Clicking sound coming from my front CV????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Teagan141, Sep 18, 2014.
  1. Sep 18, 2014 at 3:43 PM
    Teagan141
    Teagan141 [OP] Well-Known Member
    Teagan
    Llewellyn,PA
    10 TRD Sport
    plasti derp rims, BHLM, emblems, (homertaco)raptor style grill, bilistein 5100 set at 2.5 with stock coil, 2 inch custom alcan 8 leaf pack, with icon 2.0 extended travel rear shocks with resies, front and rear spider trax wheel spacers, rigid dully spots mount on the hood with CBI brackets
    So this clicking/rubbing sound.started happening this afternoon behind my driver side front tire. It starts after I hit 45-50 then cobtinues to get faster vut you cant hear it below that speed . So I jacked the front up and tokk the tire off I thought.maybea rock.was caught.in the break pad no rock....then I proceeded to rotate my wheel brearinf and thre ia a clickinfg sound coming from where my cv joint goes into my transfer case anyone ever have this prob I could really use a hand with.thos problem btw sorry for the.miss spellinf and bad grammer had to do this.from an old dumb phone.and I dont.feel like taking mytime to correct everything
  2. Sep 18, 2014 at 4:47 PM
    Rambone71
    Rambone71 Well-Known Member
    TJ
    North east
    2014 tacoma off road
    Sounds like a bad CV joint. They normally click when they go bad...
  3. Sep 18, 2014 at 5:34 PM
    gearcruncher
    Canadain bumper technician
    possibly one of your diff side gears has a broken tooth but its not normal hearing this at highway speeds going in a straight line .If you are hearing the noise as you spin the axle with the front end jacked up and the tire removed , I would guess that your 4x4 selector fork on the front axle is partially applied . Have you tried 4x4 since the noise started ?
    Front Differential Carrier Assembly (For 4WD): Components
    Front Differential Carrier Assembly (For 4WD): Removal, Disassembly, Reassembly
    Front Differential Carrier Assembly (For 4WD): Installation
  4. Sep 18, 2014 at 5:44 PM
    Teagan141
    Teagan
    Llewellyn,PA
    10 TRD Sport
    Ya 4wd still works engages and disengageswith no problems
  5. Sep 18, 2014 at 5:45 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Definitely the CV joint. Time for a new CV.
  6. Sep 18, 2014 at 6:01 PM
    Teagan141
    Teagan
    Llewellyn,PA
    10 TRD Sport
    ....its a definate click when took the wheel off and turned the hub it was a steady click and got faster as I spun the hub faster
  7. Sep 18, 2014 at 6:04 PM
    Teagan141
    Teagan
    Llewellyn,PA
    10 TRD Sport
    That was the first thing I looked for. Not even a spot of grease.
  8. Sep 18, 2014 at 6:06 PM
    gearcruncher
    Then I doubt its an axle problem .brb .I really doubt your issue is Constant velocity joint failure
  9. Sep 18, 2014 at 6:10 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Broken/damaged CV doesn't always result from a split boot.
    Takes 15 minutes to pull the CV. Just pull it and spin the hub again and see if it still clicks.
  10. Sep 18, 2014 at 6:20 PM
    Teagan141
    Teagan
    Llewellyn,PA
    10 TRD Sport
  11. Sep 18, 2014 at 6:21 PM
    gearcruncher
  12. Sep 18, 2014 at 6:37 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    http://www.4x4wire.com/toyota/maintenance/cv_axle/
    That's for a first gen but it's the same except second gens have two large bolts on the LCA/LBJ instead of 4.
    You'll need a 35 mm socket for the axle nut.
  13. Sep 19, 2014 at 12:02 PM
    Teagan141
    Teagan
    Llewellyn,PA
    10 TRD Sport
    So I took it to a garage today andthe.machanic said I need a new carrier diff bearing
  14. Sep 19, 2014 at 12:22 PM
    gearcruncher
  15. Sep 19, 2014 at 12:23 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah. when my CB and U joints went out a few weeks ago, i had similar symptoms. quick and easy fix.
    EDIT: do you mean the Carrier Bearing, or the rear diff?
  16. Sep 19, 2014 at 4:03 PM
    Teagan141
    Teagan
    Llewellyn,PA
    10 TRD Sport
  17. Sep 19, 2014 at 4:04 PM
    Teagan141
    Teagan
    Llewellyn,PA
    10 TRD Sport
    Sry carrier bearing ya I thought it was gunna be alot worse
  18. May 8, 2017 at 10:24 AM
    Taco_4x4_Guy_
    Taco_4x4_Guy_ Member
    USA
    2017 Toyota Tacoma DC TRD Off Road Premium
    3" Toytech Lift, Toyota Billstein Shocks, TRD Pro Grill, 18" Fuel Rims with 285 65 R18 Cooper Discovery SST Tires.
    So I'm glad I found this thread. I just replaced my driver side CV axle on my 04 Tacoma and it is making a clicking sound (after replacement) I took everything back apart and noticed it's clicking back and forth at the diff. So I hit the end of the axle with a hammer to make sure it was drivin all the way in, and after a second test drive, it still clicks when I hit bumps while turning (like into my driveway). Could this mean my front gear needs replacement?
  19. May 31, 2017 at 10:34 AM
    RedBostonTaco
    RedBostonTaco New Member
    2004 Tacoma SR5 4WD Xtra Cab
    I have a similar rattling sound coming from what sounds like the passenger front wheel well. Sound is only noticeable when I turn right.
    I don't have the equipment to do more than an oil change - any ideas on what I should tell the shop to look for to keep the labor costs as low as possible?
    Also looking at replacing a 3inch lift that I recently found out was removed from the front (but they left the blocks in the back) - worth it to schedule all this work at once?
    Thanks
  20. Jun 6, 2021 at 7:09 AM
    Kgrecurit88
    Kgrecurit88 Active Member
    Kyle
    2017 Tacoma TRD OR DCSB SWhite
    Drop in k&n Leveking kit Rago ditch lights
    Revive a dead thread. I'm having this issue and have replaced the cv axle already but still hear it. Starts to get noticeable at 20 then louder at 45 and when I apply breaks at higher speeds its really noticeable.
