Clicking sound while driving. Please help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Baja13, May 25, 2019.
  1. May 25, 2019 at 7:19 PM
    Baja13
    Baja13 [OP] Well-Known Member
    Antonio
    Vacaville CA
    13 Super White TX Baja
    I’ve been hearing a noise (faint clicking sound) with every rotation of the tire but can not figure out what it is coming from. No there are no rocks stuck in the treads. I’ve had a few mechanics take a look at it but they claim that they can’t hear what I’m hearing. Anyone know what may be causing this noise?
  2. May 25, 2019 at 7:23 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Can you help us out with a bit more detail?
    Does it do this with your foot adding pressure to the brakes?
    Does it sound more from the front or the back of the truck?
    How fast do you think the clicking is occurring?
    I'm interested.
    wilcam47 likes this.
  3. May 25, 2019 at 7:24 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    my guess would be alignment cam bolts shifting around, mines clicking, creaking out the whazooo. and its a nightmare scenario to try and replace or fix them
    Baja13[OP] likes this.
  4. May 25, 2019 at 7:26 PM
    Baja13
    Antonio
    Vacaville CA
    The clicking seems to go with every rotation of the tire. So the faster I go the quicker the click. I don’t know if it continues with pressure applied to the brakes but it definitely seems to be coming from the front!
  5. May 25, 2019 at 7:26 PM
    Baja13
    Antonio
    Vacaville CA
    I might have to give that a look!
  6. May 25, 2019 at 7:28 PM
    BillsSR5
    bill
    2014 SR5
  7. May 25, 2019 at 7:33 PM
    Baja13
    Antonio
    Vacaville CA
    wilcam47 and BillsSR5[QUOTED] like this.
  8. May 25, 2019 at 7:34 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I had similar sounds coming from the rear brakes when one of the springs came loose and from the front brakes when the clip rusted out of a pin and it was contacting the rim.
    b_r_o and DayTripper85 like this.
  9. May 25, 2019 at 7:35 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    If it goes away when you press the brakes, it's an issue with the pad retaining clips.
    Search for it on here, I posted a fix, somewhere in the brake threads
    lo2hi, Baja13[OP] and BillsSR5 like this.
  10. May 25, 2019 at 7:36 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    if its rotational check the tires yourself, look all around then move the truck forward and look again. If you can isolate it to driver side or passenger that will help narrow it down.
  11. May 25, 2019 at 7:38 PM
    Baja13
    Antonio
    Vacaville CA
    Really appreciate the quick responses!
  12. May 25, 2019 at 9:05 PM
    DayTripper85
    DayTripper85 Well-Known Member
    2005 Tacoma DCSB Off Road
    Yep a thumb tack or nail in the tread does this.
    A broken spring that holds your brake pads will do this
    Torque all your lug nuts to 85-90 lbft of torque
    If it's a click that speeds up and slows down it points to rotation, and not fixed points on your chassis. However it's never a bad idea to crawl under your truck with a torque wrench to check that all the bolts are properly torqued. Never hurts to check all the fender liners, grill clips, rocks trapped in the skid plates.
    If your truck is a 4x4 then check your front CV boots, and axles for play.
    Other culprits are u-joints, the rear trans output shaft bell housing is easily bent and can rub,click,squeak, and wheel bearings.
    Side note. I have a 2002 Miata that sits on Vmaxx Ultimate coilovers and has full underbody bracing and a hard dog scca roll bar. After 20k miles or so things will loosen up. Just last Wednesday I lifted the car on jack stands and took all the wheels off. What bolts did I find that were slightly off listed toraue specs?
    Rear lower shock mount bolt was off by a few lbs (it was rattling over bumpy roads)
    Front right break caliper was off by a few pounds (it was squeezing on bumpy roads)
    Roll bar body attachment locations were a little loose (was hearing another squeek)
    Heel-toe breaking into an apex the rear diff was a little loose feeling (loose mounting bolts)
    All the underbody paneling nuts and bolts got a quarter turn.
    After spending a couple of hours checking all the torque specs on the chassis and suspension my little Miata is now solid as drum and doesn't shake, squeek, or rattle.
    Let us know if you resolve it! Cheers
    Skyway and Baja13[OP] like this.
  13. May 25, 2019 at 9:20 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    I'd do this. Take a another hard look at the tires, I've seen more then once where a screw or bolt that's imbedded has been the culprit.
  14. May 25, 2019 at 9:22 PM
    Baja13
    Antonio
    Vacaville CA
    I’ve checked em probably a thousand times but I guess it would hurt to check once more lol
    DayTripper85 likes this.
  15. May 25, 2019 at 11:27 PM
    lo2hi
    lo2hi Well-Known Member
    Chiro
    Portland, Oregon
    2006 Impulse Red Tacoma 4.0L 6-Speed 4WD
    265/75R16 Falken Wildpeaks AT3W & KMC Enduros AFE air intake Bilstein 5100 & Eibach Springs & Ironman4x4 performance leaf Magnaflow 12866 muffler
    Did you get your wheels balanced recently? Discount tires did a free inspection for me, but the added wheel weights contacted the brake pad clips. Ended up going home and ripping them out.
  16. May 25, 2019 at 11:37 PM
    Baja13
    Antonio
    Vacaville CA
    I bought my tires from Less Schwab and they are normally pretty reliable when it comes to balancing, and alignment. That might also be something to look into though. Thanks for the input!
    Skyway likes this.
  17. May 26, 2019 at 6:48 AM
    BillsSR5
    bill
    2014 SR5
    its probably a rock stuck in the tire treads images_844cc825544f56ca53f192b39fb77263be4d27d1.jpg
  18. May 26, 2019 at 7:07 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Check the inside of your front rims for evidence of contact first. Then I'd have professional check the front CVs (4X4). 2X4, get the front wheel bearings inspected, re-packed, replaced if needed. I put wider wheels on an S10 once, the wheels weights just barely contacted the outer tie-rod end. Made the slightest of clicking noise. Stick-on inside the rim type weights were the simple fix in that case.
  19. May 26, 2019 at 7:11 AM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    I was thinking a rock too or CV joint
    BillsSR5[QUOTED] likes this.
  20. May 26, 2019 at 7:26 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    I had a clicking noise with tire rotation,it turned out to be one of the center caps had lost a tab,and it was floating around inside.
    Drove me nuts trying to figure out what it was
    DayTripper85 and Skyway like this.
