Cleaning Wheel Wells
Discussion in 'Detailing' started by Rockstar Junkie, Sep 8, 2008.
  1. Sep 8, 2008 at 8:15 AM
    Rockstar Junkie
    Rockstar Junkie [OP] Well-Known Member
    Springville,UT
    06 4x4 TRD Sport
    Whats the best way to clean the black plastic wheel wells? What type of cleaner? I tried cleaning them this weekend with a little spray cleaner I have, and barley did any damage. I know a lot of people just spray tire shine on them, but I want to clean them first, then shine them up. Let me know some suggestions. Thanks!
  2. Sep 8, 2008 at 9:33 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Pressure washer, dip the suction hose in good old NON WAX car wash, spray them down, let them soak for a few, then set the pressure back to high and blast them off.
    Don't make the water stream too sharp, if I do that with my pressure washer it's strong enough to take paint off.
  3. Sep 8, 2008 at 10:05 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i usually clean my wheel wells with some simple green/greased lightning and a small scrub brush........and it usually works pretty good too. then, you can spray something like armorall on there and let it sit for a bit, and it'll have some pretty good shine to it.
  4. Sep 8, 2008 at 11:43 AM
    91Toyotabogger
    91Toyotabogger "Loud Tires Can Save Lives"
    North Carolina
    91 4wd 5sp manual Pickup Standard cab white
    Mud Tires, CD player, CB radio with PA speaker, De-badged, window decals, Flow Master 40 series
    There is this tire cleaner called "Bleach White' it works well on tires and finder wells and any colored plastic, it will also get stains off the under body, just spray it on let it sit and wash off, i use it under my truck before i spray paint it back black
    lynyrd3 likes this.
  5. Sep 8, 2008 at 11:44 AM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    I 2nd the Simple Green with scrub brush.
  6. Sep 8, 2008 at 12:03 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    mr clean magic eraser then hose it off and dry with a shammmy
  7. Sep 8, 2008 at 12:05 PM
    it's in coma
    it's in coma Well-Known Member
    in the desert
    06 trd off road
    intake and exhaust
    pressure wash with simple green or wheel cleaner...
  8. Oct 19, 2008 at 8:05 PM
    mitiko
    mitiko Well-Known Member
    lax
    05 prerunner trd
    WHEEL ACID is the best I have used.
  9. Oct 23, 2008 at 2:46 PM
    jarhead773
    jarhead773 Member
    Atlanta
    08 Prerunner Off Rd
    I was told that over time using armour all or wheel shine will cause the fenders that aren't the same color as the truck to fade and turn gray. There is a product that is used to renew the soft covers for convertables and he said that won't cause fading. The guy runs a detail shop.
  10. Oct 23, 2008 at 2:54 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I did some roll-on bedliner in my wheel wells. They're always black now.
  11. Oct 23, 2008 at 2:59 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I spray mine clean with a pressure washer then spray this tire cleaner on. It cleans as well as shines but if you put it on your tires wait a while before driving as it will sling itself onto your truck and leave a grease residue. Not visible on silver. I normally do my truck at night and don't drive till morning. When sprayed on innner wheel well it doesn't matter.
  12. Oct 23, 2008 at 3:17 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    I love them eagle one products!! their tire/wheel cleaner is amazing!!!!
  13. Jan 3, 2009 at 9:33 PM
    ERdept
    ERdept Well-Known Member
    I spray simple green then a toilet brush for the car wells and wheels.
    But I do something I dont' think anyone else here has done once cleaned.
    I noticed that as the truck ages and I shine my tires with the spray on tire shine, the wheel wells and the frame and all the other stuff in the wheel well fade and get dust on them and generally look dull and dusty.
    I now spray EVERYTHING visible in the wheel well with tire shine. It keeps everything shiny and dark.
    I think it also makes it easier on future cleanings to get rid of the dirt.
  14. Jan 3, 2009 at 9:40 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Damn you guys go all out. I just give it a good spray with the hose.
  15. Jan 4, 2009 at 7:19 AM
    tacoman316
    tacoman316 go big or go home
    Mobile AL
    08 SR5 Prerunner
    K&N drop in filter, Banks monster exhaust
    I use that bleach white tire scrub with a medium bristled brush. After the truck is dry i spray the wells with WD-40. It helps the dirt and rubber from sticking to the wheel wells.
  16. Jan 4, 2009 at 7:28 AM
    Red Razor
    Red Razor Well-Known Member
    Greensburg PA
    06 TRD Sport 4X4
    When I wash my truck, I always hose off the wheel wells. Then I get in there with a long handled scrub brush to clean them up. I do this while cleaning the wheels.
    When I am all done washing, I spray black magic tire shine in the wheel wells. Sometimes I'll let it sit for a while, then go back with an old rag a wipe up the excess.
    Nothing uglier than a clean truck with dirty wheel wells.
  17. Jan 5, 2009 at 4:07 AM
    ERdept
    You are an extremly intelligent person.
    Glad to know someone else out there has sense.:D
  18. Jan 6, 2009 at 9:01 AM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    i like to use either super clean or bleach white and then pressure wash them out. After i start detailing and spraying tire shine i will cover the fender wells and anyhting else visible underneath with WD-40 and it seems to make mud and dirt not stick as bad next time.
  19. Jan 6, 2009 at 9:05 AM
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    I use purple power!(I think thats the name) You just spray it on, let it sit for 30 sec, and wipe away! The wheel will look brand new! If its really dirty you may have to do it 2 or 3 times and then wash after!
  20. Aug 9, 2017 at 10:00 PM
    AlabamaGunner84
    AlabamaGunner84 New Member
    Michael
    2008 Tacoma SR5 TRD Glasher White
    K&N air intake, TRD pro exhaust, Nitto Terra Grappler 31s, JL Audio stereo.
    Put my truck on oil changing ramps and go to town. Mostly with my power washer. Then I take rubbing alcohol and spray the areas and dura line everything from the break pads back to the chunk :)
