Clicking noise after tire rotation.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ernrok, Nov 14, 2019.
  1. Nov 14, 2019 at 8:37 AM
    Ernrok
    Ernrok [OP] New Member
    Ernie
    2011 Tacoma magnetic gray metallic TRD Off Road
    Nothing yet.
    So I took my 2011 4x4 Tacoma to the local Toyota dealer for an oil change and tire rotation. As I was driving home I noticed a clicking noise coming from the left front wheel while driving straight. It seem to get louder as I go faster. I reached out to the dealer and still waiting for a call back. BTW, didn’t have a problem prior to this tire rotation.
    Thanks in advance.
  2. Nov 14, 2019 at 8:40 AM
    theick
    theick Well-Known Member
    Eric
    Las Vegas
    you probably have something stuck in the tire; rock, nail or screw. That tire was probably right rear before and you just didn't hear it.
    LAMCKMA007 and Bleep100 like this.
  3. Nov 14, 2019 at 8:41 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Check the dust shield on your drivers brake. It could've been knocked when they pulled the tire off. Its a simple fix of bending it away from the disk brake slightly.
    -J
    LAMCKMA007 likes this.
  4. Nov 14, 2019 at 8:42 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    I second a nail or rock in the tire tread. Definitely would get louder with more rotations
  5. Nov 14, 2019 at 8:50 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Rock in tire, bent dust shield, or wheel weight contacting the caliper.
  6. Nov 14, 2019 at 8:59 AM
    Ernrok
    Ernie
    Nothing yet.
    Theick, JAM and NYC taco.
    Thank you all for the quick response. I did take the front left wheel off and didn’t notice any rocks or nails. I will check the break dust shield when I get home. Will post results
    JustAddMud likes this.
  7. Nov 16, 2019 at 12:44 PM
    Ernrok
    Ernie
    Nothing yet.
    Hello all, so last night I jacked up the taco and pulled the drivers side wheel. I found the wheel weights had fresh rub marks. For whatever reason, when I had the wheels balanced they stacked the weights on top of each other and it was rubbing on the caliper. Went to Firestone for a wheel alignment and had then balance all 4 wheels. Problemo solved.
  8. Nov 16, 2019 at 4:48 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Firestone - really. Find a good local garage, pleazzze.
  9. Nov 21, 2020 at 8:51 AM
    AZJJ
    AZJJ New Member
    JJ
    2010 Tacoma Double Cab
    Although a year after this conversation was posted this helped me figure out a similar issue on my 2010 Tacoma. Had tires rotated yesterday and immediately driving away i heard a clicking noise that got MUCH louder the faster I went. This morning I pulled my front passenger wheel off and found that a brake clip was repeatedly rubbing against the weights mounted on the inside of my wheel like a mini Price Is Right wheel. Bent the clip in, and worked like a charm! Thank you all!
  10. Nov 21, 2020 at 8:54 AM
    sled dog
    sled dog Well-Known Member
    Nice follow-up. :thumbsup:
  11. Feb 1, 2022 at 3:52 PM
    Stormtrooper Taco
    Stormtrooper Taco New Member
    2020 TRD Pro
    This site never fails me! Had the same issue and turned out to be the dust shield
  12. Mar 12, 2023 at 7:31 PM
    Swaine
    Swaine Well-Known Member
    2024 F-150 5.0 Lariat
    Trueeeeee. I had some new wheels/tires put on and they stacked the wheel weights and they were rubbing.
  13. Mar 16, 2024 at 7:39 PM
    CodeE007
    CodeE007 New Member
    C
    2013 Tacoma TRD Limited
    I actually just had my tires rotated earlier today and had a similar “clicking” noise as I left the shop in rhythm with the speed I was going. After about 5 or so miles it stopped with no reoccurrence the rest of the way home. I’ll probably take a closer look at them tomorrow just to be sure it’s nothing serious.
