Clear coat bubble spreading. How to slow it down??
Discussion in '1st Gen. Tacomas (1995-2004)' started by grbergk, Feb 6, 2022.
  1. Feb 6, 2022 at 2:22 PM
    grbergk
    grbergk [OP] Member
    Seattle
    02 Tacoma SR5 Automatic
    Noticed this bubble formed between base and clear coat. Started from a rock chip on the hood and quickly grew over a week to be a couple inches long. Should I leave the bubble or try to remove the peeling parts to where it hasn't delaminated yet? I know it probably can't be stopped but I at least want to slow the spread of it.
  2. Feb 6, 2022 at 2:49 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Keep it out of the sunlight and see a professional auto finish specialist.
    If you opt for DIY use two part clear coat.
    grbergk[OP] likes this.
  3. Feb 6, 2022 at 3:20 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Limit sun exposure and get it in for repair before the bubble opens and exposes your paint
  4. Feb 8, 2022 at 10:33 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    The paint has failed, just get it into a shop. They will strip the hood and repaint.
    Have them remove the hood so they don't have to tape your fenders, the fenders might have poor paint work as well. Tape might start pulling paint off.
  5. Feb 9, 2022 at 5:43 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    The clear coat is shot. A cheap alternative, sand it down and wrap it.
  6. Feb 9, 2022 at 5:52 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Welp, sand it down and re-coat with Raptor. I mean, like, the entire truck...
    I mean, that's the solution I've come up with for me...
    I tried chipping the bubbles off and sanding down to get rid of the edges (so I'd get to where it wasn't peeling anymore), then sprayed clear coat on it. I honestly don't think it did all that much. I also didn't do THAT great of a job, and ended up sanding thru the paint in a few places too, so that's what inspired the "F it all and just Raptor line it" thing.
    Take it to a paint shop if you want to have any hope of it turning out looking nice. You can kinda see how well it turned out for me in this pic... (by the bed rail)
  7. Feb 9, 2022 at 7:13 PM
    Runninrutt
    Runninrutt Active Member
    I just did my entire truck because the clear failed. Sanded it down and redid everything. Primer, color and clear. Took 4 days. upload_2022-2-9_22-12-38.jpg
    kgw likes this.
  8. Feb 9, 2022 at 7:15 PM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    Nice color choice.
  9. Feb 10, 2022 at 11:53 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Once your clear starts going, it’s only a matter of time before the rest of it goes. The clear failed on my roof and hood and I had to redo them. I sanded it down to factory primer/metal, fixed low spots with Bondo, then I did High Build Primer, Base Coat, and Clear Coat. Blending the roof into the c-pillars was really difficult since there’s no hard body lines.
