it says 1:00! It's driving me nuts! I have not checked my fuse box yet but any other input? Has this happened to anyone before? If the fuse was bad I would imagine the clock would just not turn on.....also it's dimmer than usual almost faded.....
  2. Dec 24, 2012 at 4:27 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    My best guess would be a short in your battery terminals. I would clean all of the connections, and see if that works.
  3. Dec 24, 2012 at 4:48 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    ^X2 or just swap out the battery.
  4. Dec 24, 2012 at 4:58 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    So you think my battery is going too low voltage wise everyday? Hmmm......truck starts fine and I would think the voltage would have to go really low to reset the clock and at that point the truck wouldn't start......but I'll check the terminals and do a battery test with my dim....and how about the interior lights? Any ideas there?
  5. Dec 24, 2012 at 4:59 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
  6. Dec 24, 2012 at 5:17 AM
    Robnik
    Rob
    Greenacres, Florida
    That is odd, that it starts. Do the headlights come on w/ the engine off? You could also get a jump & see if the dome light goes on then.
  7. Dec 24, 2012 at 5:32 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Yeah everything else works flawlessly....I'm thinking all the interior lights went out somehow I have the stock bulbs ill pop one in and see if they work then....but the clock deal puzzles me.....
  8. Dec 24, 2012 at 5:57 AM
    Robnik
    Rob
    Greenacres, Florida
    Interior light, personal lights, clock & vanity lights are all on the same fuse. Engine compartment, slot 23, 7.5 A on my truck.
  9. Dec 24, 2012 at 6:11 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    It's just the map and dome light that won't come on.....it's so strange
  10. Dec 24, 2012 at 6:11 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    I'm thinking something somehow shorted out and blew the bulbs and screwed up my clock
  11. Dec 24, 2012 at 6:47 AM
    Robnik
    Rob
    Greenacres, Florida
    I too, am perplexed. Hope you figure it out.
  12. Dec 24, 2012 at 7:23 AM
    Rodeo73
    Rodeo73 Well-Known Member
    Idaho
    1997 Tacoma 4x4
    Grizzly Chrome Rollbars (Double Bar Single Kicker), Smittybilt Chrome Light Bar, 5 6" Chrome Off Road Lights, Smittybilt Chrome Nerf Bars, Smittybilt Chrome Pushbar w/ Chrome Wrap-Arounds, Diamond Plate Rail Caps, Diamond Plate Tailgate Cover, Bed Mat, Black Mudflaps w/ Chrome Weights, 2" Bushwacker Fender Flares, Stainless Rock Guards, Bilstien Shocks, Tinted Windows, Vent Visors, K&N Air Filter, Toyota Hood Deflector, 15" Chrome Mod Rims w/ 31x10.50 Tires, Hidden Hitch Receiver, Wet Okole Seat Cover (lt. grey & black), UltraGauge
    Check your fuses. The wiring diagram shows at least your dome and clock memory are on the same fuse.
    7.5A DOME includes: clock, interior light, wireless door lock control.
    I can find it on the clock memory and dome light diagrams, but not seeing it for the wireless door circuit.
  13. Dec 24, 2012 at 7:59 AM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    If the fuse was bad I don't think the clock would even turn on....but I'm going to check it as soon as I get off work and let you guys know!
  14. Dec 24, 2012 at 8:57 AM
    Rodeo73
    Idaho
    1997 Tacoma 4x4
    Yes it would. It should have a main power feed, a memory feed, and a illumination feed (when you turn on your headlights). The fuse you need to check is the one that feeds the memory circuit which also happens to power your dome light.
  15. Dec 24, 2012 at 9:12 AM
    Davtopgun
    David
    Central Alabama
    It's not the voltage of the battery. It's your connection to the battery. They sell cleaning kits for battery terminals. Something small like lights are going to go off and on and sometimes flicker. Starting the truck will still work do to the voltage that it will use vs something small.
    Clean the terminals, it's very easy. They also have this grease stuff that they use to make the connection better. I've dealt with similar problems on many different vehicles.
  16. Dec 24, 2012 at 2:07 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Ok update time! When I turn my headlights off the clock indeed DOES turn off completely! But I checked all the fuses under the hod as well as the fuses under the steering wheel and all of them are good. I used the continuity setting in my multimeter.....I'm stumped! There is no corrosion on the terminals and the terminals are very tight. Any other thoughts?
  17. Dec 24, 2012 at 3:02 PM
    Robnik
    Rob
    Greenacres, Florida
    What was the battery voltage? Should be around 12.6V~12.7V w/ nothing on. Also, did you check the dome light socket for "juice"?
  18. Dec 24, 2012 at 3:43 PM
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Both my batteries rest at 12.82 volts with the truck off.....did not test the socket
  19. Dec 26, 2012 at 9:33 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    +1 to this.
    The clock has a constant power wire to keep the time, and an ignition power wire to illuminate the clock. It sounds like the constant supply is not working for some reason.
  20. Dec 26, 2012 at 9:35 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Mine did this once and it was a fuse under the hood...took me forever to find it I just don't remember which one it was :cool:
