Clear coat on headlight lens?
Discussion in 'Lighting' started by SEAN B, Sep 11, 2014.
  1. Sep 11, 2014 at 7:24 PM
    SEAN B
    SEAN B [OP] Well-Known Member
    SEAN B.
    SAN DIEGO
    05 PRERUNNER DCSB
    MODS/UPGRADES DONE- *ICON COIL-OVERS (LEVELING KIT) *TRD INTAKE SYSTEM *TRD CAT-BACK *RIMS & TIRES *WINDOW TINT *OEM TRAILER HITCH *GRILLCRAFT MX GRILL *TRD FRONT SEATS *'09+ OEM LED TAIL LIGHTS *TAILGATE ANTI-THEFT MOD
    Went to a local body shop a while back for a paint quote. The guy noticed my headlights and said he could restore my headlight lens and spray a clear coat on the lens so that it wouldn't discolor again.
    Has anyone done this before?
  2. Sep 11, 2014 at 7:51 PM
    Tacoma Mike
    Southern Maine
    We just started using this procedure.
    Has a life time guarantee.
    Works well.
    Does take a little finesse.
  3. Sep 11, 2014 at 7:58 PM
    medic2230
    Murph
    Bama! Roll Tide
    Just a standard clear coat? Same as over the paint?
  4. Sep 11, 2014 at 8:00 PM
    Tacoma Mike
    Southern Maine
    Ahhhh no.
    I don't know the composition but it smells different.
    It has anti yellow stuff in it I was told
  5. Sep 11, 2014 at 8:05 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    One of the major body shops in my area is doing this. I've known the fellows for over twenty years. They claim that the UV inhibitors in the clear coat is key in your tired old, newly polished lens, staying bright and clear. I know I've reconditioned some before with good results. Only to have them "yellow" very quickly afterwards.
  6. Sep 11, 2014 at 8:06 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I wax mine
  7. Sep 11, 2014 at 8:10 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    This sounds kinda cool, and a complete fix for hazing/yellowing.
    so do i also do tail lights.
  8. Sep 11, 2014 at 8:27 PM
    SEAN B
    SEAN B.
    SAN DIEGO
    05 PRERUNNER DCSB
    Do you know if they are using a standard clear coat?
  9. Sep 11, 2014 at 8:28 PM
    SEAN B
    SEAN B.
    SAN DIEGO
    05 PRERUNNER DCSB
    I was thinking of buying new headlights and having them sprayed at the same time my roof is being painted.
  10. Sep 11, 2014 at 8:37 PM
    t4daddy
    North Alabama
    No, but I can find out. Just assumed it was standard with UV protectors. I also just bought new lights (before hearing about this) Depo brand appear to be just as good as OEM. BTW, I worked at North American Lighting. We made all the Tacoma reward lighting at my plant, standard and LED. Again, these fixtures appear just as well made IMO.
  11. Sep 11, 2014 at 8:41 PM
    BamaToy1997
    Bill
    Navarre, FL
    I have been doing this for years at the shop to restore faded headlights. The clear coating on the lens surface gets faded and yellow/flakes off over time. I use 2000 grit sand paper to sand it all smooth, then spray one coat of Bulldog adhesion promoter. Let it flash, then 2 coats of a quality standard clear-coat. It will last you pretty much forever.
  12. Sep 11, 2014 at 8:48 PM
    SEAN B
    SEAN B.
    SAN DIEGO
    05 PRERUNNER DCSB
    What are the part numbers for your Depo lights?
  13. Sep 11, 2014 at 8:51 PM
    SEAN B
    SEAN B.
    SAN DIEGO
    05 PRERUNNER DCSB
    I'll keep this in mind. Will the clear coat not stick to the lens without applying the Bulldog first?
  14. Sep 12, 2014 at 4:44 AM
    t4daddy
    North Alabama
  15. Sep 12, 2014 at 5:36 AM
    BamaToy1997
    Bill
    Navarre, FL
    Technically it can. The purpose of the Bulldog is to act as a clear "primer" just like in painting. It helps the clear stick better, and longer.
  16. Sep 12, 2014 at 7:22 AM
    t4daddy
    North Alabama
    How much would this service cost a person?
  17. Sep 12, 2014 at 8:09 AM
    SEAN B
    SEAN B.
    SAN DIEGO
    05 PRERUNNER DCSB
    Cool, thanks for the part numbers. I was having a hard time finding them for some reason.
    I'll make sure to pick up a can and have the body shop apply it before they spray the clear coat.
  18. Sep 12, 2014 at 9:54 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Mine are cleared. Heads and tails
  19. Sep 12, 2014 at 11:49 AM
    BamaToy1997
    Bill
    Navarre, FL
    I typically charge $79 a pair, not including shipping costs if shipped. There is a lot of prep work involved.
  20. Sep 12, 2014 at 12:00 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    friend of mine waxes his ranger they still look brand new.. Put suntan lotion on them.
