Cleaning Fluid Film off garage floor.. ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Feb 2, 2019.
  1. Feb 2, 2019 at 4:00 PM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    there's a thin layer of fluid film on my garage floor now after going through 4-5 cans on my frame. Most of it under my truck which obviously makes working under my truck a greasy mess.
    Anyone have any tips on how to remove? I was thinking about just using degreaser and water and sweeping it out. Not sure how effective that'll be.
    GQ7227 likes this.
  2. Feb 2, 2019 at 4:02 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Is it oil? get a can of eng gunk spray/degreaser apply to the affected area and cover with a thin layer of cheap kitty litter over night, brush up the kitty litter in the morning.
    QMEDJoe likes this.
  3. Feb 2, 2019 at 4:06 PM
    bamma
    bamma Well-Known Member
    Spokane, WA
    Current: 2016 Land Cruiser, 2023 Tundra TRD Pro, 1988 FJ62 and 2020 4Runner Limited
    HOT water. Fluid film will liquify when hot. Carefully pour boiling water and scrub with a brush. Gunk degreaser will work too but you'll have to scrub. Put down a cheap Harbor Freight tarp before putting that crap on.
    Edit: from the FF site:
    Removing Fluid Film
    For easy removal of Fluid Film for the purpose of handling or inspection, a high pressure, cold-water pressure wash (1,000 – 3,000psi) is recommended. A standard, industrial strength pressure washer will suffice.
    Fluid Film can also be removed by warm water detergent wash or with a commercial-grade biodegradable cleaner. When choosing a cleaner, one formulated to remove tough grease and grime deposits is advised.
    Fluid Film can also be rubbed in like a wax if total removal of the product is not necessary, since Fluid Film is safe for use on most paints and plastics. This will also offer extended protection of materials.
    For equipment that is to be painted following a treatment of Fluid Film, a more vigorous cleaning is advised. A high-pressure, hot water or steam detergent wash (minimum 120F) is needed. Utilizing cleaning compounds specifically formulated to remove grease/wax as a pre-treatment process for painting are highly recommended.
  4. Feb 2, 2019 at 4:06 PM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    Throw some sawdust down for a week...then sweep it up or kitty litter
  5. Feb 2, 2019 at 4:11 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    There are several methods of degreasing concrete. The cheapest would be to get a 5 gallon bucket of dawn and hot water and using a scrub brush, You could shoot over to Lowes and pick up a gallon of commercial degreaser, dilute in hot water and scrub away. The hard to get areas that remain I would use electra-clean or some type of paint thinner and a rag. That stuff will take off just about anything!
  6. Feb 2, 2019 at 6:09 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Hot water and soap. Mop it a few times. I’ve had to do this several times. Just don’t use your wife’s mop, if you have one, I do and she wasn’t happy. I only made that mistake once.
  7. Mar 21, 2020 at 5:43 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    a few days ago i was FF'n the bed bolts under there to make possibly easier task on removing them for upcoming procedure
    some FF spots dripped onto the garage floor and i wipe them up immediately, i woulda spray outside but a hail storm was brewing (never showed up my area or town TG!) and had to get queen back into the garage lol
    i will check on the spots to see if its still 'oily' and use a warmish dawn mix to spot clean if necessary
    thanks,j
  8. Mar 21, 2020 at 5:25 PM
    TacomanTurd
    TacomanTurd Well-Known Member
    David
    2004 Tacoma
    Stock for now
    Wipe off with a rag and brake cleaner
  9. Mar 22, 2020 at 4:29 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    I vote for dawn dish soap and hot water. Or just speedy dry ground in with your foot then swept up. I agree FF makes for messy repair work, but the ease of taking unrusted stuff apart - out weights the mess.
  10. Mar 22, 2020 at 4:30 AM
    Stormtrooper457
    Stormtrooper457 Well-Known Member
    Indiana
    2013 TRD Sport DCLB
    Nano Ceramic Tint Heated Clazzio Seats TRD Pro Wheels Softopper
    They make bags of these granules that soak up oil. I'd spread that around, let it sit, then sweep it up, then use hot water and dawn if there's any remaining.
  11. Mar 22, 2020 at 6:05 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    I use the brake cleaner and immediately wipe with a rag on anything oily on concrete. Fast and easy, just hang up the rag and it’ll dry off. Way easier than soap and water or other materials.
