Clicking noise with no ignition
Discussion in '3rd Gen. Tacomas (2016-2023)' started by curt85, Aug 15, 2021.
  1. Aug 15, 2021 at 2:56 PM
    curt85
    curt85 [OP] Member
    2017 Tacoma TRD Sport
    Tried starting my tacoma today, only 27K, and all I get is a clicking noise. It’s a 2017 so almost 4 yrs old. Thought maybe battery, but I can run radio and all lights without cranking it. Any thoughts before I reach out to dealer?
  2. Aug 15, 2021 at 3:11 PM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    Sounds like a battery to me. I just replaced my battery from 2017 yesterday.
  3. Aug 15, 2021 at 3:14 PM
    Tacospike
    Two Trucks
    Probably battery.
    low batteries can run lights and radio with low cold cranking amps, but not turn the engine
  4. Aug 15, 2021 at 3:15 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Yeah, this is most likely just a battery on it's last leg. An old battery can certainly have enough juice to run accessories, but not enough to start the truck.
    ndoldman59 and curt85[OP] like this.
  5. Aug 15, 2021 at 3:15 PM
    curt85
    curt85 [OP] Member
    That’s what I was thinking. Did you have a clicking noise too? I had the battery sign come on in accessory mode, meaning system not charging, but a dead battery could cause that too I suppose.
  6. Aug 15, 2021 at 3:16 PM
    curt85
    curt85 [OP] Member
    Thanks everyone. I pull it tomorrow and get it checked.
    Tacospike likes this.
  7. Aug 15, 2021 at 3:18 PM
    Bikinaz
    Hey You!
    Phoenix, AZ
    Mine was clicking and failed to start. Eventually it did quit clicking though.
  8. Aug 15, 2021 at 3:18 PM
    Greene368
    Greene368 Well-Known Member
    Metro Atlanta, GA
    2021 Toyota Tacoma TRD Sport 4X4 Predator, Black
    The clicking noise is common. It's definitely the battery. Clicking noise for me happens almost every time the battery has gone out for me in various vehicles I've owned. Not uncommon.
    curt85[QUOTED][OP] likes this.
  9. Aug 15, 2021 at 3:22 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Just jump it, if it fires right up, there's a very very good chance it's the battery. 4 years is about all you'll get out of a battery,,, often less. Those low miles are only harder on a battery, having to sit for periods of time, then discharge even more to start.
  10. Aug 15, 2021 at 3:23 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Your battery is dead. Quick trip to the parts store for a new one and you'll be good to go.
  11. Aug 15, 2021 at 3:30 PM
    Greene368
    Metro Atlanta, GA
    You could jump it or get a battery tender (a low level charger for about $30) to get you a few days.
    For the record, I'd save that money and get the battery tested at AutoZone or another store and put the money toward a new battery. Luckily it's summer, if it were cold, it would be worse on the battery regarding starting.
    Mark77 likes this.
  12. Aug 15, 2021 at 3:34 PM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Yep, battery heat is just as hard on them as cold. Besides there are many more electronics putting a constant low drain on it with the low mileage.
  13. Aug 15, 2021 at 3:38 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think Wally World has a 2 year battery for like $60
  14. Aug 15, 2021 at 3:43 PM
    ndoldman59
    Murray
    West Fargo, ND
    Steves probably right on. But go for there best I believe for about 40 or 50 more you can get one with a free 3yr Total replacement warranty. And an additional 3yr prorated.
    Steves104x4 and curt85[OP] like this.
  15. Aug 15, 2021 at 11:56 PM
    Greene368
    Metro Atlanta, GA
    True...
  16. Aug 17, 2021 at 4:36 PM
    curt85
    curt85 [OP] Member
    Thanks everyone. I changed battery out today and everything looked like it was working fine. However, if I push the ignition twice to go into accessory mode I keep getting “check charging system”. Thoughts? I’ll prob just call dealer tomorrow, but interested to see if anyones knows about this.
  17. Aug 17, 2021 at 5:16 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    The battery won't charge when you are in accessory mode because the engine isn't running. Are you sure you're in accessory mode and not in Ignition/Run mode? That's what it sounds like. Which of course is different than start mode.
  18. Aug 17, 2021 at 5:26 PM
    curt85
    curt85 [OP] Member
    If you push ignition button twice, everything comes on such as radio/control windows, and the truck doesn’t crank. Isn’t that accessory mode? The truck isnt running, but maybe its something different.
