Click/Clunk when shifting into park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by T Fades, Jan 11, 2013.
  1. Jan 11, 2013 at 7:52 AM
    T Fades
    T Fades [OP] Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Have an '11 auto with about 25k miles. Have not done any tranny maintenance yet, but am religious about oil changes.
    Noticed that sometimes when I shift into park I hear a click/clunk from the shifter. I can also see the shifter move slightly as it is making this noise.
    My normal procedure for parking (usually on flat ground): come to a stop, set parking brake while foot is still on main brake, put shifter into neutral for a second until the engine goes into neutral, then put shifter into park, at this time I hear the click/clunk, then release foot from main brake.
    Also noticed that sometimes when going to leave, when shifting out of park, it sometimes is more difficult to get the tranny out of park. Not really difficult, but not as easy and smooth as I would like.
    Anybody have this happen to them? Any thoughts?
  2. Jan 11, 2013 at 9:25 AM
    T Fades
    Simi Valley, CA
    Maybe the gears are not lining up properly when shifting to park?:notsure:
  3. Jan 11, 2013 at 9:32 AM
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    95% sure what your hearing is the parking pawl slipping into place it's normal. Also when shifting out of park if the parking pawl has a load on it you will fill resistance when shifting out of park this is normal. The pawl is what locks the tranny from spinning when in park.
    Matt8vt likes this.
  4. Jan 11, 2013 at 9:45 AM
    T Fades
    Simi Valley, CA
    Thanks Tripps, makes sense. Hopefully this is not going to cause issues down the road.
  5. Jan 11, 2013 at 10:59 AM
    Tripps2012
    NC
    2014 TRD OR
    No issues that I see it's just how auto's are made. I will say this if you park on a steep hill set the parking brake before you place the truck in park. It's just easier on the parking pawl with the brakes holding the bulk of the load.
  6. Dec 3, 2022 at 2:21 PM
    Nemesis-dsl
    Nemesis-dsl Well-Known Member
    21 Trd Sport.
    I’m my 3rd gen, the cause of the clank when putting it into park or from park was due to the auto door lock feature when in park or leaving park.
