Clicking noise when wheel turned & driving/reversing at slow speeds
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SammiSilver, Apr 22, 2022.
  1. Apr 22, 2022 at 8:09 PM
    SammiSilver
    SammiSilver [OP] Member
    2021 Tacoma SR
    Running boards, tonneau cover, emblem/tailgate overlay/insert, trd pro grille and headlights,
    My 2021 Taco started making this odd slow ticking noise when driving/reversing at slow speeds (2 secs apart & stops when I come to a stop) & it primarily occurs when when the steering wheel is turned in either direction—sounds to be coming from upper driver side near the steering column. Any one else is experience this weirdness?
  2. Apr 23, 2022 at 12:11 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Stock sized tires?
    I’m wondering if you went larger and have a slight rub,,, since you mentioned when turning. Just a guess though
  3. Apr 23, 2022 at 12:16 PM
    RDW59565
    RDW59565 Well-Known Member
    Utah
    2022 TRD Pro M/T Mag Grey
    How many miles? Bad CV joint?
    Frankenstuff likes this.
  4. Apr 23, 2022 at 4:13 PM
    j45p3r
    j45p3r Well-Known Member
    Downeast Maine
    2022 MBM TRD Pro 6MT
    Sounds like a CV joint to me.
    Frankenstuff and JFriday1 like this.
  5. Apr 24, 2022 at 12:02 PM
    SammiSilver
    2021 Tacoma SR
    I actually swapped the stock tires for 265/65/17 & had a 2in front lift & 1in the rear (TRD Lift Kit — PT84K-35221)
    I put about 2k on the new set up & only now did the weird clanking start to kick up:goingcrazy:
  6. Apr 24, 2022 at 12:03 PM
    SammiSilver
    2021 Tacoma SR
    Just hit the 5k mark…
  7. Apr 24, 2022 at 3:01 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    That’s still stock size so probably not the tires
    Chew likes this.
  8. Apr 25, 2022 at 12:22 PM
    RDW59565
    Utah
    Pretty soon for a CV joint to go south.....but that's what your description sounds like.
  9. Apr 25, 2022 at 1:08 PM
    roboturner
    Colorado
    weird q, but have you checked the mudflaps and or splashguards to make sure they're fastened securely?
  10. May 6, 2022 at 6:33 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Did you find the issue to be the CV joint ? Pretty low miles for that.
  11. May 6, 2022 at 6:52 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    could be the egcs or however it's spelled bearing
  12. May 6, 2022 at 7:31 PM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Bad radiator support bushings
  13. May 7, 2022 at 12:17 AM
    80sforlife
    80sforlife Well-Known Member
    2017 Toyota Tacoma DC TRDOR 4x4
    I had a clicking noise while turning which ended up being a bad hub bearing. Got it replaced and the sound is gone.
  14. Sep 23, 2022 at 11:02 AM
    SammiSilver
    2021 Tacoma SR
    Ok so, good news is the I found the issue (resolved quite a while ago, sorry for the late response!).
    The bad/dumb news is that I’m guessing my local Toyota dealership is incompetent as hell. I brought my truck in for the Toyota care oil change (I’ll now be doing this myself…) and what I am guessing is that the mechanic must’ve taken the entire trd skid plate off instead of just getting to the oil filter via the little window. When putting it back on they must’ve not torqued to spec…I checked myself, re-torqued to spec and you betcha, no more sound!
    Thanks for all the detective work here, y’all!
