Cleaning/Testing Injectors
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Sep 7, 2017.
  1. Sep 7, 2017 at 8:40 AM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    next month I plan to replace my valve covers gaskets. While I'm in there I want to check out and clean my injectors. How would I go about cleaning the injectors off the engine?
    Can they get weak or are they more of a completely fail kind of item?
  2. Sep 7, 2017 at 9:03 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I think the cheapest method is to send them to injectordoctor or something and have them flow tested/cleaned etc. Someone else will probably have a link because I obvious don't.
    For the gaskets make sure you have some silicon rtv, there are a few places you need extra sealer :thumbsup:
  3. Sep 7, 2017 at 9:07 AM
    Trapperr
    Reno, NV
    Dang. I was hoping it was something I could do at home.
    Where does the rtv go? I figured I'd just need some o rings. Thanks for any advice
  4. Sep 7, 2017 at 9:18 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    There are 2 semi-circular aluminum caps and 2 circular plugs per head. You need a small bead in the seams of all of them.
    There are videos online for injector cleaning but you can't flow test them. I've seen guys wire the injectors to a 12v battery to open them and spray carb cleaner through.
    Are you doing cam seals as well?
  5. Sep 7, 2017 at 9:24 AM
    Glamisman
    Glamisman Well-Known Member
    I checked with my local carb rebuilder and they want $50 per injector to check,clean, bebuild and flow. I asked him how much for new injectors and he said anywhere from $35 to $65. I found new injectors for $51. I thanked him for his honesty.
  6. Sep 7, 2017 at 9:30 AM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    I had mine cleaned, $25 per injector, at Mr. Injector in Idaho. Money well spent!
  7. Sep 7, 2017 at 9:40 AM
    Glamisman
    Idaho and So Cal worlds apart... you are not a criminal in Idaho if you have a gun or an opinion.
    robertjohnsonjr and Kens04Taco like this.
  8. Sep 7, 2017 at 9:43 AM
    Trapperr
    Reno, NV
    Would those be the same cam seals that are behind the cam sprockets on the front of the engine? Or the half moon caps? I replaced cam seals when I did my t-belt 30K miles ago.
    I do plan on doing the half moons though. Also new grommets for the valve cover bolts as well as spark plug seals and pct grommet.
    Looks like I might be better off pricing injectors.
  9. Sep 7, 2017 at 9:49 AM
    Glamisman
    get the FIPG... toyotas Form in place Gasket sealant. Very good stuff and worth the cost. They recommend that you let it "skin over" before you tighten things up, a few minutes is all it takes.
  10. Sep 7, 2017 at 10:16 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  11. Sep 7, 2017 at 10:50 AM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    Over the years and various Celica and Corollas I have found "GB remanufactured" injectors a good value, they are available in sets, on an exchange basis Look in E-Bay for the best prices. several vendors carry them
    You will be impressed how much this perks up Toyota.
  12. Sep 7, 2017 at 12:23 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Thank yourself for not having common rail diesel in it. Injector price would go up seven times easy.
  13. Sep 7, 2017 at 12:56 PM
    The Driver
    Raph
    It's called shipping, it added like $15 round trip. :rolleyes:
